Replacement secondary for xx12i
25 replies to this topic
#1 mak17
mak17
  • Loc: Central Florida
Posted 28 April 2013 - 03:38 AM
Anyone know where I can get a new secondary? The Orion website says its a 70mm secondary.
#2 planet earth
planet earth
Posted 28 April 2013 - 04:00 AM
Agena Astro has the GSO 70mm, 12mm thick $70.00.
http://agenaastro.co...rror-70-mm.html
Sam
#3 pstarr
pstarr
  • Loc: NE Ohio
Posted 28 April 2013 - 08:50 AM
If your replacing a bad secondary. I wouldn't go with another supplier who has been hit miss on quality. Antares or Protostar are two who sell quality secondaries. web page
web page
#4 mak17
mak17
Posted 28 April 2013 - 06:08 PM
I want a high quality secondary but the 2.6 inch Antares and protostar are a bit smaller then 70mm. Will this cause a loss of illuminated field?
#5 pstarr
pstarr
  • Loc: NE Ohio
Posted 28 April 2013 - 06:42 PM
70mm is 2.76". It's hard to answer your question without knowing the design specifics of your scope. Do some measurements and lay them out here The 70mm could turn out to be oversized or undersized. Unless you plan on doing photography, shoot for a fully illuminated field of 1/2". Here is another calculator
#6 FirstSight
FirstSight
    Duke of Deneb
  • Loc: Raleigh, NC
Posted 28 April 2013 - 08:15 PM
I have the 2.6" Protostar Quartz secondary in my 12XTi (which optically is identical to your XX12i). I don't notice any significant loss of field illumination using that size secondary.
#7 mak17
mak17
Posted 28 April 2013 - 09:45 PM
What's the widest field eyepiece you're using and do you see a difference between the protostar and stock diagonals?
#8 cliff mygatt
cliff mygatt
  • Loc: Kitsap County, WA
Posted 28 April 2013 - 09:47 PM
I have the 2.6 inch protostar in my Orion XT12i as well with no problems!
#9 cliff mygatt
cliff mygatt
Posted 28 April 2013 - 09:48 PM
I use ethos EPs up to 21mm with no worries!
#10 FirstSight
FirstSight
    Duke of Deneb
  • Loc: Raleigh, NC
Posted 29 April 2013 - 05:08 AM
21 Ethos and 31T5 Nagler, with no worries with either.
#11 mak17
mak17
Posted 29 April 2013 - 09:06 AM
Thanks guys.
#12 jrbarnett
  • Loc: Petaluma, CA
Posted 29 April 2013 - 11:09 PM
Out of curiosity, what's wrong with your current secondary?
#13 mak17
mak17
Posted 30 April 2013 - 04:41 PM
Nothing. I just want a premium secondary.
#14 mak17
mak17
Posted 01 May 2013 - 06:05 PM
Did u guys have to buy a new secondary holder?
#15 FirstSight
FirstSight
    Duke of Deneb
  • Loc: Raleigh, NC
Posted 01 May 2013 - 06:36 PM
No, it's not necessary to replace your secondary holder in order to replace the secondary on any of the Orion XT line of reflectors. When I had an XT8, I replaced the stock secondary with an Antares tenth-wave secondary. With my 12XTi, I electively replaced *both* the secondary mirror *and* the entire spider/secondary assembly with Protostar models, but I could have instead just replaced the secondary mirror and used the stock Orion secondary holder to mount it on.
#16 dan777
dan777
  • Loc: Indiana
Posted 01 May 2013 - 06:42 PM
Happy Birthday Chris.
#17 mak17
mak17
Posted 01 May 2013 - 08:09 PM
Thanks Chris and happy birthday. I plan on buying the 1/18 wave Antares optics 2.6. Hopefully I can see a brighter image.
#18 mak17
mak17
Posted 01 May 2013 - 08:11 PM
What could I ask for the stock secondary? 30?
#19 UmaDog
UmaDog
  • Loc: Basel, Switzerland
Posted 02 May 2013 - 04:50 AM
By all means upgrade if you want, but if you're buying it to see a brighter image, then I wouldn't bother. Even if it's 10% brighter, you'd be hard-pressed to notice that without a simultaneous side-by-side comparison. Depending on what's on your scope, there might be other upgrades out there which provide greater bang for the buck.
#20 planet earth
planet earth
Posted 02 May 2013 - 05:44 AM
I wouldn't sell it until you have the new secondary installed.
I paid $20.00 plus shipping for a used GSO 2.75" with the holder.
Sam
#21 mak17
mak17
Posted 02 May 2013 - 08:21 AM
I've compared standard diagonals in refractors to high end diagonals and to my eyes the difference is obvious. Hoping this will be just as obvious. Subtle but clearly better. Well if there's no resale value I won't bother w the hassle of taking pics and making an ad then boxing it up going to post office. Keep it as a backup just in case.
#22 planet earth
planet earth
Posted 02 May 2013 - 09:45 AM
If there is no one in your area to test your oem secondary fairly cheap, then replacing it (may) provide better images.(which I hope it does).
What are the chances? 50/50, so not so bad of odds.
Clear Skies
Sam
#23 mak17
mak17
Posted 02 May 2013 - 10:14 AM
Good point.
#24 NewMoonTelescope
NewMoonTelescope
    Vendor
  • Loc: Upstate NY
Posted 02 May 2013 - 10:23 AM
I second Antares Optics out of Rochester. I use them almost exclusively and have yet to get an underperformer.
Darker skies,
Ryan
#25 mak17
mak17
Posted 02 May 2013 - 12:28 PM
Ryan those scopes look amazing. Thanks for weighing in.
