Video train not aligned?
3 replies to this topic
#1 James Cunningham
James Cunningham
  • Loc: Maryland
Posted 07 May 2013 - 06:44 AM
I have a Mallincam that I also use with a filter wheel. I had to cut down the filter wheel so that the camera did not hit the base of my mount. I am afraid that I did not make a straight cut and the camera is slightly mis-aligned with the scope. What kind of problems can this cause? Any effect on alignments? What about the images? Thanks.
#2 rmollise
Posted 07 May 2013 - 07:35 AM
Depends on how bad it is. It will be no mystery if you have this problem: stars on one side of the frame will be out of focus.
#3 GlennLeDrew
GlennLeDrew
Posted 07 May 2013 - 12:26 PM
As Rod notes, the primary problem is a tilted focal surface, which results in a systematic variation in focus across the frame.
#4 Dragon Man
Dragon Man
  • Loc: Snake Valley, Australia
Posted 08 May 2013 - 10:40 AM
G'day Jim,
you'll soon know.
I had my MCX a tiny fraction out of square and the stars were out of focus on the left side.
When I focussed the blurry stars, the stars that were in focus were then out of focus :lol:
Mine was caused by the focuser eyepiece locking screw sitting wrong and allowed the cameras nose-piece to sit in the focuser slightly off square.
I fixed this by using a small piece of electrical insulation tape on the opposite side of the lock screw.
But yeah, even a small amount off square and you can see a bit of a difference in focus across the image.
