ZAO I vs. ZAO II...?
102 replies to this topic
#1 Levine
Levine
  • Loc: 40° 47' 52" N / 85° 49' 14" W
Posted 05 May 2013 - 12:04 PM
I recently corresponded with a friend overseas. He had bench tested the two generations of ZAO's with a laser interferometer, and found the results to be so dissimilar that he felt that there was hardly basis for comparison.
He much prefers and recommends the I's over the II's
Now, those are his eyes, and all of our eyes are FAR less sensitive than an interferometer.
So the question: given the following conditions -
Dark and steady skies with optimal seeing
An optically perfect telescope
Sample EP's from both batches selected at random
An experienced observer who has worked with "good" orthos for a long period of time
- would any *MEANINGFUL* differences in performance be detected?
Any of you who have had "head to head" experience with these pieces, please tell us about your observations and preference.
:cool:
#2 leonard
leonard
  • Loc: West Virginia
Posted 05 May 2013 - 12:34 PM
Hello ,
He much prefers and recommends the I's over the II's <<<<<
Which brings up the question , what did this test show your friend ????????????????????????
:help:
#3 Levine
Levine
Posted 05 May 2013 - 01:19 PM
Hello ,
:help:
Only that the resulting diffraction patterns were different.
That's all. :o
#4 leonard
leonard
Posted 05 May 2013 - 02:24 PM
Hello Levine,
IMO , this test your friend did would have no bearing on the optical performance of these two eyepieces . I may be wrong but both the Zeiss 1 an Zeiss 2 are excellent .
The fact this person is basing his judgement on a different pattern says nothing at all.
Leonard
#5 Jeff Morgan
Jeff Morgan
  • Loc: Prescott, AZ
Posted 05 May 2013 - 02:39 PM
Good question.
Send me a set of each and I'll get back to you in a year. :grin:
  • PeterWar likes this
#6 Levine
Levine
Posted 05 May 2013 - 02:41 PM
Hello Levine,
Leonard
Right...Interferometry, and viewing with one's eye, are two different things: you cannot directly infer or predict "real world" perfomance based solely upon bench testing.
:thinking:
#7 SteveC
SteveC
  • Loc: Sunshine State & Ocean State
I compared both sets and couldn't find any visual differences, other than the fact that ZAO I's were available in 25mm and 34mm (?). I kept the ZAO II's because they were newer and sold off the I's..............except for the 25mm, which I still own.
#8 Levine
Levine
Posted 05 May 2013 - 02:44 PM
I have the 34 and 25 ZAO I's, plus the II set.
My eyes, 'scopes, and seeing are all so-so.
Given that, I have found no reson to complain.
:smirk:
#9 johnnyha
johnnyha
  • Loc: Austin, TX
Posted 05 May 2013 - 02:55 PM
The ZAO-IIs are supposed to have better edge correction for faster scopes, down to f4. Whether this makes a difference on axis I dunno since I don't have any ZAO-Is for comparison.
#10 SteveC
SteveC
Posted 05 May 2013 - 03:42 PM
:smirk:
You're a lucky guy, that 34mm ZAO is a rare bird. I gave up my search for one a couple of years ago, just too difficult to find.
#11 Levine
Levine
Posted 05 May 2013 - 04:31 PM
:smirk:
Pieces like this require determination, to be sure!
Acquisition requires 4 ingredients:
Time
Persistence
Ready cash
LUCK
When one finally came up for auction, I refused to allow it to slip away.
In my experiece, just about any EP you could imagine can eventually had, if you just stick to your guns.
For example, I once assembled a FULL Set of Clave focal lengths, including the 2" pieces.
I did it in 11 months.
10 piece Silvertop set? Two weeks.
Etc...
:tonofbricks:
#12 Paul G
Paul G
  • Loc: Freedonia
Posted 06 May 2013 - 05:42 AM
:cool:
I've side-by-sided the I's and II's, both mono and binoviewing with the Mk V, in several scopes including the following Astro-Physics refractors and Mak-Cass:
92 mm f4.9
92 mm f6.6
105 mm f5.8
130 mm f6
130 mm f6.3
155 mm f7
175 mm f8
254 mm f14.6
I've seen no noticeable difference between the I's and the II's. It's possible that one might notice a slight difference in edge correction in a fast scope if one were observing in an area with excellent seeing, but that's not where I live. In our seeing here, no difference.
The real gems of the I's were the 25 and 34mm. I was disappointed they didn't include those focal lengths when they brought out the II's.
#13 ManuelJ
ManuelJ
  • Loc: Madrid, Spain
Posted 06 May 2013 - 06:14 AM
ZAO II: less afov, better corrected for fast optics
ZAO I: less eye relief, I like the eyecup of the 16
That's all, folks ;-)
  • edif300 likes this
#14 vahe
vahe
  • Loc: Houston, Texas
Posted 06 May 2013 - 06:40 AM
Two ways to look at this:
1 – Newer is always better, be that an eyepiece, a camera, a car or whatever, if you subscribe to this theory then there is your answer !!!!
2 – I took that question to ap-ug and got an answer from Roland (#61232 & #61241)
According to Roland;
“They are optically the same, mechanically a bit different. The newer ones have smaller field stops because a few picky people complained in the past that the outer part of the field were not sharp in the version 1, so Baader had them made with smaller field stops.”
And for coatings;
“I have both and they look quite similar, I am not sure there was any great improvement. Both types produce very dark fields and both produce the same sharp planet images.
I have three pairs of version 1, 16, 25 & 34mm, with my F/20 Maks the 34mm offers the finest planetary views of any eyepiece, head and shoulder above all else including ZAO-25 and 24mm Brandons which are my only eyepieces that rival Zeiss on planets.
Vahe
#15 Levine
Levine
Posted 06 May 2013 - 06:48 AM
And for coatings;
Vahe
Great stuff!
:bow:
#16 Scott99
Scott99
  • Loc: New England
Posted 06 May 2013 - 09:58 AM
there is one obvious difference.....the dreaded undercut. ZAO I has it and also the sliding eyeguard
#17 Scott99
Scott99
  • Loc: New England
Posted 06 May 2013 - 10:02 AM
Interesting, I don't do much planetary with the longer ones but I've heard this before - people also liking the 25mm orthos best for planetary and just using barlows to get to higher magnfication.
Could it be that larger lenses somehow deliver better contrast? Maybe because the light is spread out over a larger area of glass. People have been saying for a long time that you get better contrast with a high quality Barlow + ortho rather than with an eyepiece with a tiny integrated barlow, could be the same effect.
#18 Sarkikos
Sarkikos
  • Loc: Per sylvam ad astra
Posted 06 May 2013 - 10:05 AM
Take into account that his Mak is an f/20.
:grin:
#19 Paul G
Paul G
  • Loc: Freedonia
Posted 06 May 2013 - 10:12 AM
Obligatory pic:
  • jack45 and GeneT like this
#20 Sarkikos
Sarkikos
Posted 06 May 2013 - 10:13 AM
Scott,
FWIW, my XO 5.1 showed more perceived contrast and ease of discerning surface detail than my BGO 5. The XO 5.1 has 5 elements in 3 groups, the BGO has 4 elements in 2 groups. Some observers have said that the XO's are at the same level as the ZAO's.
I think that how well an eyepiece with an integrated Barlow (Smyth lens or whatever) performs might vary quite a bit from eyepiece to eyepiece. I usually avoid separate Barlows except to bring my binoviewer to focus in my Newts.
#21 SteveC
SteveC
Posted 06 May 2013 - 10:15 AM
:grin:
That's the reason why I stopped searching for the 34mm ZAO, not enough power even for my f/15 Mak...................that and the cost, I'm retired and on a budget. I'm waiting for my wife to break her budget deal - I need another mount.
#22 vahe
vahe
Posted 06 May 2013 - 11:28 AM
For visual astronomy there are three factors that contribute to a satisfactory performance, scope, eyepiece and the eye. Eyepiece and eye interface and compatibility is one reason why super high quality short focal length and short eye relief eyepieces just do not deliver the same level of performance as the longer focal length eyepieces.
I have tried 4 & 6mm ZAO eyepieces and decided thanks but no thanks, not for my eyes.
Of course with longer focal length eyepieces one will need long focus telescope if high magnification is the goal.
Optically a 4mm and 25mm ZAO may be of equal quality but not when you factor in the limitation imposed by our eyes, or at least my eyes for sure.
Vahe
#23 csrlice12
csrlice12
  • Loc: Denver, CO
Posted 06 May 2013 - 11:46 AM
My only Zeiss lens is the one in my smartphone camera. Therefore, I'm volunteering; send me your losing ZAOs and I'll make sure they're properly diciplined (may take a few years, you know how those ZAOs can be).
#24 Paul G
Paul G
  • Loc: Freedonia
Posted 06 May 2013 - 12:19 PM
It's interesting how tastes differ. After the ZAO I's sold out and started to come up on the used market, the 4mm seemed the least wanted in the US but in Europe it was the most wanted of the set and commanded the highest prices used.
I used to cut off my eyelashes to use the 4 and 6mm, now I just use an eyepiece with greater eye relief.
#25 Starman81
Starman81
  • Loc: Metro Detroit, MI, USA
Posted 06 May 2013 - 12:55 PM
Obligatory pic:
Obligatory WOW! :bigshock:
