old meade starfinder 10"
36 replies to this topic
#1 ronaldbrownjr
ronaldbrownjr
Posted 01 February 2013 - 05:01 PM
I just aquired a meade starfinder 10" scope with a magellan II computer and eq mount and i was wondering if there is an upgrade for the magellan II computer? also how dependable are these scopes? any info would be great.. thanks
#2 rmollise
Posted 01 February 2013 - 07:23 PM
Might try the StarFinder Yahoogroup. But there's been no support for the Magellan for ages. The scope itself is very dependable--I mean there's not much to go wrong. The Magellan? It can work competently as a digital setting circle computer. The rest of its features were never really "there." ;)
#3 ronaldbrownjr
ronaldbrownjr
Posted 02 February 2013 - 10:11 AM
thanks for the info.. can i plug a newer handheld into the mount ?
#4 rmollise
Posted 02 February 2013 - 12:10 PM
Handheld what? The original was an AC synchro drive. You can put digital setting circles on it or add an AC drive corrector if you can find one. The DC model could be purchased with the old Magellan HC, which added DSCs and a few other features that semi-worked. You can't really plug anything else but the Magellan II into it. ;)
#5 Glen A W
Glen A W
  • Loc: USA
Posted 02 February 2013 - 06:36 PM
Actually, I found the DC version of the drive was quite unreliable. Also, the big chrome knob to lock the Dec. quit working after a while, no matter how much I tightened it.
The Magellan I had never worked right. Although bought new, I eventually took it apart and found a bunch of loose screws inside!
The scope is rather crude but the one I had had a great mirror and I wish I hadn't sold it, but you know how that goes! I still have the mount out front, decorating my planter! Overall, these scopes were very good for the low cost of them. GW
#6 Glen A W
Glen A W
  • Loc: USA
Posted 02 February 2013 - 06:38 PM
Ps - Drive problems were that the clutch would slip and the drive would not turn the scope - often - and then later, the motor quit running at the right rate. GW
#7 ronaldbrownjr
ronaldbrownjr
Posted 02 February 2013 - 07:39 PM
sounds like i might have my hands full with this scope between reading here and other places... thanks all
#8 Glen A W
Glen A W
  • Loc: USA
Posted 02 February 2013 - 08:13 PM
Mostly just from the heft of carrying it outside. I used mine for years after the drive quit. It was a great scope overall. GW
#9 cheapersleeper
cheapersleeper
  • Loc: Sachse TX
Posted 02 February 2013 - 08:38 PM
I m hopeful that the one in my living room will prove workable. It sure is big.
Brad
#10 rmollise
Posted 03 February 2013 - 09:52 AM
Never found this to be much of a problem. The clutch was adjustable, and I was always able to do that suitably on any of 'em I encountered. As for the Magellan, yeah, as I mentioned, it was never quite there.
#11 rmollise
Posted 03 February 2013 - 09:55 AM
I doubt it. As I said: simple and reliable. :cool:
#12 Glen A W
Glen A W
  • Loc: USA
Posted 03 February 2013 - 12:56 PM
What happened on mine was that somebody made the clutch too tight, before they sold it to me, and it was actually clicking the spur gear teeth over the worm. I did not know at first that is wasn't supposed to do that - this was quite some time ago! GW
#13 ronaldbrownjr
ronaldbrownjr
Posted 03 February 2013 - 02:41 PM
i also understand that i have to replace the focuser as well
#14 cheapersleeper
cheapersleeper
  • Loc: Sachse TX
Posted 03 February 2013 - 02:58 PM
Is the focuser plastic? I have a metal one on my Starfinder and it works fine. The immediate upgrading of every focuser that comes stock is a relatively recent phenomenon.
B
#15 ronaldbrownjr
ronaldbrownjr
Posted 03 February 2013 - 03:40 PM
it looks to be a cheap metal one
#16 Glen A W
Glen A W
  • Loc: USA
Posted 03 February 2013 - 06:01 PM
The focuser on mine was pretty bad! It had a 1.25" holder and then I could unscrew that and stick a 2" eyepiece in it. It would not stay in place at any setting, regardless. It looked like metal but if it was, it was the cheapest pot metal in the universe. I never replaced it though, I just lived with it. I got a lot of use out of that scope, so I would not want to run it down. GW
#17 ronaldbrownjr
ronaldbrownjr
Posted 04 February 2013 - 12:46 PM
I just the scope holds up for a long time since it is my first "large" telescope
#18 idp
idp
  • Loc: New Haven, CT
Posted 04 February 2013 - 01:22 PM
I used A LOT a 1994 Starfinder 8" for many years, still do at times. It still had the AC drive, but I got the inverter they sold at the time with the 12v plug, variable speed controller and fast/slow buttons. It was a must, because the drive took a bit to resume tracking after I moved the tube; so I just waited for the clutch to engage, and centered the object using the fast/slow buttons. It took a couple of minutes, but tracking was decent then.
So bad clutch yes, but I could track; bad focuser yes, but I could focus. Optics were optimized for visual observation, with f/6 focal ratio and 18% obstruction. I have used it mainly for planetary observations, and it was (is) AWESOME. Great value for the money overall, perfect for me, but I would not suggest it for imaging.
Ivano
#19 Glen A W
Glen A W
  • Loc: USA
Posted 04 February 2013 - 01:55 PM
The mirror is likely worth keeping no matter what. The one I had was USA-made and it had a better polish than most Asian mirrors I have seen. I can't believe I let it go. GW
#20 ronaldbrownjr
ronaldbrownjr
Posted 04 February 2013 - 05:27 PM
well if all else fails i can pull the optics and have another scope built for them
#21 ronaldbrownjr
ronaldbrownjr
Posted 04 February 2013 - 07:56 PM
also what kind/type of ep's would make this scope stand out better
#22 hottr6
hottr6
  • Loc: 7,257', Magdalena Mtns, NM
Posted 05 February 2013 - 08:18 AM
+1. My US-made sonotube 10" Starfinder mirror tests at 0.980 Strehl.
#23 hottr6
hottr6
Posted 05 February 2013 - 08:29 AM
I've run quite a few EPs (at least 30) through my 10", and the standouts include a 40mm TMB Paragon, S4K smoothie 8.8mm UWA, S5K 24mm SWA and 18mm UWA, Vixen 13mm LVW and Faworski 7mm Ortho. There are a few holes in this lineup that I have not been able to fill with a standout EP, but there are an awful lot of good EPs out there I have yet to try.
#24 ronaldbrownjr
ronaldbrownjr
Posted 05 February 2013 - 02:32 PM
i am kinda stuck with a small budget to buy things... my wife told me not to spend alot on this hobbie as i have another expensive hobbie...booo
#25 csrlice12
csrlice12
  • Loc: Denver, CO
Posted 05 February 2013 - 03:35 PM
Hey, this hobby isn't expensive, it just costs a lot of money! :lol:
However, look at it this way, for the most part, astronomy equipment will last nearly as long as you do (except mirrors may need recoated every 10-15 years, which is still better then most items made today. So, what really is the cost?
