Error 16 or 17?
4 replies to this topic
#1 James Cunningham
James Cunningham
  • Loc: Maryland
Posted 28 April 2013 - 08:47 AM
What would cause an intermittent Error code 16 or 17? This is recent. I have to hit "undo" to get it back communicating. It has happened the last 2 nights. It will not cause me to lose my alignment. Thanks.
#2 dragonslayer1
dragonslayer1
  • Loc: SLC, UT
Posted 28 April 2013 - 12:51 PM
Hey Jim, from all I read the easiest way to trouble shoot it is a power problem; spread power pin on scope or verify power supply is good and rock steady
Kasey
#3 bogg
bogg
  • Loc: Bruce County Ontario
Posted 28 April 2013 - 05:39 PM
As dragonslayer1 says check the power supply. Another problem I have had are the pins and connectors from the handset to the scope and to the dec housing. Replacing the connector on the wire end solved mine. Good luck
#4 jchaller
jchaller
  • Loc: Tenino, WA.
Posted 01 May 2013 - 08:50 PM
I've had this occur several times, and it was just a bad power connection at the scope.
#5 orion61
orion61
  • Loc: Birthplace James T Kirk
Posted 03 May 2013 - 08:04 PM
YUP I had that, it was my Battery, try an A/C adapter the error will go away..NBD,
good luck
