The $25 Raspberry Pi
7 replies to this topic
#1 Ira
Ira
  • Loc: Mitzpe Ramon, Israel
Posted 06 February 2013 - 04:14 PM
Ok, video hackers. Let your imaginations run riot. What can you do with this thing?
http://venturebeat.c...-camera-module/
/Ira
#2 ccs_hello
ccs_hello
Posted 06 February 2013 - 07:03 PM
It uses OmniVision OV5647 type-1/4" 5M pxl CMOS imager.
The pixel pitch is so small 1.4um*1.4um thus BSI type is selected.
It can do 5M still or various format of continuous (motion picture) read-out.
http://www.ovt.com/d...sor&sensorid=66
I would not recommend using it for astro application except for very bright objects, i.e., solar system imaging.
P.S. IMHO, not a good fit for this astro video forum.
Clear Skies!
ccs_hello
#3 mattflastro
mattflastro
    Vendor - Astrovideo Systems
  • Loc: Brevard County , FL
Posted 06 February 2013 - 09:57 PM
The old Meade LPI has a sensitivity of 3v/luxsec . This one only 0.7v/luxsec . So bad even for solar system.
#4 Ira
Ira
Posted 07 February 2013 - 07:36 PM
Too bad. So sad. :bawling:
/Ira
#5 Larry F
Larry F
  • Loc: Westchester, NY
Posted 08 February 2013 - 07:26 AM
Even if you set it up for solar imaging, it records in H.264 which Registax doesn't like, so you'd have to convert the file, which is a pain.
#6 ccs_hello
ccs_hello
Posted 08 February 2013 - 08:23 AM
That module does not pump out compressed video. The compression is done by the software within Raspberry-Pi itself.
Clear Skies!
ccs_hello
#7 benula
benula
  • Loc: Stillwater, MN
Posted 09 July 2013 - 08:34 AM
The sensor supports 2x2 binning. Could that make it a little more usable?
-Ben
#8 ccs_hello
ccs_hello
Posted 09 July 2013 - 08:40 PM
I am going back to the device datasheet and here is what I found:
- OV5647 is not using the parallel bus (DVP mode) to send digital video to Rasp Pi's main ARM CPU but instead using the high-speed serial bus (MIPI's CSI-2 interface) to send to Rasp Pi's integrated SoC GPU Broadcom VideoCore IV (same package as in the CPU ARM11 core). Omnivision image system chip requires a NDA to get the full spec.
- Rasp Pi's GPU receives the digital video then compress down to H.264 in video mode
The firmware is close-sourced.
- OV5647's DPC module seems to be only doing Defect Pixel Correction, as opposed to similar chip OV5642's image processing module (can perform simple compression as well)
- OV5647 can do 2x2 binning on the like-color pixels. Binning, oddly, is stated as voltage averaging (not using the term "summing") which happens before A/D conversion. It does not state it is summing in charge domain but already in Q -> V converted voltage values in voltage level. As a purist, charge-domain summing is better.
- However, in RaspPi wiki of the camera module, the functions of: windowed capture, binning mode, etc. are not exposed to be user controllable.
My view, I wouldn't spend time further on it.
There are more exciting image systems out there.
Clear Skies!
ccs_hello
