scope hitting hard stop in both directions
5 replies to this topic
#1 DUCE202
DUCE202
Posted 01 February 2013 - 11:14 PM
help!! my lx200 is hitting the hard stops in both directions after turning it 60 deg. in either direction ! what would cause this ? .. no one seems like they want to touch this one..help!! :confused:
#2 Christopher Erickson
  • Loc: Waikoloa Village, Hawaii
Posted 02 February 2013 - 01:16 AM
It sounds like something as come loose inside the base.
Time to carefully remove the bottom cover and look inside and see what you can figure out.
#3 DUCE202
DUCE202
Posted 02 February 2013 - 03:26 PM
hi chris, i removed the bottom cover . i cannot actually see where or why the scope is stoping .you can only see about half of the gear wheel and a plate that turns as you rotate it.
#4 Christopher Erickson
Posted 02 February 2013 - 04:57 PM
hi chris, i removed the bottom cover. i cannot actually see where or why the scope is stopping. you can only see about half of the gear wheel and a plate that turns as you rotate it.
It sure sounds like something has come loose in the hard-stop assembly.
I believe you have a number of astronomy clubs in your area and in the greater Philadelphia area, assuming that is where you are. Hopefully one of them has a member who is experienced with the internals of your scope who can come over and look at it.
If not then there is Meade Customer Service, as well as a couple of independent individuals that work on Meade scopes.
And you might be interested in joining the LX200GPS Yahoo group, which is narrowly-focused on your model of scope.
http://tech.groups.y.../group/LX200GPS
#5 DUCE202
DUCE202
Posted 03 February 2013 - 12:04 AM
thanks for the info chris ! yes.. i`m in the greater philadelpha area...thanks again....
#6 thesubwaypusher
thesubwaypusher
  • Loc: New York City
Posted 22 February 2013 - 02:31 PM
Sounds like a software problem.
As Chris suggests, go into the yahoo site. Doc and his pals will have a solution.
Good luck, Chris
