etx 125 hand controler..
6 replies to this topic
#1 deleterman
deleterman
  • Loc: El Cajon , Cal.
Posted 26 March 2013 - 05:51 PM
Hi all, was out the other night and checking out jupiter and went to lock on to it as i had 100's of times, it tracks spot on for hours..after i did this the scope went wacko going here and there.. :confused: then i tryed to use the arrow button to get back on it it worked great. but later i tryed the arrow button again and it did the same thing but not as bad the scope just went a few inches and stoped. any thoughts on this?? :help:H.B.
#2 rtanton
rtanton
  • Loc: Mission Viejo, CA
Posted 26 March 2013 - 06:13 PM
A likely culprit is the handbox cord. It usually fails at one of the RJ connectors. Some of the better cables added strain relief systems to avoid this type problem.
Russ
#3 deleterman
deleterman
Posted 26 March 2013 - 06:50 PM
Thank you so much for the info Russ.is there a way i could check the connection ? and where could i get better cables ? again thanks.H.B.
#4 Edward Swaim
Edward Swaim
  • Loc: Little Rock, Arkansas
Posted 27 March 2013 - 05:46 PM
Don't substitute a computer network cable! I blew a voltage regulator chip by doing that.
Ed
#5 deleterman
deleterman
Posted 27 March 2013 - 06:49 PM
Thanks for the great advice.its good to know these things. again thanks.H.B. :foreheadslap:
#6 deleterman
deleterman
Posted 28 March 2013 - 05:45 PM
Today checked out cable, no problem ?!! checked out scope and arrows and speed -no problem.. will do some more checking tomorrow. :shrug:H.B.
#7 tomatohead
tomatohead
Posted 28 March 2013 - 07:06 PM
If you are having trouble with intermittent 497 cable connections try this: Take an old tooth brush and ordinary tooth paste, scrub the contacts and let every thing dry. It gets the contacts nice and shiny. Works Great!
