Alignment
10 replies to this topic
#1 kljw
kljw
  • Loc: Scotland
Posted 06 April 2013 - 04:32 PM
Hi
need a little help with this. i am using the autoalign with my LX200, however, i am finding it hard to indentify the bright star it slews to and then centre.
the the first start is selected, there are many stars in the eye peace, and all seem to be about the same brightness.
so, are there any tips that any of you fellow LX200 owners can offer.
many thanks.
#2 jrcrilly
jrcrilly
    Refractor wienie no more
  • Loc: NE Ohio
Posted 06 April 2013 - 04:41 PM
The alignment star probably isn't in the eyepiece (you'd recognize it if it were). Center it in the finder first - then it'll be in the eyepiece. After a successful alignment, perform a "calibrate compass". Then the alignment star should be in the eyepiece (at reasonable magnification) on subsequent alignments.
#3 nitegeezer
nitegeezer
    Galactic Ghost
Posted 06 April 2013 - 04:50 PM
I try to start the align process as early in the evening as I can so there are fewer stars to choose between. If I don't know a particular star by name I skip it and go to the next one in the list. I try to use stars that are easy for me to recognize like Arcturus. I remember seeing a list of the alignment stars somewhere and I believe there are only about 25, I can't remember where I saw that list, but Vega and a couple of stars in the Big Dipper can also be used. I suggest learning a few well and then just skip through the stars to those, I believe that is the down arrow on the later hand controllers, but that may vary depending on which version you use.
#4 kljw
kljw
  • Loc: Scotland
Posted 07 April 2013 - 02:32 AM
Hi
thank you for the advice, i will start the alignment a little earlier tonight and i will try the calibrate compass after.
again, thank you, much appreciated.
#5 Robert70
Robert70
  • Loc: The Garden State: NJ
Posted 08 April 2013 - 10:06 AM
Is there a question mark on the handset? On my lx90 I press the ? and the name of the star appears.
#6 kljw
kljw
  • Loc: Scotland
Posted 09 April 2013 - 07:28 AM
Hi
i have ordered a telrad, so that should aid things a little better.
i have also read in the instruction book about the '?' mark, so i will try and get some charts printed, that will show me what to look for as an aid to alingment.
many thanks again for the help.
#7 Whichwayisnorth
Whichwayisnorth
  • Loc: Southern California
Posted 10 April 2013 - 01:13 AM
Hi
The Telrad will make life wonderful.
#8 nitegeezer
nitegeezer
    Galactic Ghost
Posted 13 April 2013 - 10:45 AM
I know I have fought the issue of which star should I center on. I just did a search to see what I could find and found this alignment stars webpage. I don't know why I did not look for this before but I thought I would share it.
#9 eliasx1
eliasx1
  • Loc: Chicago suburbs
Posted 13 April 2013 - 09:33 PM
I use Starwalk on my phone. This helps me identify the correct star. The star's brightness on the phone and in the sky are very similar. The stars the telescope slews to are the brightest ones. You know when you see it in the eyepiece because it is much brighter than the rest.
#10 thesubwaypusher
thesubwaypusher
  • Loc: New York City
Posted 21 April 2013 - 08:30 PM
Good idea!
#11 kljw
kljw
  • Loc: Scotland
Posted 22 April 2013 - 08:20 AM
Hi
i now have Starwalk, and i have stated to setup just as the light daes. tried this over the weekend, when aligning, it was obvious as to what stars i should turn to.
Alignment was spot on, and kept tracking spot on when looking and objects in the night sky.
all this was made possible by the Telrad, but most of, suggestions from fellow forum members.
well done, and thank you.
