Saturn April 11th nice seeing.
20 replies to this topic
#1 Kecktastic
Kecktastic
  • Loc: Broken Hill NSW Australia
Posted 12 April 2013 - 06:10 AM
Hi All,
Imaged Saturn last night in quite reasonable seeing with the intention of capturing the long lived dark spot as per the projected position from my drift chart.
Have measured the dark spot to be at L3 149.1 Lat +45.5 there is also a prominent bright spot leading the dark spot at L3 136.1 Lat +49
I am off down to Adelaide for surgery to have the wires that have been holding my wrist together removed, hope the grafted ligament has been successful.
I would have been cheesed right off if I missed good seeing but it looks like it will be less than great until I return.
Thanks for looking.
Regards
Trevor
#2 Kecktastic
Kecktastic
Posted 12 April 2013 - 06:11 AM
r channel polar projection
#3 Kecktastic
Kecktastic
Posted 12 April 2013 - 06:12 AM
RGB
#4 Kecktastic
Kecktastic
Posted 12 April 2013 - 06:13 AM
RGB polar projection
#5 Kecktastic
Kecktastic
Posted 12 April 2013 - 06:14 AM
742nm IR
#6 Kecktastic
Kecktastic
Posted 12 April 2013 - 06:15 AM
742nm IR polar projection
#7 Kecktastic
Kecktastic
Posted 12 April 2013 - 06:16 AM
r channel animation
#8 Kecktastic
Kecktastic
Posted 12 April 2013 - 06:17 AM
RGB animation
#9 Kecktastic
Kecktastic
Posted 12 April 2013 - 06:18 AM
742nm IR animation
#10 martus
martus
  • Loc: Czech Republic
Posted 12 April 2013 - 07:35 AM
Trevor excellent! absolutely perfect! thanks for sharing!
martus
#11 Kecktastic
Kecktastic
Posted 12 April 2013 - 09:07 AM
Thanks very much Martus, have just added another image thanks to some inspiration from Dave Tyler.
#12 Sunspot
Sunspot
  • Loc: Surprise, AZ
Posted 12 April 2013 - 09:17 AM
Trevor,
Wow! Very nice. I'll bet the visual views were amazing.
Paul
#13 Az Frank
Az Frank
  • Loc: Tucson Arizona
Posted 12 April 2013 - 09:57 AM
Outstanding Trevor! The dark spot is loud and clear!Great you'll be back at full speed health wise!Good luck.
#14 bunyon
bunyon
  • Loc: Winston-Salem, NC
Posted 12 April 2013 - 10:21 AM
Trevor, those are outstanding images. The R animation is really incredible.
Good luck with the wrists.
#15 lcd1080
lcd1080
  • Loc: Maryland, USA
Posted 12 April 2013 - 12:14 PM
Trevor, I like the R and IR animations each for a separate reason; the R reveals the velocity of both the dark spot and the vertices of the polar hex while the IR focuses on the dark spot and the banding at the pole. All in all a very nice tour of Saturn's surface dynamics. I hope all goes well in Adelaide, I'm sure it will.
Pete
#16 TorstenEdelmann
TorstenEdelmann
  • Loc: Landsberg, Germany
Posted 12 April 2013 - 12:24 PM
Outstanding images Trevor!
Torsten
#17 AstroDan2015
AstroDan2015
  • Loc: Racine, Wisconsin
Posted 12 April 2013 - 01:00 PM
Hi Trevor,
Really great work, your Saturn shows tremendous detail!
I'm sure your wrist will completely heal given enough time, take it easy.
Best wishes... clear skies, Dan :cool:
#18 Kecktastic
Kecktastic
Posted 13 April 2013 - 05:12 AM
Thanks very much Martus for your very generous comment.
Thanks very much Paul, I probably should be too ashamed to admit it but since building this telescope I have not looked through an eyepiece with it. All of my time goes into imaging with it. Reckon I will have to rectify this situation shortly.
Thanks very much Frank, just finished packing the car for the trip.
Thanks very much Paul.B.J.
Thanks very much Pete, it has been really awkward this last 6 weeks rotating my manual filter wheel, they left just enough of my fingers out of the plaster cast to, sort of, manage it.
Thanks very much Torsten, your most excellent FireCapture certainly makes capturing data easier.
Thanks very much Dan, appreciate your sentiments.
#19 lcd1080
lcd1080
Posted 13 April 2013 - 11:21 AM
...Thanks very much Pete, it has been really awkward this last 6 weeks rotating my manual filter wheel, they left just enough of my fingers out of the plaster cast to, sort of, manage it...
Oh my gosh Trevor you deserve a motorized filter wheel unless there's an advantage to a manual filter wheel that I hadn't thought of?
Pete
#20 Bird
Bird
  • Loc: Murrumbateman, Australia
Posted 13 April 2013 - 05:58 PM
Excellent images Trev, the red channel is great.
cheers, Bird
#21 Mitchell Duke
Mitchell Duke
  • Loc: Georgia
Posted 13 April 2013 - 06:55 PM
Awesome animation, and the processing is outstanding!!
