Tip for Az Eq6 users
8 replies to this topic
#1 HowardK
HowardK
Posted 27 April 2013 - 06:33 PM
Maybe you alll thought of this but....
In ALT AZ mode the Az Eq6 mount can be tricky to collimate the 2nd scope in Az...here's what I suggest...
Buy a set of car engine feeler guages....there will be one in there that will shim out the dovetail on the 2nd scope to bring it perfectly in line....especially if its a vixen type dovetail bar as this sits flush in the saddle giving plenty of area for the shim to do its shimming...much better than folding strips of aluminium foil.
#2 frolinmod
frolinmod
Posted 27 April 2013 - 07:07 PM
Anthony at ADM Accessories sells a "hocky puck" style counterweight shaft to (ADM) dovetail adapter with azimuth push/pull adjustment bolts built right in. He'll customize it for any counterweight shaft diameter. The AZ-EQ6 uses a one inch diameter counterweight shaft. Note that it expects you to do altitude adjustment by rotating the shaft, hence doesn't have any altitude adjuster.
I already had an ADM Accessories MAX-M, so I just put it on the counterweight shaft side instead. Adjustments with the MAX-M are fast and easy.
#3 HowardK
HowardK
Posted 28 April 2013 - 08:45 AM
Can u show me the link to the adjustable ADM adapter?
I have the max m but its weight is too heavy
#4 frolinmod
frolinmod
Posted 28 April 2013 - 09:26 AM
It's the DUAL-CW which you can find on this webpage.
#5 HowardK
HowardK
Posted 28 April 2013 - 12:18 PM
Interesting
#6 biz
biz
    Vendor
  • Loc: New Zealand
Posted 28 April 2013 - 02:03 PM
Hi Howard.
Just remember you have the saddle that you sent me that I inserted cone adjustment screws. This was done to cure the problem of adjusting the secondary OTA.
You may be able to get that to fit your new mount.
cheers.
Graham.
#7 HowardK
HowardK
Posted 28 April 2013 - 02:29 PM
Yup
That is exactly what i am going to do......
Nice one Graham
#8 HowardK
HowardK
Posted 28 April 2013 - 02:30 PM
Just need a vixen rail though for the OTA
#9 biz
biz
    Vendor
  • Loc: New Zealand
Posted 28 April 2013 - 05:58 PM
Yup
Nice one Graham
Howard, let me know how you get on.
Cheers.
Graham
