Paracorr II setting for lunar imaging?
1 reply to this topic
#1 JimP
JimP
  • Loc: South Carolina
Posted 17 March 2013 - 02:16 PM
What setting do you recommend using on a Paracorr II for Lunar imaging with a Skynyx camera and the following setup?
20" F/3.3 Lockwood/Starmaster with 5x powermate only. No eyepiece. The Paracorr II would give an additional desireable 1.15x magnification (like an additional 1.15x Barlow).
#2 Starman1
Starman1
    Vendor (EyepiecesEtc.com)
  • Loc: Los Angeles
Posted 17 March 2013 - 05:59 PM
From the TeleVue site:
FOR IMAGING APPLICATIONS
1) Back off set screw under flange (D) so you can unscrew lens assembly.
2) For use with DSLR cameras (APS size chips recommended, as full-size chips will show vignetting). Tele Vue Canon Wide-T Adapter CWT-2070, or Standard T-Ring Adapter TRG-1072 attaches directly to the Paracorr Type-2 flange.
3) For CCD cameras, use Tele Vue Imaging System accessory tubes with Tele Vue camera adapters, or A2A-1107 adapter for cameras with 2" nosepieces. Best back focus is approximately 55mm from flange face.
So you don't use the tunable top--you can't get the chip to the optimum 55mm distance using it unless the chip is right at the very front of the camera, which is unlikely.
