M78 issues!!
6 replies to this topic
#1 WhitenerJ
WhitenerJ
  • Loc: Waxahachie, Texas
Posted 01 February 2013 - 11:38 PM
I took 2 hours worth of 4 minute subs of M78 tonight and stacked them together in DSS. I did a fast rough stretch in PS and I'm having an issue with rays (lines) from what seems to be bright stars off the field. The same thing happened to me when I shot my Horsehead Nebula. Something about the 3 bright stars in the belt of Orion. Even though they are not in my image they seem to cast rays or lines into the image. Take a look at the upper right corner of the image at the blue rays and also some more lines coming down from the top. What can I do to get rid of this? I'm using an Orion EON 80mm scope with a Canon T2i modded. Also using an Astro Tech FF and IDAS light pollution filter. This normally does not happen.
#2 Sean13
Sean13
  • Loc: North Platte, Nebraska
Posted 02 February 2013 - 12:21 AM
A dew shield might help keep their glare off the lens better. Same thing happens to me when I photograph without a dew shield.
#3 Lightning
Lightning
  • Loc: Canberra, Australia
Posted 02 February 2013 - 08:14 AM
Sounds like the perfect job for an empty Pringles tube.
#4 WhitenerJ
WhitenerJ
Posted 02 February 2013 - 08:39 AM
But my dew shield is extended out all the way. This does not always happen except in certain areas.
Jason
#5 WhitenerJ
WhitenerJ
Posted 02 February 2013 - 09:02 AM
BTW here is a closeup.
Jason
#6 fco_star
fco_star
  • Loc: Texas, Midland
Posted 02 February 2013 - 08:56 PM
have you try to disable the live view while you are taking the pictures?
#7 nofxrx
nofxrx
    Vendor (HyperCams & Mods)
  • Loc: Palm Bay,Florida
Posted 03 February 2013 - 11:06 PM
That is actually a very good point/question Francisco, but most times the LiveView/LCD will leave a "glow" like effect in the image, almost exactly like Amp Glow would look like..
Since these are clearly 'streaks'/rays coming from the very bright nearby stars(assuming), I would not think it is an issue with LV..but hey, anything is worth a shot. imho..
Jason, I would try a longer dew shield to see if that helps..
Or maybe it has something to do with the LP(IIRC it is pretty heavy/bad where you live..?)... :shrug:
Cheers, and good luck!
