Building an observatory, links of interest.
74 replies to this topic
#51 DOM1950
DOM1950
  • Loc: quebec canada
Posted 13 June 2008 - 10:04 PM
GOOD NEIGHT TO YOU IT IS POSSIBLE TO HAVE YOUR OBSERVATORIES PLANS IN THE PDF FORMAT
DOMINIQUE MONGRAIN QUEBEC CANADA DSNC@XITTEL.CA
#52 GrampianStars
GrampianStars
  • Loc: Grampians, Australia
Posted 18 June 2008 - 10:23 PM
Hello Tom
:jump: absolutely sensational. Has got my building fetish going again.
Though I will only be building a 5 metre version
Congrats :bow:
#53 John Fitzgerald
John Fitzgerald
    In Focus
  • Loc: AR ..on the minus side of +36 deg
Posted 24 July 2008 - 10:07 PM
"Headwater Observatory" in this forum.HW Obs link
#54 kiwisailor
kiwisailor
  • Loc: Lyttelton, New Zealand
Posted 07 August 2008 - 04:16 AM
Vintage dome how-to, Yoke mounted Reflector moves with rotation of dome Observatory Plans Click on how to build an observatory to view the plan
Steve
#55 kiwisailor
kiwisailor
Posted 09 August 2008 - 02:04 AM
Brayebrook Observatory Main Page
Brayebrook Home Page
This publication on the Brayebrook site might be of interest:
Designing & Constructing a Domed Astronomical Observatory
PDF here
Being a detailed description of the design and construction methods of an aluminium alloy domed observatory intended for a large amateur equatorial telescope.
#56 StarWrangler
StarWrangler
  • Loc: Three Rivers, MI U.S.A>
Posted 05 January 2009 - 04:00 PM
You can check put my Yahoo Observatory group,
their are a lot of links their,
Alan
#57 kiwisailor
kiwisailor
Posted 01 March 2009 - 04:57 AM
The Design And Construction Of A Small Observatory-J.Ernest.G.Yalden
Interesting "how to" of yesteryear to be found here Scroll down the first page to to the button "send PDF" under the printing options header if you want to save the complete paper.
Steve
#58 BigBadBrain
BigBadBrain
  • Loc: Kent, Washington
Posted 01 March 2009 - 12:55 PM
I believe you may have found the way I can get around the covenants police! Disguise the dome as a gazebo! With the finial on top it hardly looks like an observatory. Make it out of the right stuff and it could be quite striking.
#59 kiwisailor
kiwisailor
Posted 02 March 2009 - 03:28 AM
Hi Brian
If that's the route you want to try, have a look at Building a small gazebo observatory this is the one that is in
Small Astronomical Observatories; Patrick Moore [editor]; Springer-Verlag 1996; chpt. 6 - ISBN 3-540-19913-6
Good luck with defeating the HOA nazis :grin:
Steve
#60 BigBadBrain
BigBadBrain
Posted 02 March 2009 - 12:27 PM
Thanks Steve. I like the dome but the gazebo probably has a greater chance of passing the architectural committee. I may start with the dome and if they reject it try the gazebo.
#61 RonM-1
RonM-1
Posted 02 June 2009 - 03:28 PM
The new URL for the Flint Hill Observatory is:
http://www.wcc.net/~...tory/index.html
Ron
#62 Restricted
Restricted
Posted 17 November 2009 - 09:43 PM
Some good information and issues to think about.
http://www.dfmengine...ory_design.html
#63 TexomaAU.Obs.
TexomaAU.Obs.
    Member
  • Loc: Texas, USA
Posted 30 March 2010 - 12:49 AM
WOW JT, I just looked at you online pic of your set up.. You have got it going,,, I am in awe of your observatory! I bow to your work, GREAT JOB! I am in the process of setting up here in Texas and build dome kits. I am making a few jigs to make tubing radials and sheet metal patterns for cutouts for the dome roofing. hope to be done setting up by year end!
#64 totolesbaloches
totolesbaloches
  • Loc: France
Posted 01 August 2010 - 05:40 PM
pic of my project
http://www.felopaul....onstruction.htm
#65 kiwisailor
kiwisailor
Posted 08 August 2010 - 03:17 PM
Interesting pier construction article from Frame Building News here
#66 TexomaAU.Obs.
TexomaAU.Obs.
    Member
  • Loc: Texas, USA
Posted 13 August 2010 - 10:47 AM
Perfect! Awesome monolithic design, great detail!
#67 csa/montana
csa/montana
    Den Mama
  • Loc: montana
Posted 04 September 2010 - 09:52 AM
Excellent thread on heat prevention in observatories:
Heat Prevention in Observatories Test
#68 csa/montana
csa/montana
    Den Mama
  • Loc: montana
Posted 04 September 2010 - 10:18 AM
I have gone thru this thread & edited out links that no longer work, & off topic posts. This should make it a little easier to navigate the thread. :)
#69 bloodhound31
bloodhound31
  • Loc: Canberra, Australia
Posted 16 November 2014 - 07:52 AM
My observatory in post #36 is now dead. It has been replaced with an observatory twice the size now with a new site documenting it's build.
http://asignobservatoryii.com/
#70 seryddwr
seryddwr
    Innocent Bystander
  • Loc: La-la land.
Posted 17 November 2014 - 01:46 PM
I love your observatory. The workmanship is of the highest quality. :waytogo:
#71 DougSol
DougSol
  • Loc: San Diego, CA, US
Posted 23 February 2015 - 11:33 PM
Our website, curiositypeak.us, has a slide show showing the stages of construction. Our
roll-off is very different from most. If you're interested in knowing more about it email or call us. Doug Sollosy
#72 DougSol
DougSol
Posted 28 March 2015 - 09:03 AM
We finished building our 12x14ft. roll-off roof observatory last spring. It might be of
interest to people because of its somewhat unconventional roof design. Instead of using a
conventional heavy lumber frame, we put together trusses, using square aluminum tubing, held together by homemade aluminum gussets and pop rivets. Its covered by 3 foot sections of corrugated galvanized steel sheets. It rolls smoothly on just 4 4" castors. Because of the relatively light weight of the roof the wall construction is 2x4, rather than much more
expensive 2x6, making it overall a lot more economical. Total cost of the structure was
under $3000.00. To see a slide show of the construction and a video of the observatory being
opened, go to our website at curiositypeak.us. For any questions about its construction our email address is curiositypeak@gmail.com Yes, it was a bit of work, but definitely a labor
of love.
#73 Pistons and Wings
Pistons and Wings
Posted 20 September 2016 - 01:54 PM
Thanks for the info!
#74 Pistons and Wings
Pistons and Wings
Posted 27 September 2016 - 11:53 AM
Post pictures. I should build something.
#75 Dragon Man
Dragon Man
  • Loc: Snake Valley, Australia
Posted 10 October 2016 - 10:40 AM
Our 'Snake Valley Observatory' is a 'Roll-Away' instead of a 'Roll-off-Roof' type, completely built by Club volunteers   :waytogo:
This is a Photographic Journal of the total 6 month construction from start to finish   :)
http://snakevalleyob...nstruction.html
