Bent compression ring?
4 replies to this topic
#1 StrangeDejavu
StrangeDejavu
  • Loc: Florida
Posted 09 May 2013 - 06:36 PM
I got my Z10 dob today. :grin: :jump: However, as I was playing with the 5 or 6 screws on the focuser tube, I apparently screwed in one side on the 1.25" adapter too hard. Now the compression ring is slightly bent and won't allow 1.25" eyepieces and my laser collimator inside without scratching it to ****. Newb mistake... I know. :(
Has anyone had this happen to them and found a simple fix for it? Sunset is quickly approaching and I haven't even checked collimation, let alone set it out to cool down. :(
#2 CharlesW
CharlesW
  • Loc: Chula Vista & Indio, CA
Posted 09 May 2013 - 07:01 PM
Pull the ring out, wrap it around something that is a little bigger than 1.25", then cinch it down with a hose clamp. That should take out the flat spot.
#3 StrangeDejavu
StrangeDejavu
  • Loc: Florida
Posted 09 May 2013 - 07:05 PM
Thanks Charles, i'll do that. I just took out my 1.25" adapter from my refractor so at least I can check collimation and use it tonight. :D
#4 Jon Isaacs
Posted 09 May 2013 - 07:52 PM
I've done it. Just remove it and bend it back, it's just brass. I used a small diameter roller to reform it.
#5 StrangeDejavu
StrangeDejavu
  • Loc: Florida
Posted 09 May 2013 - 11:14 PM
Thanks guys, it's good as new. :)
