Comprehensive list of "Do Not Disassemble" eps
23 replies to this topic
#1 Darren Drake
Darren Drake
  • Loc: Chicagoland
Posted 28 February 2013 - 04:10 PM
After the most recent incident with the 24mm Status I would like to see someone put together a list of all the eyepieces that WILL fall totally apart if disassembled. That is they have no protective retaining rings at all to prevent certain disaster. I know I could have used this info when I once unscrewed a TV 55mm Plossl. Can anyone help on this??
#2 Scott in NC
Scott in NC
    Refractor Fanatic
  • Loc: NC
Posted 28 February 2013 - 04:43 PM
I'm pretty sure that all of the Televue Wide Fields and Panoptics fall into this category, but don't know any others off the top of my head.
#3 hfjacinto
hfjacinto
    I think he's got it!
  • Loc: Land of clouds and LP
Posted 28 February 2013 - 04:47 PM
I myself won't disassemble any EP. Well maybe a ball EP I will take apart. :)
#4 csrlice12
csrlice12
  • Loc: Denver, CO
Posted 28 February 2013 - 07:56 PM
Yup, that's what they make factory reps and scope stores for.....
#5 NeilMac
NeilMac
  • Loc: MedHat, AB, Canada
Posted 28 February 2013 - 10:54 PM
Why would you, are they loose enough for dust to go in?
I unscrew the silver base so I can get a brush to the under glass, thats it.
#6 Jaimo!
Jaimo!
  • Loc: Exit 135 / 40° North
Posted 28 February 2013 - 11:25 PM
You have to see what's inside...?
Jaimo!
Ugh! I'm going to have to re-shoot the UO photo, it's terrible...
#7 Jon Isaacs
Posted 01 March 2013 - 09:33 AM
The 24mm TV Widefield does not have a retaining ring, the 15mm does. My 32mm probably does not but it is too tight to get apart.
Given the history of their design, it should be no surprise that the 24mm Meade Series 5000 SWA does not have a retaining ring but the 16mm does.
#8 csrlice12
csrlice12
  • Loc: Denver, CO
Posted 01 March 2013 - 09:47 AM
Unscew the old T1s and it's glass puzzle time.....
#9 Traveler
Traveler
  • Loc: The Netherlands
Posted 01 March 2013 - 10:04 AM
Don't disassemble a Baader Hyperion Clickstop Zoom Mark II or Mark III...
#10 csrlice12
csrlice12
  • Loc: Denver, CO
Posted 01 March 2013 - 10:22 AM
Easier Listing of eyepieces you shouldn't disassemble:
1. All
#11 Scott in NC
Scott in NC
    Refractor Fanatic
  • Loc: NC
Posted 01 March 2013 - 10:27 AM
1. All
I like that one! :lol:
#12 hfjacinto
hfjacinto
Posted 01 March 2013 - 10:29 AM
1. All
+1
#13 FirstSight
FirstSight
    Duke of Deneb
  • Loc: Raleigh, NC
Posted 01 March 2013 - 11:45 AM
The Nagler T5s and T6s CAN be safely unscrewed in half at their "waist" (both upper and lower lens assemblies are firmly held in place by retaining rings). Beyond that, you may be heading into dense briar-choked weeds trying to disassemble them further.
The ONLY reason to consider unscrewing a T5 or T6 Nagler at its waist is if condensation gets trapped and persists on either the lower lens surface of the top half or the upper lens surface of the bottom half. The main risk you take exposing these surfaces is inadvertent introduction of dust, in which case...um, you have to open it again to clean it out.
It *might* be possible to similarly do this with the T4s, but I've never tried it, and I simply have no idea whether such is also possible with the Ethos. However, prudence wins out handily over curiosity in both cases, and I have no intention to consider any experiments to find out, absent some truly compelling reason (and in the case of Ethos, would probably bite the bullet to send it to Televue and pay the cleaning service fee).
#14 Darren Drake
Darren Drake
  • Loc: Chicagoland
Posted 01 March 2013 - 12:03 PM
There is a simple way to know if you're about to get into trouble if you start unscrewing an eyepiece. If after a bit of initial unscrewing you shake the eyepiece and hear some internal rattleing going on that's your big clue to stop and retighten or continue at your own risk as there are almost certainly no retaining rings in place to avoid possible disaster.
#15 csrlice12
csrlice12
  • Loc: Denver, CO
Posted 01 March 2013 - 01:08 PM
Having the lenses fall into you lap is a really good indication you unscrewed it too far........appears we can easily add the Orion Stratus to the list.....
#16 Starman81
Starman81
  • Loc: Metro Detroit, MI, USA
Posted 01 March 2013 - 03:35 PM
TV Plossl 32mm as well. Lenses did fall out but no damage and it was easy to put back together and an educational experience. I do take it apart to clean it when internal dust accumulates though...
#17 FirstSight
FirstSight
    Duke of Deneb
  • Loc: Raleigh, NC
Posted 01 March 2013 - 08:29 PM
One problem with disassembling the internal lenses in an eyepiece is that in additon to the one correct order and orientation of lenses, there are often several other ways to assemble the lenses together which also produce a plausibly acceptable image on-axis, but only indicate the likely incorrectness of ordering by the inferior performance of the outer half of the radius. I once owned a Meade 5000 series-60 6.5mm eyepiece which, during attempted cleaning of the eyelens, I inadvertently got water underneath the eyelens and decided to disassemble it to clear out the moisture. Upon unscrewing the field stop, the lenses tumbled out into a random jumble upon a towel I had placed under it before I had any chance to remove them in a controlled, graceful in-order fashion; fortunately none of the lenses got scratched. However, it was like putting a Chinese puzzle back together; I spent hours trying different permutations and looking at diagrams of various lens designs related to the Plossl family until finally I hit upon the unquestionably right one. That once was enough adventure into eyepiece disassembly for me to last a lifetime, except for the fact that T5 and T6 Naglers can be unscrewed neatly into two parts without otherwise undoing any of the internal lens assemblies.
#18 George N
George N
  • Loc: Binghamton & Indian Lake NY
Posted 03 March 2013 - 08:20 PM
1. All
Last year (2012) at NEAF I had a discussion with Don Yeier of VERNONscope. He said that proper assembly is very important for the performance of an eyepiece. He assembles each Brandon himself for that very reason. He said that only his son can do it as well as he can.
I have an old 16mm Nagler T2 that sometimes has its internal field stop un-screw. The first time it happened David Nagler talked me thru taking the thing apart over the phone and screwing the little ring back in place. I had to do it myself in the field one additional time.
#19 astro_baby
astro_baby
  • Loc: United Kingdom
Posted 04 March 2013 - 02:43 AM
The biggest problem I found, and ai only did it once on the rear lens assembly of a TAL finder is keeping everything clean. When your messing with tiny bits of glass, spacers, and in this case a reticule, even working on a clean surface with cotton gloves on and so forth ai had to do it about a zillion times before I was happy as there always seemed to be one more speck of grot inside the assembly.
Theres no way I'd risk it with an EP anymore than I would take a camera lens to bits.
#20 smallscopefanLeo
smallscopefanLeo
Posted 04 March 2013 - 03:05 AM
The only one I inadvertently attempted was my Surplus Shed 28mm RKE (as it spilled its guts into my lap a mere moment after I unscrewed the nose piece!) and while that is supposedly one of the simplest of multi-element eyepieces to dissect based on opinions I read here, it still had me scratching my head for a bit, and visiting our forum for photos that would soon help me make sure that I got the orientation right while gingerly putting it back together (all two groups of it, AND the middle spacer ring :grin:)! :thanx:
It being surplus and slightly rough/imperfect to begin with, and the elements tumbling mere inches into velvety pliant clothing and lap (seems to be a common disassembly method here :roflmao:), the reassembled end result came out looking unchanged to my eye .. which I was relieved about!:sweat:
#21 iluxo
iluxo
Posted 04 March 2013 - 05:20 AM
ALL eyepieces you value. If you really must find out, dismantle some old ones you don't really care about.
Eyepieces less than 12mm focal length involve critically accurate assembly; if you dismantle and reassemble them they never work as well again.
#22 csrlice12
csrlice12
  • Loc: Denver, CO
Posted 04 March 2013 - 08:37 AM
"If you really must find out, dismantle some old ones you don't really care about."
and if you REALLY want to find out....dismantle OPs.....
#23 Jobryant
Jobryant
Posted 04 March 2013 - 10:09 AM
Any and all of the nitrogen purged Explore Scientifics would be at the top of my list.
#24 Thomas Karpf
Thomas Karpf
  • Loc: Newington, CT
Posted 04 March 2013 - 03:03 PM
The only eyepieces on my 'Do Not Disassemble' list are ones that I didn't find at the dump :).
