Strange behavior with LX90 motor accuracy
3 replies to this topic
#1 cirrus1500
cirrus1500
  • Loc: Florida
Posted 10 May 2013 - 06:00 AM
I have a LX90 Classic and was testing the accuracy of its motors this afternoon.
I tested in terrestrial mode during the day, by storing the positions of a few landmarks so that I can test by slewing to them. From its home position (northwards), I stored a nearby landmark as "LM1", then slew left 90 deg. and stored another as "LM2", then slew right 180 deg. (90 deg to the right from home) and entered as "LM3".
So, location-wise, it is like this: LM2 ---- LM1(Home) ---- LM3
Now if I start at LM1, and slew to either LM2 and LM3, the motor is very accurate. From LM3 to LM1 or from LM2 to LM1 - also very accurate. But when slewing between LM2 and LM3 without going through the home position first(that is scope rotates 180 deg in the other direction), the scope will overshoot the target. Now, I thought to myself that the alignment must be off by then, but when I continue to slew it back to LM1 (home), the LX90 slew 270 degrees (cord-wrap setting on) in the direction it came from and LM1 was dead center. Then from there, going to LM2 or LM3 is very accurate again.
It seems that the scope is VERY accurate as long as it slews back through the path it came from because it has count the data clicks to get back to target. But if it goes to the target from the other direction, it will miss slightly (about 10 degrees). It don't seem to know how much to move in the other direction to get to the target. Is this normal? If not, any suggestion with what is wrong with my scope? I did a reset and retrain and it still behave the same way. By the way, I have problem with my GOTO Astro mode even after successful 2-star alignment. My Autostar firmware is already the latest version (43Eg) on my 497 HC. I suspect the way it compute the clicks (not sure the right terminology to use) to get from coordinate A to B is wrong.
Any someone come across this problem before? This scope was the 2004 classic model.
#2 thesubwaypusher
thesubwaypusher
  • Loc: New York City
Posted 10 May 2013 - 06:53 PM
The LX90 is a step above the ETX mechanically. Although they can be trouble-free for years. The LX200 is a different animal, and if you can get your hands on one, pick one up. It will save you a lot of future trouble in dealing with the inferior LX90.
Don't feel bad, dealing with the ETX mechanics on a bad night can drive one nuts.
Good luck, Chris
#3 cirrus1500
cirrus1500
  • Loc: Florida
Posted 11 May 2013 - 08:21 AM
Thanks Chris for your response. The LX200 is too heavy for me as I have to drive to a dark site each time I view. Actually, my LX90 mechanics is not too bad, except for the weird behavior mentioned above.
Anyway, I did somehow solve the problem. I did some more search and found a 2003 thread with suggestion by "Dick" on Yahoo's LX90 user group that I should use the Alt/Az reading to see if my LX90 read 360 degrees when I rotate the scope precisely 1 turn. That is a very simple diagnosis that I am very glad to learn as a newbie.
http://tech.groups.y...0/message/37167
Mine reads 353.35 degrees. That explains why it overshot the target. Dick suggested that my encoder slots may be dirty. He also suggested a workaround: to change the Az Ratio setting in the Autostar to compensate for the mechanical error. I learned how to calculate the new ratio here:
http://tech.groups.y...0/message/74592
I tried that and with some trial and error my targets are now within my 7mm eyepiece. So the work around works very well.
If the problem is due to manufacturing variation of the gears and mechanical parts then the above setting should be a permanent solution. But I am worried that if its due dirty encoder slots, then the accuracy could deteriorate as the encoder gets dirtier or clears up, unless I clean up the encoder which is a rather cumbersome task to dismantle the scope. I hope my LX90 will hold its current accuracy well. Will test it with real stars when the sky clears up.
#4 thesubwaypusher
thesubwaypusher
Posted 11 May 2013 - 10:22 AM
Actually, I should have recommended you go to that site, but I did not think of it. All answers you will ever need are there. The fact that the encoders are so difficult to get to is good. That way, they will be cleaner longer. I can't imagine you having that problem again for quite a while.
Thanks for the update- it is sure to help some frustrated 90 owner in the future!
Chris
