mallincam with c11 f3.3
21 replies to this topic
#1 highfnum
highfnum
  • Loc: NE USA
Posted 01 May 2013 - 05:30 PM
it was nice last night so
i took out the little beasty(C11)
and took a few shots - its been awhile
M51 M97 M 81
#2 highfnum
highfnum
  • Loc: NE USA
Posted 01 May 2013 - 05:31 PM
m97
#3 highfnum
highfnum
  • Loc: NE USA
Posted 01 May 2013 - 05:32 PM
m81
#4 Dwight J
Dwight J
  • Loc: Lethbridge, Alberta, Canada
Posted 01 May 2013 - 05:34 PM
The C11, F 3.3 focal reducer, and Mallincam make a great combo. I use the same setup to great effect. Nice grabs!
#5 dragonslayer1
dragonslayer1
  • Loc: SLC, UT
Posted 01 May 2013 - 09:49 PM
very nice pictures, you have a ballpark integration time on the M51 shot please?
Kasey
#6 highfnum
highfnum
  • Loc: NE USA
Posted 02 May 2013 - 03:03 AM
51 was 56 sec
#7 Larry F
Larry F
  • Loc: Westchester, NY
Posted 02 May 2013 - 08:30 AM
Nice, John!
#8 Atl
Atl
Posted 02 May 2013 - 08:31 AM
Question about the colored stars. Are they the actual color or is this an artifact? My camera was doing this last night but I wasn't sure what to make of it.
#9 highfnum
highfnum
  • Loc: NE USA
Posted 02 May 2013 - 08:35 AM
some of that square looking green blue red looking stars are
'hot pixels' not real stars
1) did not have TEC on
2) proper way is to create a dark frame and subtract to get rid of them
3) these pictures are 'graps' as you see them on HDTV
#10 highfnum
highfnum
  • Loc: NE USA
Posted 02 May 2013 - 08:37 AM
thx larry
#11 Atl
Atl
Posted 02 May 2013 - 09:55 AM
Ok thanks...I am still figuring out what's going on with the images I am seeing.
#12 dragonslayer1
dragonslayer1
  • Loc: SLC, UT
Posted 02 May 2013 - 10:27 AM
thank you, you are using hyperstar it would seem with such a fast focal length? Which camera are you using? thank you, Kasey
#13 highfnum
highfnum
  • Loc: NE USA
Posted 02 May 2013 - 10:58 AM
no hyperstar- simple f3.3 SCT focal reducer/corrector
hyperstar is faster than that(2.0)
MCHP - mallincam today its considered older model
#14 nytecam
nytecam
  • Loc: London UK
Posted 02 May 2013 - 12:51 PM
no hyperstar- simple f3.3 SCT focal reducer/corrector hyperstar is faster than that(2.0)
Hi - excellent pics :bow: is hotpixel removal post processing? Regarding the quoted f/3.3 FR - is that a nominal value or the actual f/ratio on the scope? The two may not be the same. I run my nominal 3.3 FR @ f/3.6 but who am I to get technical :lol:My Owl PN from last night via Lodestar in 60s exp :rainbow:
#15 GlennLeDrew
GlennLeDrew
Posted 02 May 2013 - 01:10 PM
With my Meade f/3.3 reducer and Mallincam (with CCD 12.5mm below the lens mount's front surface), the 60mm long 2" visual back w/ 2"-1.25" adapter results in exactly f/3.3. This tells me that the focus must lie 72.5mm from the shoulder on the reducer's cell. This shoulder I refer to is the edge which a threaded on adapter stops against.
It could be the case that more recently made reducers are somewhat different in dimensioning...
#16 highfnum
highfnum
  • Loc: NE USA
Posted 02 May 2013 - 01:13 PM
I don't know
#17 highfnum
highfnum
  • Loc: NE USA
Posted 04 May 2013 - 07:36 AM
a little late adding m101 same set up
#18 FishInPercolator
FishInPercolator
  • Loc: NYC
Posted 18 May 2013 - 02:17 PM
How did you achieve a f/3.3? I asked around how to do this with a C6 f/10 and was told with the Universe version there are inevitable problems due to chip size.
#19 A. Viegas
A. Viegas
  • Loc: New York City/ CT
Posted 18 May 2013 - 02:56 PM
Jason -
For focal reduction in a typical SCT at prime focus you can either use the Celestron or Meade F6.3 of F3.3 correctors, these you can usually find around used for $75-90. For Mallicam specifically, there is a MFR5 focal reducer you can buy that comes in two pieces, and can be put together in such a way as to get from 0.39 - 0.8x in reduction. This adapter costs $250. The FL on a C6 is what ~1500mm ? so I think you could probably achieve good results using a stock F6.3 corrector. I am not sure if the F3.3 corrector would produce too much vignetting on the C6...
Al
#20 Stew57
Stew57
  • Loc: Silsbee Texas
Posted 18 May 2013 - 03:55 PM
The chip size in the Universe is much larger than the mallincam extreme, X2, or VSS. Focal reducers work well with the smaller chips. You will get vignetting with the Universe with the above mentioned reducers. Celestron makes a specific reducer for large chip cameras and the HD line of scopes. These should work fine. There may be others but the reduction factor is limited.
#21 johnpd
johnpd
  • Loc: Green Valley, AZ
Posted 19 May 2013 - 04:44 AM
The camera he was using was the older MHCP (Mallincam Hyper Color Plus) not the Universe. With the smaller chip Mallincams, f/3.3 works fine. Also, as I recall Rock saying, the Universe is more suitable for larger telescopes.
JohnD
#22 GlennLeDrew
GlennLeDrew
Posted 19 May 2013 - 09:36 PM
The Universe would work well with ordinary camera lenses too. It's not the aperture itself which is so important, but rather the field size you wish to cover. With Universe you could attach an 8mm f.l. (~4mm aperture!) fisheye lens to obtain an all-sky image.
