C11hd vs Meade 12" f/8
8 replies to this topic
#1 Starhuckster
Starhuckster
  • Loc: Boston, MA
Posted 24 April 2013 - 06:44 AM
Has anyone done a side by side comparison? Is there a thread about this already?
#2 Lane
Lane
  • Loc: Frisco, Texas
Posted 24 April 2013 - 05:49 PM
28lbs for the 11 vs 56lbs for the 12 is all you really need to know. The Meade is even heavier than the C14 HD, which is only 45lbs.
I have had my C11 next to a 12 on two occasions and saw nothing in the 12 that I could not see just as well in my C11. In fact the last time I did that comparison the C11 beat the 12 pretty badly, but only because the 11 was able to adjust to the dropping temps better that night. I believe the mirrors in the Meade scopes are much thicker than those in the Celestron, which causes them to adjust to temperature changes slower.
I am sure there are some faint galaxies or planetary nebula that a 12 could see that the 11 could not, but I will bet that list is pretty small.
As far as the HD vs ACF goes, the HD approach is better according to everything I have read. Apparently you have to have a corrector lens, as celestron used, to properly correct for the various aberrations in an SCT. Just reshaping the secondary is not enough.
#3 MikeBOKC
MikeBOKC
  • Loc: Oklahoma City, OK
Posted 24 April 2013 - 06:01 PM
Had my standard CPC1100 next to a Meade 12 as well, and the views were essentially identical. I can't speculate on the C11HD, but I would bet it would be better to the edge as noted above, and probably the same on axis.
#4 Bill Barlow
Bill Barlow
  • Loc: Overland Park KS
Posted 24 April 2013 - 07:43 PM
I wonder if the 56 pound weight of the Meade f/8 12" is a misprint. My Meade 12 ACF OTA weighs 39-40 pounds with the Losmandy rail, the AP visual back and a2" diagonal, so I would think the f/8 version is probably closer to 45 pounds. Especially if the Meade f/8 14" weighs 63 pounds, there must be a larger weight difference between the f/8 Meade 12" and 14" OTA's than 7 pounds.
I owned both C11's and M12's and I prefer the views through the Meade. But YMMV.
Bill
#5 Lane
Lane
Posted 25 April 2013 - 02:10 PM
The 56lb weight is listed on OPT's site. Meade has never published the weight of their scopes because of discussions like this one.
#6 Griffin!
Griffin!
Posted 25 April 2013 - 02:18 PM
Meade lists the weight of the 12" LX200 as 34.66 lbs.
I can see the f/8 being a bit heavier with new focuser, but not 20 lbs more.
#7 KevH
KevH
  • Loc: Maine
Posted 25 April 2013 - 03:04 PM
Link to the 34.66 lb weight...
LX200 Specs
I agree, there is no way the f8 ota weighs that much more than the f10.
#8 mega256
mega256
  • Loc: N of Tampa
Posted 25 April 2013 - 03:30 PM
I would belive that the true weight of the 12" is about close to 40 lbs with the mounting dove tail bar on it? I just measured my C11-HD with a focuser (jmi-elect.) and dovetail bar and its real close to 29 lbs...
Wonder if that spec from meade is stripped dowm ? Can anyome try theres ?
But I also agree.....specs from meade can use some improvments....
#9 Starhuckster
Starhuckster
  • Loc: Boston, MA
Posted 26 April 2013 - 05:50 AM
I was just looking at some used Meade 7" Maks and some of those seem to have iron weights built in, so maybe they're making that an option again ;)
