Are you an observing perfectionist?
42 replies to this topic
#26 Dennis_S253
Dennis_S253
  • Loc: West Central Florida
Posted 13 February 2013 - 01:21 AM
Looks off to me.
#27 GeneT
GeneT
    Ely Kid
  • Loc: South Texas
Posted 13 February 2013 - 05:55 PM
I'm hardly a perfectionist. I like the routine of checking the collimation prior to viewing. Puts me in the mood.
Me too!
#28 jeff heck
jeff heck
  • Loc: stl,mo.
Posted 13 February 2013 - 09:00 PM
Observing for me IS perfection! :gramps:
#29 kansas skies
kansas skies
  • Loc: Kansas, USA
Posted 14 February 2013 - 07:18 AM
My scopes don't tend to go out of collimation easily (refractors and cats), so I don't spend much time these days on collimation. I went through a period with each where collimation was necessary, but they've long since settled down. That being said, I'm still very aware of the effects of poor collimation, so it's always on my mind at some level. If during the course of an observing session, I see a need for collimation, I usually fight the urge and wait to see if some other factor might be the culprit (thermal equilibrium, atmospheric conditions, my eyes, etc...). More often than not, something else is responsible. If not, then I either collimate at that time, or make plans to do so in the near future.
So, to answer your question, I would have to consider myself a patient perfectionist in regards to collimation.
Bill
#30 csrlice12
csrlice12
  • Loc: Denver, CO
Posted 14 February 2013 - 10:47 AM
Uh, guilty, I'd tweek it--and why not, you've already went to the problem of checking it...the hard part's done!
#31 Madratter
Madratter
Posted 14 February 2013 - 11:00 AM
I've noticed in a lot of my hobbies there are gear hounds and people for whom the gear is just a means to the end. For a gear hound, playing with the equipment IS their enjoyment. For those to whom it is a means to the end, dealing with the gear can be rather annoying. They just want to observe/make music/take pictures/etc.
There are of course people who enjoy both aspects. I'm one of those people. But I'm probably somewhat more oriented towards the observing side of things.
Oh, and I'm with Carol on this. I'm not against the gear hounds. And I'm certainly not against the observers.
#32 Madratter
Madratter
Posted 14 February 2013 - 11:07 AM
Below is a good test of whether, for you, collimation is merely "standard operating procedure" or else whether it crosses over a bit into OCD-perfectionism. Assume you have the Catseye collimation tools, and the below picture shows the view of how your red triangle center spot appears when viewed in the Catseye Blackcat (i.e. cheshire tool). Here's the test question: Is the primary collimation shown comfortably good- enough for your tastes to consider it "done", and start observing? Or would that tiny sliver of black above the top vertex of the triangle make you itchy to continue tweaking collimation some more? "Remember, this is for posterity, so be honest" (line from "Princess Bride").
If it was after I just setup the scope, I would probably tweak it, but it would depend on my experience with my equipment if that amount of deviation actually mattered.
If I had gotten here while observing, I would be tweaking it. Because the only reason I would be checking collimation while observing was because I had noticed a difference that was big enough to effect the view.
I'm a pragmatist. If in my equipment it matters, I deal with it. Otherwise, I don't go looking for trouble.
#33 Madratter
Madratter
Posted 14 February 2013 - 11:13 AM
Let me give an illustration of the above. When I got my 20" mirror, made by a premium maker, I found the views lacking. Star tests weren't right, but more importantly, the view through the eyepiece wasn't as good as it should have been. I found a guy who could test the mirror, and I found, unsurprisingly, that it was way out of spec. I called the guys who figured the mirror and they made me a new mirror, as "good as they could make it". I got that mirror, and have had some incredible views with it. The best planetary views I have ever had were with the new mirror. I have never had it tested to find out whether it is 1/8th wave, 1/10th wave, or whatever. All I care about it the pragmatic, "it gives me great views."
#34 Tom Polakis
Tom Polakis
  • Loc: Tempe, Arizona
Posted 14 February 2013 - 12:59 PM
Regarding the slightly off orange triangle in the circle, I would proceed to look at a star at 300x. If there is no detectable flaring, then it's good enough. As others have said, it comes down to how things look through the eyepiece, and not necessarily what the test apparatus reveals.
Regarding perfectionism, I have become spoiled about tracking, and don't even want to look through my scope if the tracking fails. I'm only slightly less anal about polar alignment. If the object drifts a couple arcminutes in 15 minutes of observing it, then I inevitably start nudging the platform to correct it.
#35 coutleef
coutleef
  • Loc: Saint-Donat, Quebec, Canada
Posted 15 February 2013 - 09:33 AM
I am not sure that I would label collimatinga scopeasanattempt at perfectionism.
Exactly. Collimating a scope is standard operating procedure. Perfectionism is something else.
nice question
if i am looking for splitting double stars, planets or the moon, i will fix it. looking at DSOs, i will not loose one second and will start using the scope.
i usually use my dob below 150 x at my dark site. maybe i am plain wrong and should adjust it all the time, but i have fun with my scope so why should i overobsess with collimation???
#36 csrlice12
csrlice12
  • Loc: Denver, CO
Posted 15 February 2013 - 12:57 PM
Just me, but if I've went through the process of checking it, I'll tweek it. What's it take, another 10-15 seconds tops?
#37 Jon Isaacs
Posted 16 February 2013 - 05:58 AM
nice question
No matter what scope(s) I am using, no matter how dark or how bright the sky is, no matter how turbulent the seeing is, I will always look at the big planets, split a few doubles and catch some DSOs...
Collimation, I set the scope out before sunset. If I am traveling to a dark site, I plan on arriving before it's time to observe. I just always collimate. Just carrying a solid tube in from the yard to the house and back can mess up the collimation.
And too, some DSOs only reveal their secrets at high magnifications. Seeing the details in a small planetary nebula, that might be best done at 500x-700x depending on the size of your scope.
#38 astro_baby
astro_baby
  • Loc: United Kingdom
Posted 16 February 2013 - 07:07 AM
I ose I am a perfectionist in a lot of things. Observing I always get a good polar alignment using either the setting circles or the clock position. I take some time to get the mount level and polar aligned, balancce the scope, get a good finder to main optics alignment do a solid star alignment and then check collimation is ok on a star. Give it a tweakif needed.
Doing the set up well doesnt take very long and I can have the scope out the car and fully se up in not much more than 20 minutes working at a leisurely pace...the scope likes those 20 minutes to get to ambient amd sometimes its left with its fan running while other work is in progress.
The secret to getting it all done quickly and accurately is just practice really and being organised.........the five 'P's ......practice and preparation prevents poor performance. Some times its six 'P's as theres a rude word that can be added :)
I dont see getting it right a waste of time anymore than I'd say skipping cockpit checks in a plane is a waste of time. Its part of the order of things. I find a sort of comfort in having a process which calms me prior to observing so that I am properly receptive to the view later on. The scope needs to cool down and I need to calm down.
A quick star test takes not much time and a collimation tweak is not a lot of effort once your familiar with the process.
Once up and running I change EPs to get the best view to my eyes for any given object. For instance I might star Orion on a 30mm widefield and have a look and then change up to say a 14mm and go in a bit and then maybe change to a 5mm for close up views and maybe back off to 9mm if the sky wont supprt the 5mm. With each view I will spend a bit of time looking around at the long view or slowly cruising the scope along te edies of the nebula at higher magnification.
The perfectionism is jus t make sure I get the best view, the colimation process gives me assurance the scope is operating at optimum and the good polar alignment means I am not constantly distratcted by having to 'bump' the scope. When your communing with the infinite ( which is how I tend to think of observing ) you dont want to be constantly having to mess about....it would be a bit like sitting in a theater where other patrons are constantly asking you to move so they can buy some more popcorn :)
Maybe that makes me a perfectionist observer..I dont know.
#39 Ed D
Ed D
  • Loc: Sunny South Florida
Posted 16 February 2013 - 07:36 AM
Almost all of my observing is done with my 6" f/8. After several years of using the same scope I know all its little quirks, and also know it stays adjusted really well. If I feel it may not be up to par a simple star test and/or visual check is easy enough. Most of the time it's the conditions, not the scope.
Ed D
#40 coutleef
coutleef
Posted 16 February 2013 - 09:24 AM
nice question
Unfortunately at my dark site in the mountains, seeing is almost always below average, going beyond 150x is rare. But transparency can be very good and LP is at a minimum.
In the city seeing is often excellent, so i obsess over collimation. But my sct keeps very well collimation which i have not tweeked for two years
#41 northernontario
northernontario
  • Loc: Porcupine, Ontario Canada
Posted 16 February 2013 - 12:14 PM
A dob is like a guitar...you gotta tune it.
jake
#42 GeneT
GeneT
    Ely Kid
  • Loc: South Texas
Posted 16 February 2013 - 08:40 PM
You are close to achieving good collimation--I say tweak it up and get it dead on. It only takes a few more seconds to do so.
#43 GeneT
GeneT
    Ely Kid
  • Loc: South Texas
Posted 16 February 2013 - 08:42 PM
Our time is our own, and what we do with it is simply a matter of personal choice.
Well said!
