Nebulosity fine focus?
2 replies to this topic
#1 WhitenerJ
WhitenerJ
  • Loc: Waxahachie, Texas
Posted 12 February 2013 - 09:43 PM
Ok what numbers should I be aiming for when fine focusing in Nebulosity? Like the Max and HFR? Also what do you look for on the graphs?
Jason
#2 Mike7Mak
Mike7Mak
  • Loc: New York
Posted 12 February 2013 - 10:08 PM
I've never been able to make sense of the graph. The actual numbers depend on the image scale but you want the HFR as low as possible and Max as high as possible. Nights with poor seeing can make fine focus a pain to use. I used it for a long time but it always left a nagging doubt as to whether I actually got the lowest HFR possible. A lot of time was spent going in and out of focus trying to minimise HFR.
I've since gone to a Bahtinov mask. There's no comparison. The mask leaves no doubt about when you've reached proper focus.
#3 Charlie B
Charlie B
  • Loc: Sterling, Virginia
Posted 13 February 2013 - 07:47 AM
I use both the Bahtinov mask and Nebulosity's fine focus. The mask gets you on when you have a bright star, but when doing Ha or OIII imaging, and switching filters, I need Nebulosity's fine focus to get the best focus. In good seeing, The FWHM is less than 2 pixels, usually 1.6-1.8 with my 800 mm fl and in bad seeing can be greater than 3.
Charlie B
