Baader GPC
13 replies to this topic
#1 MAURITS
MAURITS
  • Loc: Belgium
Posted 03 May 2013 - 03:18 PM
Can I do something with the "Baader 2.6x GPC" in my refracter and the Mark V, becauce I read at the Baader instructions that it's specially designed for newtonian telescopes! :confused:
Thanks! :waytogo:
#2 denis0007dl
denis0007dl
    Vendor (Binoviewer Supercharging)
  • Loc: Umag, Croatia
Posted 03 May 2013 - 03:31 PM
Baader GPC 2,6 is universal, so you can use it with any kind of scope, but difference between 2,6x and 1,25x & 1,7x is different position, and this position you can find on instructions and many posts on this forum.
It is reverse position, but there exists one trick: yo can use it in usuall position on MkV body if you unscrew GPCs metal ring which holds 2,6 lens, and reverse lens, and turn it back in GPC housing!
#3 MAURITS
MAURITS
  • Loc: Belgium
Posted 03 May 2013 - 03:38 PM
denis0007dl, thanks a lot for this tip and info!
#4 denis0007dl
denis0007dl
Posted 03 May 2013 - 04:12 PM
No problem, if you have any further questions, do not hasistate to ask me :)
#5 Astrojensen
Astrojensen
  • Loc: Bornholm, Denmark
Posted 03 May 2013 - 04:23 PM
Do notice that the 2.6x GPC has an air-spaced lens and MAY be tricky to work with, if you choose to reverse it in the cell.
It does work splendidly well in refractors, BTW.
Clear skies!
Thomas, Denmark
#6 denis0007dl
denis0007dl
Posted 03 May 2013 - 04:33 PM
Clear skies!
Thomas, Denmark
This is not true in my case, 2,6 GPC does not have air-spaced lens, so there is no fear of nothing, just turn over lens, and thats it!
#7 Astrojensen
Astrojensen
Posted 04 May 2013 - 02:54 AM
:shocked: Okay, this is news to me, first I've ever heard of a Baader 2.6x GPC with cemented lens.
Now, I know this will all sound very anal, but are you *sure* it's a 2.6x GPC unit, despite what it says on the cell? I once bought a 1.25x GPC that turned out to have a 1.7x GPC lens installed...
I just checked my own 2.6x GPC, bought last year, and it's definitely air-spaced.
Clear skies!
Thomas, Denmark
#8 denis0007dl
denis0007dl
Posted 04 May 2013 - 04:01 AM
Clear skies!
Thomas, Denmark
:shocked:
Really yours air spaced?
Mine was 100% cemented, maybie was difference in year of production, I buy it 3 years ago from Teleskop Service in Germany, and reverse lens tat I can use it normally.
Very interesting, but I believe that there is no difference in opticall quality.
I can relate this with Baader Maxbrights binos, in past screws touch eyepiece barells directly, now they have comprehantion rings! I know, this is not about optics, but for sure some changes are made through years optically and mechanically.
#9 MAURITS
MAURITS
  • Loc: Belgium
Posted 04 May 2013 - 05:36 AM
Well, mine is on order and I'll let you know what I get!
#10 DaveJ
DaveJ
  • Loc: NE Ohio
Posted 04 May 2013 - 10:12 AM
My 2.6 GPC is definitely air-spaced.
#11 denis0007dl
denis0007dl
Posted 04 May 2013 - 10:39 AM
Interesting,probably performance between air spaced and cemented does not exists, or is very subtile.
#12 Mark9473
Mark9473
  • Loc: 51°N 4°E
Posted 04 May 2013 - 10:52 AM
So how do you see the difference short of opening it up?
#13 Astrojensen
Astrojensen
Posted 04 May 2013 - 10:57 AM
In mine you can see a thin plastic ring between the lenses, like in many small objective lenses. A comparison with the 1.25x GPC showed no such ring in this lens. It would probably also be possible to do a green laser scatter test, but I haven't tried that.
Clear skies!
Thomas, Denmark
#14 denis0007dl
denis0007dl
Posted 04 May 2013 - 11:00 AM
My GPC lens was cemented in one piece, it was easy to reverse lens, but even if you have air spaced lenses, it was probbly two pieces, just put it out, reverse, put it back!
