Polar Scope LED on Atlas
5 replies to this topic
#1 KD58
KD58
  • Loc: West Texas
Posted 07 April 2013 - 01:00 PM
Would I be able to safely replace / modify it myself at home? If so, do I open the panel that the power / cables etc attach to or would it require more elaborate disassembling of the mount. In trying to move the LED out of the way (it was too bright) I ended up with no LED light at all after I tugged at it gently with a hook made of wire.
#2 tclehman1969
tclehman1969
  • Loc: SF Bay Area, California
Posted 07 April 2013 - 03:25 PM
Yes, on the Atlas EQ-G the LED is just inside the compartment behind the power and hand control panel. I'm not entirely certain what holds it in place, looks to be a glue of some sort.
I just bought my Atlas EQ-G and I initially thought the LED was too bright, but I found you can decrease brightness from the hand controller. Have you thought about doing that before delving in to the challenges of modifying it?
#3 Cliff Hipsher
Cliff Hipsher
  • Loc: North Chesterfield, VA
Posted 07 April 2013 - 04:08 PM
That happens when you pull the wires off. (biting tongue)
#4 KD58
KD58
  • Loc: West Texas
Posted 07 April 2013 - 04:53 PM
That happens when you pull the wires off. (biting tongue) [/quote]
I realize that's what I've done but didn't want to say it:)
Khavar
#5 KD58
KD58
  • Loc: West Texas
Posted 07 April 2013 - 04:56 PM
I've recorded my misery on another thread. I can't get the Synscan hand controller to work with the mount and am running it through EQMOD and a gamepad controller. Unfortunately it seems I will need to open up that panel. I'll post here what happens next.
#6 KD58
KD58
  • Loc: West Texas
Posted 07 April 2013 - 10:01 PM
Thanks for your help. I was able to open the side panel and get to the LED. I snipped the wires and attached a small LED i got from Radio Shack and put some electrical tape on the connections and some superglue on the wires holding it onto the circular piece holding it. I tested it before closing the panel and again a little while ago. It is perfect: just enough red to isolate Polaris. I am very pleased and appreciate your help very much.
Khavar
