How to balance in DEC axis?
8 replies to this topic
#1 amdizack
amdizack
  • Loc: Goodyear, AZ
Posted 02 March 2013 - 11:45 AM
I find it fairly easy to adjust counterweights and find balance in RA axis. How can I best balance my OTA in DEC? I am using a CGEM 8HD with guidescope package, DSLR and auto guider.
I can't slide the OTA any further up the dovetail plate to better balance the scope in DEC. Help!
#2 Raginar
Raginar
  • Loc: Rapid CIty, SD
Posted 02 March 2013 - 12:23 PM
AMDizack,
You'll need a longer dovetail or you'll need to use a counterweight system on your scope. I have a very similar problem with my newt when the camera is on my ED80 stacked on top. I have to push the tube nearly to the end of the dovetail to get balance. One thing you could try moving your 80mm guidescope farther towards the nose of your SCT if you can.
So, longer dovetail or a counterweight system to make your mount nose heavy is really what you want.
#3 Sean13
Sean13
  • Loc: North Platte, Nebraska
Posted 02 March 2013 - 03:32 PM
I had the same problems with my tiny C6 on the CG5. I taped some lead fishing weights to the end of the tube until the balance was equal.
EDIT: Also the weights that are used to balance a car tire can either clamp onto metal or have an adhesive back and are rounded in shape. Should work fairly well for the front of the tube I'm guessing.
#4 EFT
EFT
    Vendor - Deep Space Products
  • Loc: Phoenix, AZ
Posted 03 March 2013 - 12:54 PM
For a smaller imbalanced, to to ScopeStuff and pick up one of their small counterwieghts here: http://scopestuff.com/ss_baln1.htm. These are threaded and can be attached to the hole near the end of the dovetail that is used for the emergency stop. These put more weight up near the front of the scope to counter the tail heavy nature of the SCT. For a larger imbalance another option is one of the aftermarket balance kits that attach to the underside of the dovetail.
#5 HowardK
HowardK
Posted 03 March 2013 - 01:58 PM
Ed
Does the dovetail of an Edge 8" have this threaded hole for the emergency stop?
#6 EFT
EFT
  • Loc: Phoenix, AZ
Posted 03 March 2013 - 06:09 PM
Ed
Mine does but it is a D-series wide dovetail. I haven't had a V-Series stock dovetail in quite a while so will have to check that. The hole needs to be a 1/4-20 to work with the ScopeStuff wieghts.
#7 Garry
Garry
  • Loc: Belleville, MI
Posted 03 March 2013 - 08:43 PM
Take a look at the ADM CW options:
ADM CW
This what I use.
#8 amdizack
amdizack
  • Loc: Goodyear, AZ
Posted 03 March 2013 - 08:53 PM
Thanks Ed--big help as usual!
#9 HowardK
HowardK
Posted 04 March 2013 - 12:08 PM
Ed
Just bought the rear vent fans for my Edge 8" from your site
