Counterweights
9 replies to this topic
#1 dragonslayer1
dragonslayer1
  • Loc: SLC, UT
Posted 04 February 2013 - 08:08 PM
I found a great alternative to the $50.00 starizona counterweight if you need more as I did. I bought 2.5lb weights ( the round dumbbell ones) then had to try to find a way to fit them to the 1/2" threaded weight shaft so would be snug. Found an item in plumbing at Home Depot called "shark bite 1/2" demount clip".. Item #697285910874, put 2 into center hole of weight offset 90* apart and works great. Total cost for one is $5.00.. :jump:
#2 nytecam
nytecam
  • Loc: London UK
Posted 05 February 2013 - 04:45 AM
Shouldn't this post be in EQUIPMENT FORUM?
#3 csrlice12
csrlice12
  • Loc: Denver, CO
Posted 05 February 2013 - 08:28 AM
uh, unless somebody moved it, it IS in the equipment forum...... :question:
Always great to see sombody do a cheap workaround to an expensive item (and just why are metal plates with holes in the middle so expensive?)
#4 skywolf856
skywolf856
  • Loc: SE Michigan
Posted 05 February 2013 - 12:16 PM
I used dumb bells with a PVC pipe reducer to fit my CG5 bar.
#5 Pat at home
Pat at home
  • Loc: Campbellton, New Brunswick, Canada
Posted 05 February 2013 - 03:43 PM
I adapted mine by way of a wood insert epoxied in place then bored for the diameter of the counter-weight bar.
#6 csrlice12
csrlice12
  • Loc: Denver, CO
Posted 05 February 2013 - 04:33 PM
But will the epoxy hold in very cold temps (may not be a worry for you)......
#7 Pat at home
Pat at home
Posted 06 February 2013 - 09:42 AM
Cold is a fact of life during Canadian winters. Minus 26 degrees out right now. Good 2 part epoxy will hold up just fine. Even tough the scope is in a dynamic situation, relative to the scope itself the counterweights are static.
#8 csrlice12
csrlice12
  • Loc: Denver, CO
Posted 06 February 2013 - 10:24 AM
Sounds good, I just know from when I was in Greenland that some glues just gave up in extreme cold. Epoxy is different then glue though.
#9 cheapersleeper
cheapersleeper
  • Loc: Sachse TX
Posted 06 February 2013 - 10:54 AM
I have a few of those to supplement my real counterweight. I need them back when I work out. :lol:
Brad
#10 csrlice12
csrlice12
  • Loc: Denver, CO
Posted 06 February 2013 - 12:22 PM
Simple, just pick your scope up and down.....
