Brandon Eyepieces in Binoviewer?
26 replies to this topic
#1 Aquarist
Aquarist
  • Loc: Illinois
Posted 19 March 2013 - 12:32 PM
Is anyone using Brandon Eyepieces in a Binoviewer? If so, which ones? Thanks in advance.
#2 Stellarfire
Stellarfire
  • Loc: Switzerland
Posted 19 March 2013 - 02:30 PM
Hi Steve,
Since we are using the same equipment (TOA-150 / Mark V bino) I too would be interested in any Brandon-related feedbacks. Perhaps from other TOA-users out there?
Stephan
#3 johnnyha
johnnyha
  • Loc: Sherman Oaks, CA
Posted 19 March 2013 - 03:27 PM
I've been using the 32mm, 24mm, 16mm, and 12mm 50th Anniversary Brandons for years. They are spectacular, A+ imho. I also have 16mm and 10mm ZAO-IIs and the Brandons are to my eyes actually slightly better on bright planets, showing equal resolution and a touch less scatter, using an FS152 fluorite APO and MkV binoviewers. I've spent hours and hours directly comparing many eyepieces but especially the Brandon 16s v. the ZAOII 16s and the Brandons win for me, barely, on bright planets due to less scatter - they are pretty much equal on the Moon. YMMV of course there are differing opinions :grin:... for me they have proven to be excellent premium eyepieces and a joy to use. Don't expect them to have perfect edge correction in a fast dob unless you are using a GPC or barlow though. I am not a big fan of the eyecup version but I did own a pair of 16mm for awhile and they were exactly the same quality as the flat tops I now own. :waytogo:
#4 Stellarfire
Stellarfire
  • Loc: Switzerland
Posted 19 March 2013 - 04:04 PM
Sounds good. Okay, I think I should finally try those Brandons, too...
Stephan
#5 vahe
vahe
  • Loc: Houston, Texas
Posted 19 March 2013 - 04:24 PM
I have only one pair of B24’s, I use them strictly for planets in Zeiss/Baader viewers and F/20 Maksutovs. The B24’s are every bit as good as ZAO-25’s in every category including low scatter, low glare surrounding bright planets, color neutral, and offer a bit wider view.
If you have an eye for quality you will not be disappointed with Brandons.
Vahe
#6 Aquarist
Aquarist
  • Loc: Illinois
Posted 19 March 2013 - 04:51 PM
Yes, I was most interested in the B16 pair. Sounds like I should give them a try. Thanks!!!
#7 johnnyha
johnnyha
Posted 19 March 2013 - 06:01 PM
If you get the rubber eyecup version you can screw off the entire top and try them as flat tops. I find the rubber eyecups constrict the view, they have a hole in the middle that is just a little too small for my eyes, making it hard to see the field stop.
#8 gustave
gustave
  • Loc: Charlottesville, VA
Posted 19 March 2013 - 06:39 PM
I use twin Brandon 24's with a WO Bino that sits on top of a TV Big Barlow that is necessary to come to focus. Even with 2x Barlow mag stars are relatively sharp, extended deep sky objects are more apparent, and Jupiter is simply an incredible, "You are there" view. Open star cluster views surpass mono viewing with eps = to the FoV and mag of the bino set up above.
#9 tomcody
tomcody
  • Loc: Titusville, Florida
Posted 20 March 2013 - 10:23 AM
Johnny,
Are the flat top Brandons a special issue or old production? all I see on the web site are eyecup model eyepieces.
Rex
#10 REC
REC
  • Loc: NC
Posted 20 March 2013 - 10:27 AM
I have one 16mm and I keep looking in the claisdieds for a used one so I can pair them up in my BV. The 16mm is my best EP I have for the moon!
#11 johnnyha
johnnyha
Posted 20 March 2013 - 09:27 PM
Rex - The 50th Anniversary Brandons from a few years ago are special, and they were initially made in 100 sets with gold anodizing with 32, 24, 16, 12, 8, and 6mm in a gorgeous box for $950. Afterwards Don made some sets that were black. But Don will make the flat tops (I actually think they are "semi-volcano") on request, just give him a call.
#12 MikeBOKC
MikeBOKC
  • Loc: Oklahoma City, OK
Posted 21 March 2013 - 07:55 AM
I have a pair of Brandon 16s and they are the very best performers in my Denk Big Easy. Simply perfect on the moon.
#13 MrGrytt
MrGrytt
  • Loc: Upstate Cuomostan
Posted 21 March 2013 - 08:42 PM
I've been using Brandons of all focal lengths for bino-viewing for a very long time. The slower the scope the better but they are excellent on-axis in most any scope.
Harvey
#14 t.r.
t.r.
  • Loc: 1123,6536,5321
Posted 22 March 2013 - 07:12 AM
All of them! I use the anniversary sets in my Denk II's for everything from planetary to deep sky in my C11 and AP130GT. The 130mm is F/6.3 and while the very edges of the Brandons are astigmatic in it, the center field of view is wonderful, scatter free and dark. One thing rarely mentioned is how light these eyepieces are and that makes them perfect for binoviewing, throwing off balance very little if at all. I can easily swap from 32mm to the 6mm with little issue. Yes, even the 6 can be used for binoviewing, though admittedly less often. The "sweet spot" focal lengths appear to be the 16 & 24, but all perform. I will take two astro-items to my grave...my AP Gran Turismo refractor and my Brandons! :bow:
#15 Mark9473
Mark9473
  • Loc: 51°N 4°E
Posted 22 March 2013 - 11:15 AM
Just tell us where your plot will be, T.R. ;)
What I wanted to ask, why wouldn't you prefer to binoview with longer-FL Brandons and then use a barlow or GPC?
#16 Mike B
Mike B
    Starstruck
  • Loc: shake, rattle, & roll, CA
Posted 22 March 2013 - 11:18 AM
Aw, shucks TR... some of us were hopin' you'd release your grasp- at least when they close the lid! :lol:
Like many here have affirmed, the 16's are pretty sweet in a BVer... i use a pair of these in my Denk II + Dob, which runs them at an effective ~F6.6 at the low end: 158x - 222x - 267x with the Power-Switch... perfect for planets!
:jump:
#17 Mike E.
Mike E.
  • Loc: Moonstone Observatory
Posted 22 March 2013 - 12:11 PM
I purchased a VERNONscope binoviewer and two sets of Brandon eyepieces awhile back. When the seeing is good here in the UK, I have found the 12mm's to be the sweet spot; especially for Lunar observing.
#18 t.r.
t.r.
Posted 22 March 2013 - 01:13 PM
You certainly could do that. And I do. Many will say, do all your magnifying before the binoviewers (w/GPC or barlows) only. But, I like to break rules and run with scissors! The Denk II's and Brandons are certainly up to the task no matter how I configure the optical train. ;) And FYI...I'm being cremated with the aforementioned goodies! :mrevil:
#19 George N
George N
  • Loc: Binghamton & Indian Lake NY
Posted 22 March 2013 - 05:30 PM
I have a pair of Brandon 16mm ‘blems’ that I got from Don about 2 years ago while visiting his shop (about 60 minutes from my house). He picked a precisely matched pair of optics from those going into his military order and put them in barrels with a slight defect. One had a scratch on the part that inserts into the focuser, and the other had a deficit in the white paint in the printing. Don give me a super-great discount on these ‘blems’. They have proved to be by far my favorite eyepieces in my Denk II for planetary viewing, especially with my 127mm APO. I also use one in my Coronado PST for h-alpha solar. I like them so much that I’ve thought of getting a pair of 8 or 10mm.
BTW, Don often sells blems at NEAF, but they all sell out in the first hour or two on Saturday morning. He told me that he sells even more blems at the WSP, but they go fast there too.
For deep sky, mostly on my Obsession 20, I use Denk 21mm’s and a pair of cheap Rini 30mm Erfles.
#20 johnnyha
johnnyha
Posted 22 March 2013 - 05:43 PM
It is SO nice to finally see here on Cloudy Nights
a) the Brandons finally get there due respect, and
b) the Brandons mentioned without someone immediately derailing the thread with some ridiculous unfounded disbelief and mockery.
They are excellent premium orthoscopic eyepieces with extremely high polish only available in very few other eyepieces costing much more, and you can see the results optically.
#21 Mike E.
Mike E.
Posted 23 March 2013 - 05:46 PM
:ubetcha:
#22 Aquarist
Aquarist
  • Loc: Illinois
Posted 23 March 2013 - 07:15 PM
I agree. I sent off asking for a matched pair of 16mm to give them a try in my MarkV.
#23 johnnyha
johnnyha
Posted 23 March 2013 - 08:00 PM
Bob S. is selling a nice set of flat tops on the other site.
#24 Paul C-I
Paul C-I
  • Loc: United Kingdom
Posted 25 March 2013 - 04:44 PM
agree with others,
Pair of 16 & 24's in my Mkv along with the Baader FFC for high power viewing..............just don't get any better!
Paul
#25 Phil Cowell
Phil Cowell
  • Loc: Southern Tier NY
Posted 07 April 2013 - 02:12 AM
I have two sets of Brandon's and use the Vernonscope binoviewer. They really are something special in my TEC 140, 6" MCT or C14 Edge.
Phil
