CG-5 GT-C11
10 replies to this topic
#1 magnus
magnus
  • Loc: Visby, Sweden
Posted 27 January 2013 - 06:13 PM
Is the CG-5GT steady enough to handle a C11 for visual observations?
Magnus 57N.
#2 A. Viegas
A. Viegas
  • Loc: New York City/ CT
Posted 27 January 2013 - 07:19 PM
Hi Magnus,
There are many posts and discussions on this topic here on CN. Generally I think the opinion is that it is possible, especially if you use the vibration suppression pads. I have used my CG5-AGST with about 28 pounds of stuff and it handled it ok, i was even able to take 20-30 second exposures without much star bloat. When using an auto guider i was able to go 1-2 minutes. So I think it will work for you.
Good luck,
Al
#3 magnus
magnus
Posted 27 January 2013 - 07:46 PM
Thanks very much, Al for your feedback! I have read a lot`bout this topic, CG-5/C11 for visual here on CN. Some say NO some say YEAS (with reservations)so I am a bit confused.
I have an old -73 orange C8 on my CG-5 and it is just so perfect. A C11 would be my "dreamscope" but I don`t want to upgrade my CG-5 (which I am so happy with) to a larger, heavier, like an EQ6 or similar.
Best Regards,
Magnus
#4 jrbarnett
  • Loc: Petaluma, CA
Posted 27 January 2013 - 08:10 PM
My buddy Tom (CNer Americal) runs his C11 on a CG5-GT. It works just fine for visual. I can't recall if Tom runs VSPs or not, but he probably does.
#5 magnus
magnus
Posted 27 January 2013 - 08:56 PM
Thanks Jim for info; I do really wish the combo CG-5GT/C11 really could work for visual.
The max load for CG-5 is 12 kg, C11 is 13 kg. On the other hand the C11 is a relative short scope.
My CG-5 has no issues with my 8" f/6 OOUK Newt. (1200mm long)and it weights 7 kg.
So the C11 must be just on the edge what is possible for the CG-5?
Best Regards,
Magnus 57N.
#6 RTLR 12
RTLR 12
  • Loc: The Great Pacific NorthWest
Posted 27 January 2013 - 09:16 PM
Celestron list the payload for the CG-5 at 35 lbs.
Stan
#7 magnus
magnus
Posted 27 January 2013 - 09:55 PM
Hi Stan,
Payload 35Ibs=17.5 kg -impossible!!
Magnus
#8 RTLR 12
RTLR 12
Posted 27 January 2013 - 10:22 PM
From Celestron's site...
http://www.celestron...se&_a=viewar...
#9 morrisng2
morrisng2
Posted 28 January 2013 - 12:19 AM
The payload rating is a maximum and a bit stretch in my opinion. I have the CG-5-ASGT carrying a C10N (with accessories add up to about 30 lbs). For visual it is okay, but the DEC starts making cranking noise and skip once I put a heavier eyepiece or DSLR on it.
#10 RTLR 12
RTLR 12
Posted 28 January 2013 - 04:29 AM
I think a C10N is a size problem rather than a weight problem.
Stan
#11 EFT
EFT
    Vendor - Deep Space Products
  • Loc: Phoenix, AZ
Posted 28 January 2013 - 11:27 AM
This exact question was just discussed for the millionth time over on the Cats and Casses group here: http://www.cloudynig...5643991/page...
