Really nice midsized refractor
17 replies to this topic
#1 jerry10137
jerry10137
  • Loc: Texas, USA
Posted 03 February 2013 - 08:18 PM
Hey everyone, I'm looking to purchase a nice midsized refractor and wanted your thoughts on this....
http://www.astronomi...ctor-optical...
Looking for something between 80mm and 100mm that will be great for both photography and viewing. Would this be a good clear choice? Budget is 2,500 and due to mount restrictions, it really should weigh less than 10 lbs.
#2 Scott in NC
Scott in NC
    Refractor Fanatic
  • Loc: NC
Posted 03 February 2013 - 08:29 PM
How about the Stellarvue SV90T f/7 apo triplet?
#3 jerry10137
jerry10137
  • Loc: Texas, USA
Posted 03 February 2013 - 08:47 PM
That is def another option that seems to fit the bill. Thanks for the recommendation.
The TMB and SV seem to both be priced about the same.
#4 Scott Beith
Scott Beith
    SRF
  • Loc: Frederick, MD
Posted 03 February 2013 - 10:39 PM
Both will be excellent for your uses. The TMB is faster at f/5.5.
#5 Scott in NC
Scott in NC
    Refractor Fanatic
  • Loc: NC
Posted 03 February 2013 - 11:31 PM
I mentioned the SV90T because that's the only 90mm scope that I have personal experience with, but now that I've had a chance to read the specs on the TMB92, I think that looks like a really nice scope. I don't think you'd go wrong with either one.
#6 jerry10137
jerry10137
  • Loc: Texas, USA
Posted 06 February 2013 - 09:50 PM
How about a Williams Optics? How are those stacking up against these?
#7 Scott Beith
Scott Beith
    SRF
Posted 06 February 2013 - 10:13 PM
Which model from WO?
#8 jerry10137
jerry10137
  • Loc: Texas, USA
Posted 06 February 2013 - 11:07 PM
I've been eyeballing the GTF81 5 element. It comes with a field flattener built in. I believe their 98mm models are too large for what I'm going to use them for.
#9 Mike Clemens
Mike Clemens
    Frozen to Eyepiece
  • Loc: Alaska, USA
Posted 07 February 2013 - 12:52 AM
If used is an option... I've found two TMB100/8 over the years for under $2 grand. That's as good as it gets in 4".
#10 Jon Isaacs
Posted 07 February 2013 - 10:53 AM
What are the mount restrictions you refer to? What mount are you planning on using? For photography, combination focal reducer/field flatteners are available so the built in field flattener is not such a big deal.
#11 jerry10137
jerry10137
  • Loc: Texas, USA
Posted 07 February 2013 - 08:25 PM
I'm trying to stay somewhat conservative if I can. I'd like to start taking some nice photos. I purchased a used C9.25 and CI700 mount for a pretty good deal. The mount is rated at 60lbs and is in great condition. It has been well kept. What I wanted to do was view or guide thru the 9.25 and piggyback a refractor on top of it for some photos. THE OTA is 20lbs. A refractor under 10lbs will put me at the 30lb half way point that I keep reading about. Obviously, a camera and an eyepiece will add a little more weight. What I really wanted to do was throw a C11HD on it and piggyback an AT65EDQ or a lighter 80mm but have decided against that for right now. And you are right, the field flattener is not a huge deal but I will need one either way.
Right now I am considering a WO81GTF, TMB92L/SS or a SV90T Triplet. Right now the SV is winning the race for me.
#12 jerry10137
jerry10137
  • Loc: Texas, USA
Posted 07 February 2013 - 08:31 PM
Used is def an option for me. The astronomical community takes very good care of their things for the most part. However, I have not seen a used TMB100 lately.
#13 JJK
JJK
Posted 08 February 2013 - 06:30 AM
A 92 mm refractor is not mid-sized; ~ 150 mm is.
#14 Jon Isaacs
Posted 08 February 2013 - 07:08 AM
In the big picture, a 150mm scope is a small scope, maybe borderline medium, 300mm is mid-sized, 500mm large...
But refractors are a special case, I consider a midsized refractor to be around 4 inches. In any event, the original poster has already defined "mid sized" for the purposes of this thread, something under 10 lbs.
#15 turtledude1
turtledude1
  • Loc: SW Fla.& SW. NM
Posted 08 February 2013 - 02:50 PM
Both the TMB 92SS an the 92L are great scopes, what sold me on the 92SS was all the great reviews and the 3" Feather Touch focuser. I also have 5 Stellarvues so I won't say anything bad about those, just check to see if they are using florite glass. I just ordered one the first William Optics GTF 102 it will be here Monday. Well i guess I approve WO also but if I were picking a new 92 I would go with the TMB as first choice.
Russ
#16 Paco_Grande
Paco_Grande
  • Loc: Free State of Arizona
Posted 08 February 2013 - 03:38 PM
How about the new William Optics GTF102 102mm f/6.9 Apo? I almost pulled the trigger on one and then stumbled on a used WO William Optics FLT 98 Triplet and bought it instead. I like the fact that the GTF has a built-in flattener, which is not true of the FLT.
The GTF is listed at 11 lbs tube weight.
http://agenaastro.co...pe-with-flat...
#17 jerry10137
jerry10137
  • Loc: Texas, USA
Posted 12 February 2013 - 12:05 AM
Well I ordered the SV90RT from OPT this afternoon. It will serve multiple functions and I can't wait to get it.
#18 JMW
JMW
  • Loc: Nevada
Posted 12 February 2013 - 03:12 PM
You will enjoy your scope. It is a very usable size but will work well for wider views and darker skies.
JJK:
If 150mm is a mid sized refractor, than you will have to budget a lot of money for a large APO refractor. Here is my grouping of refractor sizes:
<100mm small
100-150 medium
150+ unaffordable
