Alt/Az Mount Heads
41 replies to this topic
#26 ASTERON
ASTERON
  • Loc: ISRAEL
Posted 21 February 2013 - 09:54 AM
Chucky,
Very nice setup ! what is the OTA on the tripod?
I like very much the little red filter on the sky commander ! Is it home made or commercially available?
If I read you correctly you just use the sky salary as a star map?
Or do you have a way to control the sky commander directly from the miniipad ??
AFAIK the iPad does not have any socket which allows it to connect to another computer or device.
#27 Chucky
Chucky
  • Loc: Dublin, Ohio
Posted 21 February 2013 - 01:48 PM
Shown in my photo is a Stellarvue 80ED. Yes, Sky Safari is used as my star chart. Sky Commander sends the alt/az positions wirelessly via SkyFi to my Ipad Pad. Pretty simple and straight forward. The Sky Commander has a Starmaster plastic dew guard which I then installed a red plastic filter sheet.
#28 mogur
mogur
  • Loc: WI
Posted 21 February 2013 - 08:03 PM
How about a AYOtraveler from AOK Swiss?
http://www.aokswiss....yotraveler.html
regards
Chris
Wow! This looks like exactly what I'm after. Wish I could read Swiss. :(
I got one of these for my Solarmax 60 :). Nice and light weight but no slow mo
http://stargazerslou...ss-ayotraveler/
Bummer. When I saw the two knobs on it I wrongly assumed they were slo-mo knobs. I guess they're just locking knobs? This is rather frustrating. Why can't someone make a mount sort of like THIS but about twice as big with a beefier 3/8" tap on the bottom? I think it would sell like hotcakes if it could be kept around $100.
#29 Kfrank
Kfrank
  • Loc: Northern Colorado
Posted 22 February 2013 - 11:53 AM
regards
Chris
It probably would sell like hotcakes at that price point, however, making a profit on it would be another matter.
#30 Mark9473
Mark9473
  • Loc: 51°N 4°E
Posted 22 February 2013 - 01:59 PM
I don't know about the price point, but have you looked at the Manfrotto geared tripod heads?
#31 Midnight Dan
Midnight Dan
  • Loc: Hilton, NY, Yellow Zone (Bortle 4.5)
Posted 22 February 2013 - 02:00 PM
I own one of those. It's only good for a VERY small or lightweight scope (think ST80, tops) and even then only at low magnifications. The build quality is marginal, and the only real reason I still have it is because it can come in handy if I want to throw it and some very minimal gear into a backpack for a hike.
To make something like this bigger and beefier (and able to handle larger scopes) means ending up with something very similar to one of the current offerings mentioned by folks above - and definitely not for $100. Unfortunately, if you want something useable, with quality build and performance, it will cost you.
I would question whether you really need the slow motion controls. I was very attached to the slo-mo controls myself but took the plunge and went with the Desert Sky DSV-1, which doesn't have them. While I still like slo-mo's, I have to admit that this mount makes them pretty much unnecessary up to about 170x. The mount is extremely well made with very smooth action and it's just as easy to simply move the scope to keep up with the target.
Contrary to Kieth's experience above, I've found this mount to be very stable and focusing is easy even at higher mags. I'm not sure what scope he was using or what tripod the mount was on, but those might have been contributing factors to the problems he was having. I'm using it with a WO Megrez 90 on a "shorty" contractor's tripod.
In any case, with the scopes listed in your sig line (other than the Lightbridge which, I assume, you're not putting on this mount! :grin:) I would think a DSV-1 would be more than adequate for your needs. And for a few bucks more, you can get it with dual saddles and mount 2 of your OTAs at the same time.
-Dan
#32 Ebbisham
Ebbisham
  • Loc: Surrey, Uk
Posted 22 February 2013 - 04:59 PM
To be fair to the AyoTraveller if is indeed a extreme lightweight (and IMHO well made) mount intended for small scopes. My SM 60 with binoviewer is the most I would throw at it.
But you are right, make the 2 disks solid aluminium and we are close to a well loved and pricier mount.
#33 Kfrank
Kfrank
Posted 22 February 2013 - 05:49 PM
"I would question whether you really need the slow motion controls. I was very attached to the slo-mo controls myself but took the plunge and went with the Desert Sky DSV-1, which doesn't have them. While I still like slo-mo's, I have to admit that this mount makes them pretty much unnecessary up to about 170x. The mount is extremely well made with very smooth action and it's just as easy to simply move the scope to keep up with the target."
Slow motion controls may not be "needed" but, IMO, they add immensly to the convenience and ease of use. This is particularly true when the OTA being used is a short one, resulting in a short moment arm.
After starting out with a mount with no slo-mo, I upgraded to an MG2 and would never go back.
There are a number of things to be considered when selecting a mount, such as stability, carrying capacity, smoothness and ease of use.
One of the MAJOR advantages of slo-mo controls are that when the heads are locked in the slo-mo mode, the scope remains where it was when eyepieces are changed and minor EP changes, adding barlows, etc, cause much less problems.
Sow motion controls may not be "needed" but they sure make for more convenience and easy operation. I wouldn't be without them.
#34 mogur
mogur
  • Loc: WI
Posted 22 February 2013 - 06:00 PM
Those do look really nice, but a bit pricey for something I would only use when traveling. I have a Vixen Mini-Porta that does me good at home! There's a used one in the CN classifieds for about $100 off. Hmmmmm... BTW, this would only be used for the Onyx and the SolarMax 60.
#35 mogur
mogur
  • Loc: WI
Posted 23 February 2013 - 12:14 PM
regards
Chris
Well, this one is less and comes with a tripod!
http://www.optcorp.c...px?pid=277-6536
Only reason I haven't bought it is I can't get a straight answer as to how it attaches to the tripod. :(
#36 Agatha
Agatha
  • Loc: Coulee Region, Wisconsin
Posted 23 February 2013 - 03:36 PM
Mogur,
I don't think I can recommend the Celestron mount/tripod that you are wondering about. I have one that I got for binoculars and haven't used it yet. The terminology in the description is idiotic..."heavy duty" :lol:
It might be useable for certain things if you are willing to perhaps do some mods (ie; scopestuff stuff). I do not like the very short thread bolt to attach something to...the 1/4-20 bolt, which is I believe the standard camera thread. Of course that can certainly be dealt with. I will try to attach some photos of the attachment method to tripod. I am terrible with photography and computers. So here we go...I am in learning mode with computer stuff...this first photo is of the top of the mount.
#37 Agatha
Agatha
Posted 23 February 2013 - 03:43 PM
The next photo is of the bottom of the mount.
#38 Agatha
Agatha
Posted 23 February 2013 - 03:44 PM
This is the top of the tripod.
#39 Agatha
Agatha
Posted 23 February 2013 - 03:49 PM
And this is the bottom of the mount. The shoulder section measures about 25mm in diameter and is about 23mm depth to surface of tripod. The thread size is 10mm.
Best, Linda B.
#40 Agatha
Agatha
Posted 23 February 2013 - 03:50 PM
Oops,
here is the photo
Best, Linda B.
#41 mogur
mogur
  • Loc: WI
Posted 23 February 2013 - 05:16 PM
Agatha, you are an angel! Now I know this mount would not work for me. I need a 3/8" hole in the bottom, not a stud like your photos show. Thanx very much!
#42 HfxObserver
HfxObserver
  • Loc: Canada
Posted 23 February 2013 - 06:12 PM
Takahashi Lapides, get one don't look back, buy it used for cheap, immediately order some alu. slo mo knobs from Bob and throw out the plastic ones that come std. on the Tak Lap.
I don't know why people still use those spaghetti noodle slo-moes.
-Chris
