Good, classic, reliable, EQ mount
20 replies to this topic
#1 Ira
Ira
  • Loc: Mitzpe Ramon, Israel
Posted 27 February 2013 - 08:29 PM
It seems like everyone wants the latest and greatest, cutting edge mount, many of which have teething problems or cost a fortune or weigh a ton or something else is an issue. Is there a good, reliable classical EQ mount for mainly visual use, time proven, spare parts abound, or is this just as rare as a unicorn?
/Ira
#2 orlyandico
orlyandico
  • Loc: Singapore
Posted 27 February 2013 - 08:47 PM
G11 non GoTo.
Atlas / EQ6 non GoTo.
#3 gonzosc1
gonzosc1
  • Loc: South Carolina
Posted 27 February 2013 - 08:48 PM
I believe theres an Atlas non goto on ebay now!
#4 mdowns
mdowns
  • Loc: Englewood,FL
Posted 27 February 2013 - 09:00 PM
I second orlyandico comments.The non goto versions of the losmandy g8s and g11 are solid,reliable performers.Replacement parts are readily available.The g11 that carries my c11 is sweet!Several years earlier I had a g8,again sweet.Just power it up and track.
#5 frozen.kryo
frozen.kryo
  • Loc: East of the Sun, West of the Moon
Posted 27 February 2013 - 09:46 PM
Good, classic, reliable?
The Vixen GP/GPDX springs to mind.
#6 comets4tom
comets4tom
  • Loc: Texas
Posted 27 February 2013 - 09:56 PM
I agree with the mention of the GP/GPDX. Parts should be available since it is still currently sold.
Tom H.
#7 JMW
JMW
  • Loc: Nevada
Posted 28 February 2013 - 12:40 AM
I think you can find an used Atlas for well under $900. They are a nice step up from the CG-5 and can be used for imaging also.
#8 RogerRZ
RogerRZ
    Whatta you lookin' at?
  • Loc: West Collette, NB, Canada
Posted 28 February 2013 - 07:44 AM
How much of a pain would an older G11 be for imaging at or less than 1200mm fl? I have an EQ6 pro that kind of works, but has a PE curve about a mile wide (20 seconds max unguided with a 200mm lens).
#9 t.r.
t.r.
  • Loc: 1123,6536,5321
Posted 28 February 2013 - 07:51 AM
Yep, Vixen Super Polaris/Great Polaris/Deluxe are the workhorse mounts! :bow:
#10 orlyandico
orlyandico
  • Loc: Singapore
Posted 28 February 2013 - 10:08 AM
Roger,
I'm pretty sure an old G11 can manage much better than 20 seconds unguided with a 200mm lens!!
But a much cheaper option, although not as appealing, is to simply buy an Aeroquest worm for the Atlas/EQ6. It's only a little over a hundred bucks. You will get a worm that is at least 15" p-p and probably better. That's about what you'd get with an old G11. My Aeroquest worm (on my CGEM) is about 16" p-p.
However.. if your PE is that big (sounds like hundreds of arc-seconds), it might not be in the worm, but could be some non-concentric bearings or something. Ed Thomas would be in a better position to know if this is possible or not.
#11 RogerRZ
RogerRZ
Posted 28 February 2013 - 10:34 AM
I bought it brand new, and it's been like this from day one. I suppose I could have returned it, but I didn't really care for the hassle. As big as the PE is, it seems to be quite smooth, as it autoguides out quite well, up to 1000-ish mm...
#12 Tom and Beth
Tom and Beth
  • Loc: Tucson, AZ
Posted 28 February 2013 - 04:58 PM
/Ira
How about Cave with the 1.5 inch shafts? Further up the chain would be G11, and don't forget about the Push To Astro Physics. I put hundreds of hours annually on my circa 1994 AP1200DA. Can still get service with a phone call, replacement parts in a week or so.
For grab-n-go, the Vixen SP and GP
#13 Geo.
Geo.
  • Loc: Upstate NY
Posted 28 February 2013 - 07:01 PM
Yes, many parts for the Vixen GP can be obtained from one of the U.S. Vixen distributors. When Orion was a dealer they kept a lot of spares. I got a large flat rate box of 'em off eBazy. Need any motor covers :question: One thing I'm hanging onto are those spreader hinge pins!
#14 coopman
coopman
  • Loc: South Louisiana
Posted 01 March 2013 - 08:47 AM
I would not buy a used Orion mount due to the fact that if you ever need parts, they will not sell them to you.
#15 rmollise
Posted 01 March 2013 - 10:01 AM
Well, that's true to some extent. Orion doesn't make a single mount...and parts for the mounts they sell are generally available from other sources.
#16 NealC
NealC
Posted 09 March 2013 - 05:15 PM
Please do tell identities of these sources. :jump:
#17 rmollise
Posted 09 March 2013 - 06:33 PM
SkyWatcher is one. ;)
#18 Hikari
Hikari
  • Loc: Maine, USA
Posted 10 March 2013 - 12:55 AM
Takahashi EM2S. Only a RA motor and manual dec. Built like a tank.
#19 rzep8
rzep8
  • Loc: Flemington, NJ
Posted 10 March 2013 - 08:10 PM
I don't know about spare parts (as the thing has never broken), but my Byers 812 is probably the best "push-to" mount around. Solid, transportable (but it ain't light) and reliable. Uses 120VAC synchronus motors so you'll need a frequency chopper drive corrector (an old Accutrak still show up on A-mart now and then). A good one costs about $2K or so.
#20 orion61
orion61
  • Loc: Birthplace James T Kirk
Posted 11 March 2013 - 09:51 AM
+1 on the SP/GP :waytogo:
#21 hottr6
hottr6
  • Loc: 7,257', Magdalena Mtns, NM
Posted 11 March 2013 - 10:25 AM
OP never stated payload.... I guess everyone here are better mindreaders than I.
As an owner, I have had experience with the following for visual work:
- Byers or Schaeffer for heavy payloads > 40lbs
- Losmandy G8/G11 for middle-weight payloads 14-35 lbs
- Vixen Polaris for light stuff < 12 lbs.
Shane in gray-zone NM
