Saturn 2013 05 25, drawn in pastel at the eyepiece
21 replies to this topic
#1 chrisrnuttall
chrisrnuttall
  • Loc: York, England
Posted 26 May 2013 - 12:07 PM
Hello all
Here is a drawing I made last night of Saturn.
This morning I cut it out and mounted in my sketch book, the rest was done at the eyepiece.
The seeing was OK, mostly AntIII, later degrading to AntIV. I did however have a couple of brief moments of AntII early on in my session, during which I was treated to a clear view of the white collar around the NPC, and the yellow zone in the North temperate region (which is apparently the remnant of last year's storm).
No details within any belts or zones unfortunately.
I was able to capture the broad Encke minimum in ring A, and three different tones in ring B.
#2 azure1961p
azure1961p
  • Loc: Triton
Posted 26 May 2013 - 01:04 PM
Utterly superb Chris!!!
I just got my mirrors back (recoated) so Im looking forward to a gander to night at Saturn. The polar region is very nicely done. I've wondered for a while if that brighter edge to the A ring on its exterior side (facing the f ring) is not a contrast produced by the dark background but the lighter contrast of that outer edge of the ring that the Encke gap seperates. I posted the query of that possibility in the planetary forum but to no conclusion. It would be interesting that while the gap is invisible the slight albedo on either side of it defines those two different areas regardless.
This is one of your best Chris. Very well done.
Pete
#3 dweller25
dweller25
  • Loc: Lancashire, UK
Posted 26 May 2013 - 01:31 PM
Fantastic Chris, I was out at the same time but had very poor seeing after 11pm. Your new scope is turning out great views.
#4 frank5817
  • Loc: Illinois
Posted 26 May 2013 - 01:45 PM
Chris,
This is a beautiful crisp capture of Saturn showing much fine detail. Exceptional.
Frank :)
#5 chrisrnuttall
chrisrnuttall
Posted 26 May 2013 - 01:52 PM
Pete, I think that's it, I'm sure someone will confirm or deny, but the Encke gap is found at the outer edge of the Encke minima. You could be right about the outer edge of ring A simply appearing bright because it is seen against the black sky though. it's what makes it fun!
Good luck with your mirrors Pete, I hope they blow your socks off!
thanks for the complements everyone.
#6 Asbytec
Asbytec
    Guy in a furry hat
  • Loc: Pampanga, PI
Posted 26 May 2013 - 02:18 PM
Chris, well done. Per Pete's comment, I've not seen the outer A ring as brighter. For me, the inner A ring appears brighter. Nice catch on the polar cap, never seen it that well, either.
I missed Saturn this year. Traveling and away from my scope and clear, steady skies. Upon returning home next week, it'll be rainy season.
#7 magnus
magnus
  • Loc: Visby, Sweden
Posted 26 May 2013 - 02:54 PM
Pretty impressive sketch & observation. Wordclass! Thanks for sharing :)
/Magnus 57N.
#8 chrisrnuttall
chrisrnuttall
Posted 26 May 2013 - 05:14 PM
It hasn't really come across in the sketch, but the A ring was darker than the B ring.
#9 Andrev
Posted 26 May 2013 - 05:32 PM
What an extraordinary sketch. So beautiful and detailed. I like it so much. You did a very great job.
#10 kenrenard
kenrenard
  • Loc: Dunmore, PA
Posted 26 May 2013 - 06:59 PM
Chris,
Nice sketch and observing report. You were able to get some nice detail with even poor seeing. The moments of AVII must have proven helpful.
Ken
#11 Aquarellia
Aquarellia
  • Loc: Provence, France
Posted 26 May 2013 - 11:19 PM
Very nice sketch and report Chris, your pastel technic is whaw.
#12 stanislas-jean
stanislas-jean
Posted 27 May 2013 - 07:22 AM
Details on the pole area are interresting to note here from your sketch.
Stanislas-Jean
#13 Jef De Wit
Jef De Wit
  • Loc: Hove, Belgium
Posted 27 May 2013 - 07:38 AM
What a subtile pastel work :applause:
#14 niteskystargazer
Posted 27 May 2013 - 11:53 AM
Chris,
Very good sketch of Saturn :).
CS,KLKU,
#15 idp
idp
  • Loc: New Haven, CT
Posted 28 May 2013 - 07:04 AM
Wow. I just say wow. This view is very, very similar to the one I had last night with a 10" refractor, but no way I can reproduce it like you did.
I suppose you used a template on black paper, right? How do you print it?
Ivano
#16 idp
idp
Posted 28 May 2013 - 07:09 AM
OK, maybe I got it! Is normal Xerox paper OK for pastels?
Ivano
#17 chrisrnuttall
chrisrnuttall
Posted 28 May 2013 - 01:21 PM
Ivano
I use velour paper, normal Xerox paper does not have enough 'tooth' for pastels, that means the powder fills the surface very quickly and if you apply more it falls just off.
You can also use heavier pastel papers, they have rough surface to hold on to more pigment and I think are quite good for the moon with its craggy detail, but for planets I like the softness velour paper provides.
#18 Achernar
Achernar
  • Loc: Mobile, Alabama, USA
Posted 28 May 2013 - 01:55 PM
Very good sketch. Now I know beyond any doubt those white regions near the pole are real features and not illusions, I was seeing them through my 15-inch. Last night, I caught a glimpse of them through the 6-inch too, which has excellent optics.
Taras
#19 JimPie
JimPie
  • Loc: S.E.Michigan
Posted 28 May 2013 - 11:26 PM
Chris, Exquisite !
#20 mike73
mike73
  • Loc: UK / Cornwall
Posted 02 June 2013 - 04:39 AM
One of the best Sketches/observations I've seen on here for quite a while, well done!!
#21 Tamas Bognar
Tamas Bognar
  • Loc: Hungary, Zákány
Posted 02 June 2013 - 11:44 AM
Very nice sketch !!
#22 ericj
ericj
Posted 15 July 2013 - 09:17 AM
Hi Chris,
Very fine sketch, you recorded a lot of fine detail.
I just started working with pastels when making sketches of the planets.
Any tips or suggestions for me?
Here is a link to the sketch:
http://ejamison.net/saturn052813.html
Best,
Eric Jamison
