Counterweights (also posted in video forum)
1 reply to this topic
#1 dragonslayer1
dragonslayer1
  • Loc: SLC, UT
Posted 04 February 2013 - 08:19 PM
I found a great alternative to the $50.00 starizona counterweight if you need more as I did. I bought 2.5lb weights ( the round dumbbell ones) then had to try to find a way to fit them to the 1/2" threaded weight shaft so would be snug. Found an item in plumbing at Home Depot called "shark bite 1/2" demount clip".. Item #697285910874, put 2 into center hole of weight offset 90* apart and works great. Total cost for one is $5.00..
#2 MikeBOKC
MikeBOKC
  • Loc: Oklahoma City, OK
Posted 04 February 2013 - 09:07 PM
I use the dumbell weights too on top of one of the threaded $25 weights. Above them I hage a wide washer and a quarter inch nut I just tighten down to secure the whole load at whatever distance from the OTA is necessary.
