AP 2" ADASCTLC visual back for Edge 11?
10 replies to this topic
#1 WesC
WesC
  • Loc: La Crescenta, CA
Posted 28 March 2013 - 07:34 PM
I'm looking at getting the Astro-Physics ADASCTLC 2" visual back for my C11 Edge, but I'm a little confused about how this is going to work.
Astro-Physics says on their site:
"Note: Celestron Edge HD scopes have a restricted rear cell that may not allow accessories with a long nosepiece to fully seat in this adapter (the AP Maxbright diagonal will not seat). It is recommended to choose the ADASCTLC27 and ADA2003 (or ADA20132) as an alternative when using the Edge HD scopes."
Now, I haven't heard anyone mention that this is a problem for them using this visual back, and have seen it recommended frequently, so is this really the case or is it OK to just get this thing and be done with it?
I'm considering the TeleVue Everbright, AP Maxbright or Williams Optical CF dielectric diagonals for use in this scope. I just need to know if I need to follow AP's advice or if you find folks here on CN have made this work with this visual back.
#2 turk123
turk123
  • Loc: N.E. Ohio
Posted 28 March 2013 - 10:17 PM
I am using one just fine. I have a WO diagonal and two different cameras, adapters, extensions, it all works just fine. I never understood AP other than their diagonal is non- standard.
Go for it.
Turk
#3 Whaleboy
Whaleboy
  • Loc: Los Angeles
Posted 29 March 2013 - 01:20 AM
I figured why risk it, although I'm sure it works with most accessories, I went ahead and did as AP suggests and got the ADASCLTC27 plus ADA2003, and that combo works fine, although it likely takes up a bit more back focus, at least so far it works with everything I need.
-David
#4 WesC
WesC
Posted 02 April 2013 - 05:41 PM
So one for and one against. Hehe, not really clearing this up for me. But thanks!
#5 ewave
ewave
  • Loc: northwest NJ
Posted 02 April 2013 - 05:58 PM
Wes
I simply use the ADASCTLC back for my C9.25 edge with a 2" GSO quartz diagonal and never had an issue with the nosepiece hitting the corrector. Not sure about the C11 edge but I'm sure you can always find a shorter 2" nosepiece anyway for whatever diagonal you decide to purchase.
#6 ewave
ewave
  • Loc: northwest NJ
Posted 02 April 2013 - 06:01 PM
also forgot to mention an important aspect, I also have a refractor style nosepiece with the diagonal
#7 turk123
turk123
  • Loc: N.E. Ohio
Posted 03 April 2013 - 07:31 AM
Their is no danger in hitting the rear lens in a 1100 edge scope as it is 130mm away from the back inside the baffle. What Astro Physics is talking about is the baffle is under 2". Using this adapter if your focuser has a nosepiece longer than 31mm, it will hit the smaller opening baffle. It will not allow the device to pass into the main baffle. If you are just wanting a good grip on the device, the 31mm is plenty especially with the three thumbscrews and compression ring on the ASASCTLC. The back focus on an 1100 is somewhere around 149mm, quite a ways back. It has not impacted any of my equipment including reducers, filter wheel, cameras, diagonals. In fact, most of the time I'm adding extensions to get there.
#8 bilgebay
bilgebay
  • Loc: Turkiye - Istanbul and Marmaris
Posted 03 April 2013 - 10:49 AM
Just buy ADASCTLC. I have used this visual back for three years with no problems whatsoever. None of my diagonals or binoviewers had any issue with this part.
It is a beauty.
#9 WesC
WesC
Posted 03 April 2013 - 12:15 PM
Thanks a lot guys, I appreciate your comments. :)
#10 stefang
stefang
  • Loc: Sydney
Posted 15 June 2015 - 07:45 AM
Has any one used the mark V with the Baader 2" SCT Click-Lock Eyepiece Adapter / Visual Back (with 3.25" SCT Thread) # CLSCL-2 2956233?
stefan
#11 t.r.
t.r.
  • Loc: 1123,6536,5321
Posted 16 June 2015 - 06:21 PM
stefan
Folks here do use this combination satisfactorily...but it will add more back focus as it is longer. The AP is low profile.
