Telementor model 2 disassembly
35 replies to this topic
#1 starman876
starman876
  • Loc: VA
Posted 28 March 2013 - 05:52 PM
Here are some pictures of the Telementor II after I took it apart. Very interesting that there is an OTA within the larger tube complete with baffles that actually is moved back and forth by friction by the focusing knob.
  • albert1 likes this
#2 starman876
starman876
  • Loc: VA
Posted 28 March 2013 - 05:53 PM
Pic 2
#3 starman876
starman876
  • Loc: VA
pic 3 these are the guides inside the larger tube that keep the smaller tube sliding back and forth smoothly.
#4 starman876
starman876
  • Loc: VA
Posted 28 March 2013 - 05:55 PM
Pic 4 this is the focusing mechanism
#5 Masvingo
Masvingo
  • Loc: Ayrshire, Scotland
Posted 28 March 2013 - 06:02 PM
Interesting! Thanks for posting these, Johann.
What is the friction wheel made of? It is some sort of rubber compound?
James
#6 starman876
starman876
  • Loc: VA
Posted 28 March 2013 - 06:07 PM
All metal. The wheel goes into the long slot in the ota and just moves it back and forth when the focuser knob is turned. the wheel has a slight taper to it. Provides about 4" of travel.
#7 Masvingo
Masvingo
Posted 28 March 2013 - 06:14 PM
Certainly an unusual set up. How light / heavy is the focuser knob to turn? Is there a noticeable difference in feel between the tube being horizontal and vertical?
#8 Dave M
Dave M
  • Loc: Ohio
Posted 28 March 2013 - 06:31 PM
Whats the little blocks on the guides, teflon, metal or something else ?
#9 starman876
starman876
  • Loc: VA
Posted 28 March 2013 - 06:40 PM
The little white blocks are Teflon.
#10 terraclarke
terraclarke
  • Loc: !KentuckY!
Posted 28 March 2013 - 07:21 PM
Johann, how's the weight of the T2 compared to the T1? I would imagine the T2 is a good deal heavier. If so, that must be one heavy telescope considering that the T1 is more than twice as heavy as any other 60mm refractor that I own.
#11 gelkin
gelkin
  • Loc: Western, MD.
Posted 28 March 2013 - 07:53 PM
Pretty cool Johann. Don't have one of those but very interesting post. :bow:
#12 AllanDystrup
AllanDystrup
  • Loc: Denmark
Posted 29 March 2013 - 03:17 AM
Thank you for the pics Johann ! -- I've always thought the T2 focusing mechanism was a 'standard' R&P (or possibly a worm gear type, like the Unitron focuser).
Now a friction wheel driven linear actuator..., that's something quite original. Works great though.
Allan
#13 starman876
starman876
  • Loc: VA
Posted 29 March 2013 - 06:17 AM
Terra
When I put it back together I will weigh both and let you know the difference.
#14 starman876
starman876
  • Loc: VA
Posted 29 March 2013 - 06:24 AM
Have not checked to see if the feel is different versus vertical amd horizontal.
#15 nightpilot
nightpilot
  • Loc: Southern Suburbs, Chicago
Posted 29 March 2013 - 11:48 PM
Thanks for the great pics ... I have a T1 but I always wondered what the inside of those looked like and how they worked. Very interesting.
Bob
#16 starman876
starman876
  • Loc: VA
Posted 30 March 2013 - 09:50 AM
After I took it apart I realized I did not need to disasemble as much as I did. Will be interesting putting it back together.
#17 starman876
starman876
  • Loc: VA
Posted 30 March 2013 - 05:30 PM
No difference in feel between vertical or horizontal focusing. I redid lube with synthetic white grease. Still have not weighed the two tubes.
#18 starman876
starman876
  • Loc: VA
Posted 30 March 2013 - 05:34 PM
Not sure if my scale is accurate enough. They both weigh in at 6.8 pounds.
#19 mustgobigger
mustgobigger
  • Loc: Michigan
Posted 31 March 2013 - 06:39 PM
pretty cool johann...so the two half round shims go in the front
and the other goes opposite focus wheel ?
#20 starman876
starman876
  • Loc: VA
Posted 31 March 2013 - 06:54 PM
one half round goes opposite the focuser. the other goes at the end of the tube with the spring loaded shim opposite it. I really did not need to take any of those parts out to remove the inner OTA. I had no clue what I was going to find so I just removed every screw and then the tube came out and all the parts just fell out afterwards. I had to make a special piece of wood with nothches in it so that I could hold the shims in place so I could put the screws back in My hand was too small to fit into the tube.:lol:.
#21 mustgobigger
mustgobigger
  • Loc: Michigan
Posted 31 March 2013 - 07:02 PM
i always use a paint stick with 2 way tape on it...works great.
#22 terraclarke
terraclarke
  • Loc: !KentuckY!
Posted 31 March 2013 - 08:25 PM
I hope the operation is proceeding smoothly. :smash: Now where does this screw go :question:
#23 starman876
starman876
  • Loc: VA
Posted 31 March 2013 - 09:10 PM
All back together
Now to wait for clearskies :cloudy: :cloudy:
#24 Mike E.
Mike E.
  • Loc: Moonstone Observatory
Posted 01 April 2013 - 12:15 AM
An interesting and informative thread, thank you for posting.
#25 starman876
starman876
  • Loc: VA
Posted 01 April 2013 - 08:29 AM
To be honest I think this was easier then taking the helical focuser on the type I telementor apart.
