AZEQ6 DEC vertical play
3 replies to this topic
#1 Mike X.
Mike X.
  • Loc: Greece-Athens and Rome-Italy
Posted 27 March 2013 - 02:57 AM
Hello friends, excuse me for opening another thread in so short time, i thought i should open a new one due to the nature of the querry.
As the title states i have this DEC play in vertical when the DEC clutch is free and i move the RA Axis (in EQ mode) for more than 180 degrees.
In that case due to the gravity i see a slight vertical movement of the DEC axis for about 1-2mm.
If the Dec clutch is tightened up and the axis is not free,there is no movement at all in whatever position i move it.
Does anyone who has this mount saw a similar thing?Is it because of the different blocking meccanism?
Thank you in advance,
#2 Mike X.
Mike X.
Posted 27 March 2013 - 03:40 AM
Here are 2 videos i made so i can show the problem if such it is.
http://youtu.be/h__XmcIt3DQ
http://youtu.be/OxH9jp9Nrb4
#3 rmollise
Posted 27 March 2013 - 07:58 AM
Maybe I'm not understanding the problem, but if there is no movement with the axis locked, I don't see that there's a problem...
#4 Mike X.
Mike X.
Posted 27 March 2013 - 09:40 AM
Hi Rod,i was just wondering if it's normal as i've never had this kind of movement on my cg5.
Yes witht he axis locked nothing moves.
PS:I 've just checked also the RA axis, i guess is pretty normal ,it happens the same thing.
