Motor failure on a ETX 90AT, circa 2004
4 replies to this topic
#1 Graytalon
Graytalon
Posted 14 March 2013 - 10:28 AM
Morning all,
I need to find out if there is an issue with my "handset" or the motor. I keep getting motor failure error when trying to align the mount in the "Easy" mode. I have swapped batteries, gone as far as to use a dc adapter. I did a Reset, Calibrate, and Train Drives...twice. The only thing I haven't done is try to update the handset, but I don't have the cable to do that.
My question is am I missing something or is the drive just toast?
thanks,
GT :imawake:
Oh yeah, here's a shot of PanSTARRS from my Canon powershot in a parking lot. Sometimes you just get lucky.
#2 jgraham
jgraham
Posted 14 March 2013 - 01:32 PM
A motor fault is usually a weak power source. Since you've changed the batteries and added an AC adapter it is not the source itself, but it could be a dirty connection. Carefully clean the connections on both ends of the cable and the receivers on the handset and mount. I've also seen this fault with a cable that was too long. I doubt this is what you are running into, but the handset won't work with cable extensions longer than about 14 feet. Last thought, see if your mount has a hard stop. If it does you might be running into it.
#3 bartine
bartine
  • Loc: Silver Spring, MD
Posted 15 March 2013 - 12:18 PM
Does the mount slew in all axis? The motor failure can also be a bad wire connection...
#4 Geo.
Geo.
  • Loc: Upstate NY
Posted 18 March 2013 - 07:31 PM
Motor failure means the HC can't find/communicate with the motor.
#5 Graytalon
Graytalon
Posted 24 March 2013 - 05:40 AM
Thanks for the info on the HC. I haven't had time this week to test that out. Something about wife, kid, work, hail...been interesting the last week or so. Any way, I have found the scope works beautifully without the motor. I borrowed a 10mm ep from a club mate at a star party for some scouts on the 16th and now I have to get one...Jupiter was awesome!
GT
