Binoviewing Deep Sky
41 replies to this topic
#1 Eddgie
Eddgie
Posted 06 May 2013 - 10:28 AM
Spring is not my best season. I live under marginal sky conditions, being near the geographic center of a metropolitan area of 2 million.
That doesn't stop me from doing a lot of observing, but it does tend to restrict me to only the brighter galaxies, and even then, they are not usually compelling.
Last night, I did do some observing and as expected, I find the binoviewers to not be maybe neutral in terms of viewing Galaxies. I viewed several bright galaxies, and found that while they generally only a tiny bit dimmer than when using Monovision, and I was able to locate all of them that I have seen in the past with Monovision with no difficulty.
Planetary Nebula are great in the Binoviewers, and here I perceive a positive difference. Many Planetary Nebula are quite small, and often do contain some detail or structure that can be perceived, and I think these objects do look better in binoviewers. They often seem to show more graduation where as in Monovision, they appear more as being more evenly illuminated.
Globulars... Ahhhhhhh. This is a class of object that simply looks so much better in binovision that it makes it difficult to go back to viewing them mono.
Last night, I was out for a while under so-so seeing, so Saturn was not really putting on much of a show (sure, I could see a lot, but I wanted to try to resolve the Hex polar feature and last night was not the night, because I think this is a feature that is going to require some serious magnification).
Anyway, I did a bunch of doubles, and finally worked my way to M3 and M5.
Both were easy and bright in the C14 with the 40mm Plossls (about 100x).
But the more power I put in, the better they each looked.
At 308x (13mm Hyperions) these clusters were simply fantastic.
M3 is much tighter than M5. The brighter "Ball" easily took up about the central 25% of the field, but the outlying stars easily stretched out to maybe 60% of the field diameter, but there were other stars in the field all the way to the field stop.
I have to assume that these are also member stars.
The catalogs list the size as 18 arc minutes, and the 13mm Hyperions should only be showing about .23 degrees (about 15 arc minutes?) so from an angular diameter, it would appear that most of the stars in the field were cluster members. But the concentration towards the center was easily imagined as the cluster itself.
It was beautiful, but there are not a lot of bright stars, and while the core was not fully resolved, there were stars visible across the entire ball, so partially resolved for sure.
Because of the lack of brighter stars, I did not get as an immersive effect as with some of the brighter Globulars, but it was still a mildly 3D view.
M5 though was simply spectacular.
The linear size is listed at 23 arc minutes, so it should have overrun the field, and once again, the field was full of stars, but the concentration was mostly in the center 305% of the field.
Here though, there are many bright stars that extend far away from the center. I would guess they extended over about 60% of the field in the eyepiece and because of these bright stars, the cluster had that strong 3D illusion.
The core was much better resolved (not as well as for M13 of course) but the broader distribution of brighter stars really makes this a standout Globular.
Seeing it in the Binoviewers this year (this was the first time I have seen it in Binoviewers) was a real treat.
I think this for Deep Sky, small bright clusters and Planetary Nebula are by far and away the most fun to observe because of the impressiveness you get from the binoviewers.
I am trying to like them for galaxies though, and while they work well enough, I don't find them as compelling to use for this application.
Anyway, M3 and M5 at high powers in the binoviewers looked better than I have ever seen them.
I am going to do a dark sky trip in the next month. Can't wait. I have yet to use them under really dark skies, and will make sure I do a report.
#2 Mike B
Mike B
    Starstruck
  • Loc: shake, rattle, & roll, CA
Posted 06 May 2013 - 10:46 AM
I concur with your take on Globs in a BVer- simply astounding! The 3D effect is palpable (tho yes, illusory ;))!
I suspect everyone's eyes are different, or should i say eyes-brain? But for me, BVing helps pretty much across-the-board... galaxies, nebulae, you-name-it! The only time i revert to mono is for higher mags & ultimate detail- like structure in a planetary nebula, Saturn's rings, etc. I find "mono" doesn't help my eyes so much for faintness & magnitude reach, but for ultimate sharpness of image. It's subtle, to be sure, and the conditions (Don's "3-C's") must be pretty decent for me to see it... but i'm certain it's real.
Have been a dedicated BV user (Denk II) for nearly a decade, and it's been the sharp optics of my Dob (just now 5 years, this month! :jump:), plus the introduction of EPs like a Pentax XW, Brandon, & CJZ Ortho that has helped me see the sharpness difference, and returned me (somewhat) to the joys of "mono" viewing. But that's me, and my eyes.
Good plan! Get that big CAT under some dark skies!
:waytogo:
#3 denis0007dl
denis0007dl
    Vendor (Binoviewer Supercharging)
  • Loc: Umag, Croatia
Posted 06 May 2013 - 10:58 AM
GREAT review!!!
I want to add, few days ago, I was looking Orion Nebula, M81 & M82 with my 10" dob, 28mmRKEs + Mark V, and views were breathtaking!!!
I am long time ago forgot how it to do astronomy with monoviewing!
#4 pftarch
pftarch
Posted 06 May 2013 - 11:41 AM
M13 with 28 RKE's/Powerswith on my Z10 is like you are falling into it. And yes, it loves to have the magnification stoked up.
My prime viewing area is my light polluted backyard, so galaxies are questionable no matter how many eyes you use. I was poking around the Virgo Cluster last night and having fun with two eyes. I prefer bino to mono for galaxies (although locating them with the bino's is a bit of a chore). As I don't tend to get much detail with one or two eyes, it's just more relaxing using two. For me, I find I notice more by staring at something for ten minutes straight in a relaxed mode rather than squinting with one eye for only a few minutes. Again, I would hardly call my self a "discerning" viewer. (I notice the same "see more relaxed" effect on planetary detail also.)
Peter T.
#5 REC
REC
  • Loc: NC
Posted 06 May 2013 - 12:41 PM
Nice report and I look forward to my first views of a globular in my BV.....IF it ever clears up :(
#6 Kent10
Kent10
Posted 06 May 2013 - 01:37 PM
Fun report to read, Ed. Thanks. I am a somewhat inexperienced observer but your impressions were exactly mine just last week. My old scope is a Meade 8" F6.3 with a huge CO so I had seen globular clusters before but they were really just smudges of light. With my relatively new Tec 160FL the globulars were easy to resolve with many stars seen at moderate powers. I have tried mono and I haven't done a lot of comparisons yet but for me, too, I enjoy the binos so much more even if it may be dimmer. I still want to do more testing on my own to see what I am missing and gaining with mono/bino. But I enjoy the view so much more with the binos. With the galaxies, I wasn't so sure. I was only doing some casual observing in my backyard and my eyes were not always very dark adapted but it seemed to really appreciate these in the bino I thought to myself I need to better dark adapt my eyes next time so that I can see more. I have dark skies living in a "dark sky" city but there were a few lights on in the neighboring homes. I use a hooded vest that helps.
Another thing I wanted to test and compare was the difference in sharpness with binos over mono. I had trouble getting really sharp stars the other night with my Mark V. I think it could have been the seeing but to be sure next time I will compare to mono. Have you noticed any differences in sharpness of stars with the binos? I wonder if double star viewing would be better with mono.
Lots of fun. I always wish I had more time!
#7 Eddgie
Eddgie
Posted 06 May 2013 - 01:50 PM
I have not noticed any loss of sharpness at all. Stars look every bit as sharp to me as monovision.
Here may be what is happening though. It could be that minor flaring of the first ring of a star that is caused by seeing was previously not easily seen, and the binoviewers may be helping you resolve it.
Anyway, I fine the Mark Vs to be superb optically. There is one issue that a bright star in the field can sometimes though a little reflection, but I have only noticed it a couple of times. The star has to be in just the right position, and not in the center of the field.
Never been an issue for me though.
#8 HowardK
HowardK
Posted 06 May 2013 - 02:28 PM
Kent...
I too use a hooded vest but i find that my breath gets trapped and inside 20 secs the ep's get fogged up....
How do u cope with this?
#9 Kent10
Kent10
Posted 06 May 2013 - 02:36 PM
Thanks Ed. I am going to keep testing and I'll figure it out eventually.
Howard: Yes I have had the fogging up happen too. I haven't found a way to cope with it yet. I just take a break and then hold my breath more I suppose :) I am in the desert and it is dry here so maybe it clears quickly. I have read of some using a straw to breathe through but if the fogging is a result of your warm eyes then that may be a problem too. I have been using eyepieces with longer ER and that should help so the eye doesn't get too close. Maybe others have other ideas...
#10 HowardK
HowardK
Posted 06 May 2013 - 03:44 PM
I thought about a straw....but thats gonna be ridiculous!
Its not my eyes...its my breathing that fogs the eps up
I have a Dark Apparel hooded vest...it is a great help...deep pockets for stuff and a oversized hood.....but if i pull the hood over the top of the binoviewers then i will fog out.....the trick is to leave a gap
#11 Kent10
Kent10
Posted 06 May 2013 - 03:50 PM
:roflmao: Yea It will take a lot of fogging for me to want to try the straw trick. :roflmao:
#12 HowardK
HowardK
Posted 06 May 2013 - 05:08 PM
A monks hood
And a straw
Noooo
#13 Kent10
Kent10
Posted 06 May 2013 - 05:15 PM
I have one of the white vests with hood that I use for solar viewing too. The other day, a neighbor saw me from a distance and quickly went inside. I wonder what she thought :) I also had white gloves on for sun protection and I waved. I'll have to explain next time I see her. Her kids play with my kids so I feel an explanation is necessary or else they may no longer want our kids going over there.
#14 johnnyha
johnnyha
  • Loc: Austin, TX
Posted 06 May 2013 - 07:53 PM
That's hilarious!
#15 Mike B
Mike B
    Starstruck
Posted 06 May 2013 - 08:10 PM
Gives new meaning to "observing in the 'hood"
:lol:
#16 Arizona-Ken
Arizona-Ken
  • Loc: Scottsdale, Arizona
Posted 06 May 2013 - 09:07 PM
Binoviewing deep sky, eh?
As I've posted before, I have done the entire Herschel 400 with an EarthWin Binoviewer on a C11 with Pan24s or XW20s in the good skies here in Arizona. Piece of cake.
Oh, there probably will a point in time during the Herschel II list when some low surface brightness object or the dim mag 13+ stuff will have me go back to mono-viewing, but not yet.
Just sayin' ........
Arizona Ken
#17 Mike B
Mike B
    Starstruck
Posted 06 May 2013 - 09:29 PM
...when some low surface brightness object or the dim mag 13+ stuff will have me go back to mono-viewing, but not yet.
I'm thinkin' this varies by the observer, by the eye-brain combo of each individual.
There's no argument about the physics- the light pokin' thru each half of a BVer will be less-bright than before it was "split". But the summation-effect... THIS is what varies person to person!
For me & my eyes+brain, i'm convinced that brain-summation nets me essentially all what was "lost" in the optical splitting. I've gone back & forth b/t bino & mono, same or close magnifications, and it's a rare event to see mono what i can't see bino... it's down to percentages of time a faint star is seen- 50% in/out averted versus 75%. That close!
Yet for others i'm sure they've found differently. And some of that might be aperture-dependent?... a small scope showing the difference more profoundly? I dunno... haven't tried BVing anything less than 10-inches. 'Tis been 15-inches the past five years...
:shrug:
#18 denis0007dl
denis0007dl
Posted 06 May 2013 - 10:01 PM
Arizona Ken
Mark V will show more sharper image and little brighter than EarthWin Binoviewer!
I always seen more detailed with bino than with one eye. Whwn observe with one eye, my eye tyred for approx 2 hours, and then I can not concentrate to see picture at all, and with binos, I can observe whole night without strain my brain and eyes!
#19 Arizona-Ken
Arizona-Ken
Posted 06 May 2013 - 10:30 PM
Glad to hear others chime in about doing most of their gazing with a binoviewer.
Like anything else, equipment quality is important, size of the scope is important, and how your eyes/brain combination works is important. Everyone's experience varies a bit. Most people find that it is more comfortable to spend time looking with two eyes, and that you stay at it longer.
But a good set-up, with its corresponding cost, is not just for bright objects like the moon, planets, and the brighter M-objects. There are a lot of things to see and that can make the investment worthwhile.
I was lucky in the fact that one of my buddies has an EarthWin and I got a few chances to look through it. Of course, he keeps it in a case and hardly ever takes it out, while mine is out constantly.
Arizona Ken
#20 mark8888
mark8888
Posted 07 May 2013 - 04:08 AM
Here's my idea. I've posted it before, but for whatever it's worth, here it is. It blocks all the light, allows complete air flow (the materials should be very light, and note the open space in the front to allow for air movement between the lenses), is very light and comfortable, takes up virtually no space at all when folded, and costs less than $5 to make from dollar store components. "The Astronohat". :grin:
#21 HowardK
HowardK
Posted 07 May 2013 - 01:25 PM
Well.......
Its ugerly
#22 Mike B
Mike B
    Starstruck
Posted 07 May 2013 - 06:02 PM
True enough... yet for SOME of us :whistle: it might be an improvement?
#23 mark8888
mark8888
Posted 07 May 2013 - 07:54 PM
I tell you it completely eliminates the problem of stray light, causing no fogging at all, at no weight or expense. And it's quite dashing, really.
#24 Pinbout
Pinbout
  • Loc: uhmm...still in 2nd grade
Posted 07 May 2013 - 08:02 PM
I think the hooded vest should do something about the scary look...
#25 Kent10
Kent10
Posted 08 May 2013 - 08:41 AM
Here is more talk about fogging eyepieces.
http://www.cloudynig...wflat.php/Cat/1,2,3,4,5,8/Number/5521508/Main/5521042
You need to copy and paste the link.
