Mount for Explore Scientific AR152 f/6 Refractor
8 replies to this topic
#1 brucedeerhaven
brucedeerhaven
Posted 06 April 2013 - 11:17 AM
Can anyone suggest some good sturdy Mounts for my new Explore Scientific AR 152 f/6 Refractor. Thought about purchasing the Explore Scientific Twilight II Mount which appears to be Heavy Duty enough for this particular scope. Any other suggestions?
#2 Pat at home
Pat at home
  • Loc: Campbellton, New Brunswick, Canada
Posted 06 April 2013 - 11:47 AM
For manual Alt/Azm I use a Canadian Telescope Duo-T (same as SkyTee II) with ADM clamp and for GOTO I use a Skywatcher EQ6 also with ADM clamp.
#3 dakota
dakota
  • Loc: SD (God's Country)
Posted 06 April 2013 - 03:49 PM
Ditto on the Canadian Duo-T.
Here's mine holding a AT152mm and SV110ED with no problems.
#4 herrindude
herrindude
  • Loc: Fairhope Alabama
Posted 08 April 2013 - 10:07 PM
for photography, i use a older cge mount and it works great.
#5 dr.who
dr.who
Posted 08 April 2013 - 10:15 PM
Non goto the Twilight II works very well. Goto for visual only I have had one on a CG5 and it did fine but you will want the Orion pier extension for it because it is a yard cannon. If you want to be doing AP then you will want at least a CGEM if not CGEM DX.
#6 Lane
Lane
  • Loc: Frisco, Texas
Posted 08 April 2013 - 11:12 PM
The Celestron Advanced VX would handle it just fine. And then you have GoTo and Tracking for your new scope at a reasonable price.
#7 jbalsam
jbalsam
  • Loc: Spencerville, MD
Posted 09 April 2013 - 11:15 AM
Like Herrindude, I use an older CGE mount for mine when I'm imaging. Works great for me, so long as you're willing to deal with the occasional hiccups that CGEs have.
#8 Pat at home
Pat at home
Posted 10 April 2013 - 12:52 PM
For GO-TO an EQ6 handles the AR-152 with aplomb. Taller DIY tripod so as not to be laying down on the ground with higher objects.
#9 exparrot
exparrot
  • Loc: Dallas/Fort Worth, TX
Posted 10 April 2013 - 02:49 PM
I use mine on a Universal Astronomics DoubleStar. It's a tandem Alt-Az mount that handles 40lbs on the right and 30lbs on the left. I'm currently having the mount retrofitted with encoders and adding a Sky Commander for push-to capability.
