Friday's Pop Quiz
6 replies to this topic
#1 Douglas729
Douglas729
  • Loc: Clarksville Mo.
Posted 15 February 2013 - 11:32 PM
The Aperture-holics Anonymous Pop Quiz
1. What is the 0.82x rule as pertains to binoviewer magnification by Sir Thomas of Denmark?
2. Describe the 0.88x plossl rule of forum mathematician EdZ.
3. What is the 1.25x rule regarding binoviewers and eyepieces?
4. Describe the relationship between an fstop and a binoviewer ca?
5. Have you ever had more fun in the dark with your clothes on?
DG
Damaged Goods
#2 EdZ
EdZ
    Professor EdZ
  • Loc: Cumberland, R I , USA42N71.4W
Posted 16 February 2013 - 07:37 AM
Ummm, never heard of it
edz
#3 Douglas729
Douglas729
Posted 16 February 2013 - 12:14 PM
Excuse me EdZ, then from whom did I learn that a 30mm Plossl x's 0.88 will reveal a field stop of 26.4mm?
do you concur?
#4 EdZ
EdZ
    Professor EdZ
Posted 16 February 2013 - 12:50 PM
do you concur?
ahh, is that what you're referring to. Didn't recognize that as some factor. OK, I suppose that could be used as a rough number. That would give a 50° Afov.
But not all plossls have the same size field stop. Plossl eyepieces have field stops that range from 46° to 53°.
#5 GlennLeDrew
GlennLeDrew
Posted 16 February 2013 - 03:48 PM
I'll take a stab at #4. The clear aperture at the front end, in conjunction with the optical path length from there to the focus, determines the fastest f/ratio which can be accommodated before aperture reduction occurs.
#6 junomike
junomike
  • Loc: Ontario
Posted 16 February 2013 - 07:04 PM
#3 is easy. An eyepiece will appear to have a magnification factor of 1.25X It's given Focal Length when used in conjunction with a Binoviewer and SCT/MCT.
This is only approximate an varies depending on 1) the optical length of the Binoviewer, 2) the Telescope being used, and the optical length of attachments used to connect 1 and 2.
#7 Douglas729
Douglas729
Posted 16 February 2013 - 10:04 PM
Glenn and Mike-
Both answers are absolutely correct and very well defined in our native tongue, thank you.
My reason for creating this test is simply that I have learned to configure binoviewers with a pair of eyepieces properly can become a complicated process of trial and error. I refer to eddgie as a prime example.
