Who can tell me?
4 replies to this topic
#1 biggles
biggles
Posted 01 May 2013 - 02:02 AM
:question:First off I would like to make it clear that I am an experienced Meade ETX user and fully experienced in the correct set up of these great 'scopes!...so my question is this: I often enjoy the 'tonights best'feature of my Meade etx 125 and always have objects placed in the field of view of my 26mm eyepiece.
This holds true through out the guided tour.
I then often like to do it again, and this is where things go wrong.All most nothing is in the field of view in the eye piece!! Why does this happen?...near as **** it every time?...I am SOOO careful not knock any part of the set up to mess up alignment. My lx 90 10" (before I de-forked it)would do the same thing,..just interested as to why! :question:
#2 cuivienor
cuivienor
  • Loc: Tokyo, Japan
Posted 01 May 2013 - 02:41 AM
I have to say I haven't noticed problems like that - I did run several times through the tonight's best with my ETX125, with no issues.
My guess is that there could be some grease in the encoder wheel of on of the axis, so that slowly the scope loses track of exactly what is where. Alternatively the drive training values are not perfect and so the accumulated backlash over the first session starts to reduce its accuracy.
Otherwise I wouldn't be able to tell...
Yannick
#3 biggles
biggles
Posted 01 May 2013 - 03:44 AM
Thanks Yannick, I did not think of either of those possibilities. The 'scope is probably a good ten years old, although this wound not normally be a problem, the person who owned it before me was not careful about storing it and did not use it more than 5 of 6 times, so it is certainly possible. The forecast here in Suffolk England U.K is clear for tonight so I can train drives and stuff then.
clear skies and clean glass
Mike :)
#4 redlinedb16a
redlinedb16a
Posted 01 May 2013 - 09:02 PM
Sometimes I'd re align my scope and that would correct it
Make sure the home position is correct,the less you have to slew to the alignment stars the more accurate
Also make sure you have a strong power supply,freash charged batteries
Completely level
#5 Geo.
Geo.
  • Loc: Upstate NY
Posted 07 May 2013 - 08:31 AM
Probably just an accumulation of small errors. Working on the calibration and backlash settings may help, but realigning should be a cure.
