Meade 12V pwr cord tip polarity
7 replies to this topic
#1 flygal6
flygal6
Posted 05 May 2013 - 12:51 PM
I have a meade 12v pwr cord and one of the wires pulled out of the tip. I unscrewed the collar with the intent of making repairs and resoldering the wire to the tip. To make a long story short, then the connection tip broke off totally. Off to radio shack I go. I purchased a 12v 5amp power cord and the correct adapter tip (this was the only type they sold). My first question is this power cord safe to use as a replacement? Second does anyone know if the original cord has a positive or negative tip polarity? I need to know this to make sure I put the tip on correctly and not get it reversed.
Thanks Carol
#2 Whichwayisnorth
Whichwayisnorth
  • Loc: Southern California
Posted 05 May 2013 - 01:03 PM
Center is positive, outside ground.
#3 highertheflyer
highertheflyer
  • Loc: Aledo, Texas
Posted 05 May 2013 - 08:44 PM
This statement so true, and never ever, to cross the polarity!
Make certain you find a way to always connect the positive to the positive, red to red, big prong to little prong, etc....!
Perhaps someone here on Cloudy nights can come up with a way that would protect your choices in the wee hours of the night and as a backup, not allow you to cross connect.
#4 flygal6
flygal6
Posted 05 May 2013 - 08:58 PM
Thanks - it worked!
#5 nitegeezer
nitegeezer
    Galactic Ghost
Posted 05 May 2013 - 10:24 PM
I have thought of putting a bridge rectifier on the inside of that connector to make it a don't care. That would protect polarity issues, but I am not sure if the 1.5v drop across the bridge would be too much. I don't want to protect myself from one problem and just create another. It all depends what the lower limit is on the power requirements.
#6 OzAndrewJ
OzAndrewJ
Posted 05 May 2013 - 10:38 PM
Gday NiteGeezer
You also need to be careful re ground loops doing this as well.
ie items coming off the same battery/supply, then directly connecting to the scope, like guiders etc.
One way to protect agains reverse polarity is to use a reverse biased PChannel Mosfet in the supply line, and wire it up so it will only ever open if the polarity is correct.
A simple test utility is to get a multi colour LED ( or wire 2 LEDs back to back ) in a plug unit.
Put the cable into the unit and one of the LEDs will always glow
and the colour tells you the polarity.
#7 nitegeezer
nitegeezer
    Galactic Ghost
Posted 05 May 2013 - 11:20 PM
That looks like a great idea.
Up to now I have not worried about ground loops because I was pretty much a visual user. I am now going to get serious about ap, so I know there are issues. My Canon camera by itself would be no problem as there would be no interesting current paths to worry about, but I have decided to operate my camera remotely from a laptop so I know I am going to have to be careful. I am going to see how well I can do without guiding, I consider this more a learning experience rather than going for the perfect shot that first night. I will spend this summer learning what I can do with what I have, and then during the winter look at guiding to see how that would help. By taking little steps, I hope to avoid the ground loop issue. I have put large systems together in the past, and tracking down a ground loop with a large system is a nightmare, so I like to grow things a little at a time.
#8 MarkyN
MarkyN
Posted 06 January 2016 - 12:12 AM
Normal diodes drop about 0.6V but when passing significant power can go past 1V.
However, a better option is a type of diode called a Schottky diode (which are commonly used in switch mode power supplies) and only drop about 0.2V and perhaps about 0.7V under power.
I've read on Weasner that people have damaged ETX-125's because they are not reverse polarity protected and I guess most other telescopes will not be either.
The 1N5822 is a high power Schottky diode (see www.digikey.com) and should be suitable for telescopes that use less than 3A.
Without this, playing around with 12V batteries and croc clips in the dark would be a recipe for disaster.
Edited by MarkyN, 06 January 2016 - 12:19 AM.
