iEQ45 gear upgrade?
52 replies to this topic
#1 Polaris41N
Polaris41N
  • Loc: Eastern PA
Posted 08 May 2013 - 09:32 AM
Does anyone know of a worm gear upgrade for the iOptron iEQ45?
#2 rkayakr
rkayakr
  • Loc: Northeast Ohio
Posted 08 May 2013 - 11:44 AM
Aeroquest will make one. One was sold in the classifieds last December by a member who said that they were $112 new. Also - there is a post on the ieq45 imaging Yahoo group (message 2216) that quotes iOptron tech support as saying that iOptron will sell upgraded worms for $100 + $10 shipping and handling.
Bob
#3 Wembley2000
Wembley2000
  • Loc: SW Ohio
Posted 08 May 2013 - 11:59 AM
I had the aeroquest worm and the upgraded ioptron worm. Go for the upgraded ioptron one if you are going to do it. The ioptron worm was smoother than the aeroquest and was I think lower in pe if I remember correctly.
#4 Astronewb
Astronewb
  • Loc: Connecticut
Posted 08 May 2013 - 12:58 PM
Ditto...! iOptron has indicated in an email to me, that the updated worms will be available sometime in June.
Fwiw,
Paul
#5 kyang
kyang
  • Loc: Fremont, CA
Posted 08 May 2013 - 02:01 PM
Will iOptron offer upgraded worms for iEQ30 ?
#6 timmbottoni
timmbottoni
  • Loc: W Chicago suburbs, IL USA
Posted 08 May 2013 - 02:46 PM
I plan on getting one once they are available.
Thanks for the info
Timm
#7 Polaris41N
Polaris41N
  • Loc: Eastern PA
Posted 08 May 2013 - 07:19 PM
Thanks to all of you for your answers. I talked to Kevin at iOptron earlier this afternoon and he did indeed say he was waiting on some parts to put the worm upgrade kits together. He indicated they would post availability on their web site when the kits are ready.
#8 Astroeksarheio
Astroeksarheio
Posted 28 June 2013 - 07:52 AM
Hello from Greece!
I contacted with Kevin too a month ago and had the same answer. I sent him an email again yesterday for an update and he informed me that they have been furnishing and testing better pulleys and belt so there will be another month of delay. Thats cool by me though the better the kit the more we benefit all
#9 Stew57
Stew57
  • Loc: Silsbee Texas
Posted 28 June 2013 - 04:34 PM
Paul
What is the raw PE of your mount again? Seems it was astonishingly low and an "upgrade" gear set may be a disappointment.
#10 dvb
dvb
    different Syndrome.
  • Loc: Vancouver, Canada
Posted 28 June 2013 - 07:03 PM
Is the upgraded gear easy to install?
#11 Goodchild
Goodchild
Posted 28 June 2013 - 08:39 PM
Are new IEQ45's coming with the upgraded gear?
#12 chboss
chboss
  • Loc: Zurich Switzerland
Posted 29 June 2013 - 01:46 AM
Following this interested... looking forward to more details. ;)
regards
Chris
#13 Astronewb
Astronewb
  • Loc: Connecticut
Posted 29 June 2013 - 09:16 AM
Paul
Hi Stew, the raw PE on my iEQ45/8407 was about 32 arc secs peak to peak, if I remember correctly.
Early on I installed a Telescope Drive Master, which put an end to any PE concerns I may have had.
Regarding the info from iOptron about pulleys and belts in addition to the updated worm, if they go to the 28 tooth pulley and belt currently used on the ZEQ25 mount, it should transform the iEQ45.
The pulley and belt are very fine when compared to the iEQ45 and should immediately smooth out any PE graph.
It will be interesting to see what they finally offer to consumers.
Clear skies,
Paul
#14 Astronewb
Astronewb
  • Loc: Connecticut
Posted 29 June 2013 - 09:21 AM
Replacing the worm on a iEQ45 requires disassembly of the RA gear housing and just basic mechanical skills.
Any kit would hopefully have installation instructions, and I'm pretty sure there are probably some on the Yahoo Group iOptron Imaging forum.
Paul
#15 Astroeksarheio
Astroeksarheio
Posted 01 July 2013 - 06:12 AM
I found about a month ago (dont remember where from) a pdf manual beautifully instructing how to clean or replace RA gear. Had to split the file because was 400kb
#16 Astroeksarheio
Astroeksarheio
page 3
#17 Astroeksarheio
Astroeksarheio
Posted 01 July 2013 - 06:13 AM
and the last 3 pages. Enjoy
#18 Bill McNeal
Bill McNeal
Posted 21 July 2013 - 04:20 PM
Are units sold today shipping with the upgrade? Also any word on a ZEQ45 model?
#19 Astroeksarheio
Astroeksarheio
Posted 31 July 2013 - 07:39 AM
Last day of the month but no news from ioptron bout the worm,belt and pulley upgrade. Hope they soon put the package up for sale. I wouldnt like to see a new zeq45 being released before that especially now that i recently bought the ieq45(without the upgrades)
#20 rkayakr
rkayakr
Posted 01 August 2013 - 09:09 AM
I believe that you have to ask tech support. I did and they asked for a pix of my worm to see if I could use the upgrade. I had a problem at the first step in getting the invisible 1.5 mm allen head set screws out of the pulleys. I sent a pix of the pulleys and they responded that the pix was enough to say that I can use the upgrade. However, they were discouraging about the upgrade and suggested that I try to change the relative position of the RA worm and motor shaft or reassemble the RA driving train first.
To do any of those I need to get the @#$^#@# set screws out. If I ever do, I would just as soon put the better parts in as disassemble and reassemble repeatedly.
Bob
#21 Astroeksarheio
Astroeksarheio
Posted 08 September 2013 - 06:02 PM
https://www.ioptron....c5f7604d-c97...
Mine is arriving tomorrow! :yay: :yay: :yay:
#22 Astronewb
Astronewb
  • Loc: Connecticut
Posted 09 September 2013 - 10:12 AM
Hi Bob, the set screws in the pulleys are 1.5mm allen type.
I found it best to grind off the short arm a bit to give increased room between the two pulleys. Hint: if you pull the housing up to disengage the worm, you can turn the pulleys with your fingers to allow access to the set screws, or simply power up the mount and slew in RA to access the screws.
I did a test of the new worm, and also the new style pulleys. The new pulleys did not perform as expected.
I also modified a set of Z pulleys (fine pitch) and installed them, they worked great.
Details can be found in this Flickr set, with annotations:
http://www.flickr.co...57635275957079/
Hope the info helps,
Paul
#23 rkayakr
rkayakr
Posted 09 September 2013 - 07:07 PM
Paul
Thanks - A ball ended hex key did the trick for me.
I received the iOptron upgrade kit today. It contained a new worm, 2 bearings, a new pulley, a new encoder, a few bits of fastening hardware and, of course, no instructions. I have the December 2011 RA Worm Gear Cleaning instruction pdf and will use that as a guide unless someone has something more relevant.
Since a single pulley is provided I assume that there is no change to the belt/pulley system so that I will have the old style belt/pulleys.
I got a new puppy! Ursa Minor is a 10 week old female Golden Retriever. She should be a big help in the mount disassembly process, as long as she doesn't eat anything too important.
Bob
#24 timmbottoni
timmbottoni
Posted 10 September 2013 - 07:10 PM
I's still testing mine, but I confirmed off line with Paul that mine is performing much better than my original worm gear.
Timm
And congrats on the new puppy!
#25 Astroeksarheio
Astroeksarheio
Posted 11 September 2013 - 05:22 AM
So the mix that would make our nights easier consists of ioptron's worm, Paul's belt/pulleys, better bearings and some cleaning/new grease maybe(superlube or else) ?
