Ioptron IEQ 45 AZ GOTO Mount
29 replies to this topic
#1 barry j
barry j
Posted 02 June 2013 - 08:11 AM
Has anyone tried this new mount? It seems like everyone is jumping on the EQ/AZ dual mount bandwagon.
Barry
#2 germana1
germana1
  • Loc: New Jersey
Posted 02 June 2013 - 08:58 AM
I'm waiting on some reports too very interested in this mount also.
Pete
#3 MRNUTTY
MRNUTTY
  • Loc: Mendon, MA
Posted 02 June 2013 - 09:03 AM
Paul (astronewb) bought one and provide a series of threads on the mount. astronewb's posts
#4 Astronewb
Astronewb
  • Loc: Connecticut
Posted 02 June 2013 - 11:52 AM
Close John, but I don't have the alt/az version, although with the az conversion kit, it would qualify.
Paul
#5 MRNUTTY
MRNUTTY
  • Loc: Mendon, MA
Posted 02 June 2013 - 12:18 PM
oops! I messed up! sorry Paul. :-)
I confess to be confused about these newer products.
#6 dc_robert
dc_robert
  • Loc: Washington, DC
Posted 02 June 2013 - 12:24 PM
I recently got this mount, along with the iOptron PowerWeight (a portable power supply that also acts as a counterweight). The AZ version has a couple kinks that need to be worked out:
* The handset controller's firmware didn't come updated for AZ mode. It's not difficult to update the firmware, but...
* The mount comes only with RJ232 connectors and no USB. None of my computers has an RJ232 (aka serial) port, so I had to buy a USB-to-RJ232 converter.
Switching from GEQ to AZ mode isn't that difficult, fortunately. But having just updated the handset yesterday with the right firmware, I haven't yet properly tested the mount in AZ mode.
#7 Mkofski
Mkofski
  • Loc: Greenfield, Indiana, USA
Posted 02 June 2013 - 12:32 PM
If those are the only 2 issues, it looks pretty good. Most (all?) low and mid level mounts still have Serial ports rather than USB so I wouldn't even count that one as an issue. With the innovation seen from iOptron, I'm a bit surprised that they haven't moved to USB yet.
#8 Mkofski
Mkofski
#9 dc_robert
dc_robert
Posted 02 June 2013 - 12:34 PM
Here is a pic of the mount in AZ mode, btw.
As you can see, it comes with the pillar instead of the tripod.
#10 MikeBOKC
MikeBOKC
  • Loc: Oklahoma City, OK
Posted 02 June 2013 - 03:21 PM
What strikes me most about this mount is its stated payload is considerably higher than the Synta EQ/AZ entry, which offers a payload on dual AZ mode of only 20 pounds per side, for several hundred dollars more than the iOptron.
#11 MRNUTTY
MRNUTTY
  • Loc: Mendon, MA
Posted 02 June 2013 - 03:53 PM
that is SLICK! I already have the Pier... I love Alt-Az for some stuff. Looks like a spiffy replacement for the MTII.
#12 johnpd
johnpd
  • Loc: Green Valley, AZ
Posted 03 June 2013 - 03:07 AM
I think you may have misread the specs on the Synta AZ-EQ6. It states a payload of 20kg (~44 lbs) excluding counterweights. That means it could handle 40+ lbs per side (~88 lbs in total).
JohnD
#13 MikeBOKC
MikeBOKC
Posted 03 June 2013 - 07:26 AM
You are right John, I stand corrected!
#14 Bluejay08
Bluejay08
Posted 08 June 2013 - 03:30 PM
Yes, USB is convenient. Actually, ioptron's MiniTower and Cube mounts are among the first using USB cables for computer control. I still remember when one tried to use a iPhone to control the MiniTower via WiFi, the adapter from Orion only had serial port at the time.
For USB 2.0 standard, the maximum cable length is 5 meter, I think. When using a RS232 cable, it can be up to 15 meter at 9600 bps. If you want to control a mount from a distant computer, it may run into difficulty with a USB port.
My limited knowledge about the ASCOM also indicates that the command sent to the mount is still in a serial format. So there is a need for a USB to Serial converter anyway, integrated or external.
Jay
#15 leveye
leveye
  • Loc: Central Oregon Coast
Posted 08 June 2013 - 07:28 PM
Such a great looking rig congrats!!
I have over 65 feet run to my Zmount using USB 2.0 and repeater cables every 15 feet no issues at all.
#16 Bluejay08
Bluejay08
Posted 08 June 2013 - 09:43 PM
Of cause it can go longer with repeaters.
Jay
#17 SteveGR
SteveGR
  • Loc: Western Michigan
Posted 11 June 2013 - 02:12 PM
Don't feel bad! Unit conversion mistakes are common, and it's not like you crashed a probe into Mars... :)
#18 MRNUTTY
MRNUTTY
  • Loc: Mendon, MA
Posted 15 September 2013 - 01:46 AM
Inadditon to this mount, iOptron also came out with an upgrade kit to convert the iEQ45 to the Alt-Az mode via additional hardware changes plus firmware changes to the handset.
I started the conversion last week and ran out of time to complete to view this weekend. I very much appreciate the Alt-Az mode for observation, it's easier to make those initial positioning, as well as providing a second mount point for an additional scope :D I like the 10"SCT narrow angle view with a 3-5" refractors for wide angle view.
Good stuff!
#19 rkayakr
rkayakr
  • Loc: Northeast Ohio
Posted 15 September 2013 - 08:03 AM
John
Let us know how the conversion goes.
Did you have to remove the polar scope to do the conversion?
#20 MRNUTTY
MRNUTTY
  • Loc: Mendon, MA
Posted 05 October 2013 - 09:35 PM
@rkayakr, FINALLY finished my conversion, had a setback when my hand controller died. what I love most about it is being able to mount my Meade 10"ACF and my 6" Achro; that's 28+28lbs :-)
Yes, you do remove the polar scope, there is no need to keep it. You just have to ensure its level, and oriented to East.
#21 rkayakr
rkayakr
Posted 06 October 2013 - 10:51 AM
John
Wow 2 x 28 lbs. You sound like a happy camper.
My issue with the polar scope is that I would like to go back and forth between the styles. Reinstalling the polar scope would add the effort of recalibrating when you go back to EG style.
#22 MRNUTTY
MRNUTTY
  • Loc: Mendon, MA
Posted 06 October 2013 - 08:07 PM
Oh! Good thing you mentioned it. Reinstalling the Polar scope isn't a problem compared to the rest of the changing; there is a lot of loose hardware with all the knurled bolts and spacers. This what I was hoping the LX80 would have been like.
Here's the result:
I just noticed it obscured the mount, here's another angle. All the images from the other side are fuzzy. I can post some close ups later.
Oh... Yeah, I get what you mean about the polar scope. I haven't moved mine since I had it setup last. Yeah, alignment is always a hoot :-)
#23 rkayakr
rkayakr
Posted 06 October 2013 - 09:17 PM
Nice mount setup and beautiful observatory!
#24 MRNUTTY
MRNUTTY
  • Loc: Mendon, MA
Posted 06 October 2013 - 09:19 PM
TY! It almost keeps me out of trouble :-)
The iEQ45 was my favorite mount but the Alt-Az kit came out and now it's even MORE of a favorite with this new functionality. I vastly prefer Alt-AZ to GEM for visuals and with this tonnage of carrying capability I'm totally wowed!
Btw, I lucked out that these two scopes happened to be the same weight!
#25 Moromete
Moromete
  • Loc: Romania
Posted 06 October 2013 - 10:48 PM
Very nice to have in parallel a 10" SCT and a 6" achro!
How do you put the same object in the eyepieces of both OTAs in the same time with IEQ45 AZ?
