Atlas AZ/EQG type of clutch?
5 replies to this topic
#1 mistyridge
mistyridge
  • Loc: Loomis, CA
Posted 11 May 2013 - 04:12 PM
Since I have only seen pictures of the Atlas AZ/EQG(also applies to Skywatcher version) I can't tell what type of clutch it has. Does it employ a slip clutch like the Losmandy G11? Or is it a positve lock type (all on or all off) as found on most Celestron mounts?
#2 mistyridge
mistyridge
  • Loc: Loomis, CA
Posted 12 May 2013 - 01:35 PM
I guess this mount is not out yet so nobody has one to give me an answer. :shrug:
#3 rmollise
Posted 12 May 2013 - 02:16 PM
The mount is out. The clutches are the same as on the Atlas.
#4 mistyridge
mistyridge
  • Loc: Loomis, CA
Posted 12 May 2013 - 02:48 PM
Thanks Rod.
#5 EFT
EFT
    Vendor - Deep Space Products
  • Loc: Phoenix, AZ
Posted 13 May 2013 - 09:02 AM
As Rod said, "same as the Atlas," which means that the clutch presses a brass button against the surface of the ring gear drum in order to engage. The pressure that can be applied is variable.
#6 mistyridge
mistyridge
  • Loc: Loomis, CA
Posted 14 May 2013 - 01:53 AM
That was what thought, not a total all on or all off, in reading other users experience.
