Replacement lock knob for CGE counterweight?
8 replies to this topic
#1 jrbarnett
  • Loc: Petaluma, CA
Posted 17 April 2013 - 10:21 PM
I have a CGE with two counterweights. On one of the counterweights the plastic "T" handle has shattered on the lock knob. Has anyone found a source of replacements for these knobs?
Not my mount, but a good picture of the CW with the lock knob visible.
http://www.astrofoto.../CGE_FLT110.jpg
#2 jrcrilly
jrcrilly
    Refractor wienie no more
  • Loc: NE Ohio
Posted 17 April 2013 - 10:26 PM
That's a weak part. I bought a new CGE when they first came out and one of the included counterweights arrived with that knob shattered. C replaced it. I think they are threaded 1/4 X 20 - if so, Scopestuff can fix you up.
http://www.scopestuff.com/ss_lscr1.htm
#3 jrbarnett
  • Loc: Petaluma, CA
Posted 23 April 2013 - 11:58 AM
Thanks John. I'll check them out.
#4 KD58
KD58
  • Loc: West Texas
Posted 21 June 2013 - 10:50 PM
Jim. I've run into the same problem and wonder if you were able to resolve the issue through Scopestuff and if so which knobs did you get?
Khavar
#5 CharlesW
CharlesW
  • Loc: Chula Vista & Indio, CA
Posted 22 June 2013 - 08:55 AM
That's a pretty sizeable CW. Not as convienent but wouldn't it be safer to use a socket-head bolt instead?
#6 frozen.kryo
frozen.kryo
  • Loc: East of the Sun, West of the Moon
Posted 22 June 2013 - 12:08 PM
If I'm not mistaken, the 25# CGE counterweights share the same type knobs with the losmandy 21#. Losmandy sells them for 8 bucks each. Item CWTS.
#7 KD58
KD58
  • Loc: West Texas
Posted 23 June 2013 - 01:10 PM
I emailed Anthony at ADM and will be shipping my counterweight screw to him. He will make a knob for me. I'll post back when it arrives.
#8 jrbarnett
  • Loc: Petaluma, CA
Posted 23 June 2013 - 02:20 PM
Yup, those are the ones. I need to measure my broken one. $8 a pop is a little steep for a screw with a plastic flange.
- Jim
#9 jrbarnett
  • Loc: Petaluma, CA
Posted 23 June 2013 - 02:23 PM
Hi Charles.
When the plastic flange shatters, that's what you end up with - hex socket headed nylon tipped partially threaded screw. So technically I can use the second weight as-is; I just need to make sure that I have the right allen wrench on hand to tighten it. It's a convenience issue more than anything else.
