Sky watcher NEQ6 GT AZ polar scope led brightness
2 replies to this topic
#1 elbert
elbert
  • Loc: Limburg, Netherlands
Posted 14 February 2013 - 02:16 PM
Overall I'm very pleased with my new mount. It's very stable Goto and autoguiding Work wel, periodic error seems small. There is ons problem: the led in the polar scope is way too bright. According to the synscan manual there should be an option 'polar scope led' in the utility functie. Menu. When I look for this it simply isn't there (I'm using firmware version 3.31). Anyone have a similar experience / solution?
Renards, Elbert
#2 hectar
hectar
  • Loc: Ontario, Canada
Posted 19 February 2013 - 11:04 PM
Did you try yahoo's EQMOD and EQ6 groups?. Apparently it could be done with older firmware (3.24?) or with some small patch to synscan..
#3 rigel123
rigel123
  • Loc: SW Ohio
Posted 20 February 2013 - 10:20 PM
Check the Setup menu rather than Utilities. See if there is a choice for Handset Settings. There you should find the choice for dimming the PA Scope LED
