My Dome Observatory - Construction Log
30 replies to this topic
#1 Canada_LX10
Canada_LX10
  • Loc: Portage la Prairie, Manitoba, Canada
Posted 28 February 2013 - 09:21 PM
EDITED: I put up single pics on each post. Not sure why they don't allow multiple photos in one posting.
This picture is using my radius drawing jig to make the template in the 1/8" Masonite board.
#2 astrodog73
astrodog73
  • Loc: Australia
Posted 28 February 2013 - 11:07 PM
You can upload pics, most threads in this forum especially, are brimming with pics....
People will need to actually sign up to that other forum to see the pics anyway....
#3 Midnight Dan
Midnight Dan
  • Loc: Hilton, NY, Yellow Zone (Bortle 4.5)
Posted 01 March 2013 - 07:13 AM
There are two ways to include pics. One is to simply add the picture to the post using the button that's available when posting. However, that limits you to one picture per post.
To include multiple pictures per post, you can use any of the standard image hosting services like Photobucket, Shutterfly, etc. and include properly formatted links to those images.
-Dan
#4 Bob Griffiths
Bob Griffiths
    Getting Grouchy
  • Loc: Frederick Maryland
Posted 01 March 2013 - 08:27 AM
Canada.... I red both of your posts on the other forum.. and replied to both lol
But it is honestly not much work to post the pictures on this forum and BELIEVE me this Forum is 100 times as active and much more knowledgeable then
the other forum...
Again good luck with your build..
Bob G.
#5 csa/montana
csa/montana
    Den Mama
  • Loc: montana
Posted 01 March 2013 - 10:07 AM
Hello; we have a Member's Gallery right here on CN, scroll to the bottom of the forums to find it. Simply open your account there, and upload your pictures there. Also, you no doubt have your photos on your computer, so when posting; after hitting "Continue", you will see a "Browse" window on the second page. Click on browse to your photos on your computer & simply upload them (staying within the image size).
#6 dobsoscope
dobsoscope
Posted 01 March 2013 - 10:39 AM
i wont be signing up to yet *another* forum to view the post sorry mate!.. try using tinypic.com - no need to sign up to post the images.
#7 Canada_LX10
Canada_LX10
Posted 01 March 2013 - 07:16 PM
All the pieces drawn out on the 1/2" plywood.
#8 mikey cee
mikey cee
  • Loc: bellevue ne.
Posted 01 March 2013 - 07:29 PM
Suits me adios amigo!
#9 tim53
tim53
  • Loc: Highland Park, CA
Posted 02 March 2013 - 01:03 PM
If you already have photos somewhere online, the easiest way to post multiples within a post is to use the "image" link in the preview reply window and add them there.
But it's not hard to post one at a time from your hard drive, either.
-Tim.
#10 Canada_LX10
Canada_LX10
Posted 02 March 2013 - 02:28 PM
Cutting out the rough ribs. Used the jig saw to rough cut, then a router will trim them up to the final shape.
#11 Canada_LX10
Canada_LX10
Posted 02 March 2013 - 02:29 PM
The rough cut base ring pieces.
#12 Canada_LX10
Canada_LX10
Posted 02 March 2013 - 02:33 PM
My $1.49 router table. Used a wooden box cover that was covering an old Briggs & Stratton engine outside. Turn on its side it became my router table. $1.49 was for longer base screws.
#13 Canada_LX10
Canada_LX10
Posted 02 March 2013 - 02:36 PM
My router template screwed to the rough stock. Ready for a trim.
#14 Canada_LX10
Canada_LX10
Posted 02 March 2013 - 02:38 PM
The template removed after the trim job.
#15 Canada_LX10
Canada_LX10
Posted 02 March 2013 - 04:17 PM
Ribs for the base ring are finished being trimmed. Next, I have make spacers and layout the base ring and trim the pie pieces to make a circle.
#16 Canada_LX10
Canada_LX10
Posted 02 March 2013 - 08:37 PM
The test fitment of the base ring. I need to now cut the joints and then laminate the layers.
#17 averen
averen
    Vendor Main Sequence Software
  • Loc: Austin TX
Posted 03 March 2013 - 12:03 AM
Very nice! Any information about the dome you're building? Diameter? Type (framed/frameless)? Etc...?
Jared
#18 Canada_LX10
Canada_LX10
Posted 03 March 2013 - 11:49 AM
It is a 7.5' diameter wood dome made with curved plywood ribs. Will be making an 8x8 base for it.
Here is the website of the original builder:
http://www.baetsenob...ts/ObsDome.html
The plans in PDF format are in that website.
#19 Bob Griffiths
Bob Griffiths
    Getting Grouchy
Posted 03 March 2013 - 12:09 PM
The base ring LOOK darn good...
Bob G.
#20 Canada_LX10
Canada_LX10
Posted 03 March 2013 - 01:12 PM
Just fitting the base ring pieces to be the 91" diameter. Mine is a little larger but I need to trim the ends anyway. Just figuring the amount to trim.
#21 csa/montana
csa/montana
    Den Mama
  • Loc: montana
Posted 03 March 2013 - 05:51 PM
A lot of cutting; but you certainly managed to get it done, and the ring looks great!
#22 Canada_LX10
Canada_LX10
Posted 07 March 2013 - 06:28 PM
Hi everyone. I have not been working on the observatory build as of late but I am starting again.
We had a huge dump of snow and I spent hours on the tractor snow blowing it. The wife got stuck on the rural roads the next day so she ended up staying home that day after I towed her out with the truck. The snow was drifted up so high and thick. They took 3 days to plow our roads because of the amount and slow progress. So that was a bit of distraction to building.
No photos today but I did sand the inside of the base ring so that the roller wheels will roll nice. Tonight I am going to cut and glue the second base ring. After that I should have more photos to share.
Keep checking back as this project is not stalled.
#23 nytecam
nytecam
  • Loc: London UK
Posted 08 March 2013 - 05:40 AM
Interesting - your base ring and ribs from the same cut. Just for others considering such a project I find structurally the ribs [in vertical position] can be about half your size relative to the base ring, and whilst neat, it isn't essential to make the second cut to the inside edge within the dome. This saves by halving the total number of cuts. Hope you didn't mind the suggestion here :grin:
#24 averen
averen
  • Loc: Austin TX
Posted 08 March 2013 - 12:03 PM
I agree with the above. Doing the extra cut does make them look nicer, but it's faster to just trim the top to size. That's what I ended up doing on my dome. Here you can see the rib on the left with the 2 cuts, and the ribs on the right each with a single cut. The inside cut of one rib forms the outside cut of the next.
Jared
#25 Mary B
Mary B
  • Loc: Minnesota
Posted 08 March 2013 - 04:56 PM
I need a laser cutter with a 12 foot bed.... could cut ribs that way :lol:
