Why no Nikons?
47 replies to this topic
#26 ZR WON
ZR WON
  • Loc: Indiana
Posted 08 June 2013 - 09:07 AM
Duka:
Thanks so much for this software! I downloaded your software and have done some testing with my D7000 in the house and all seems well, sans the 'bulb' mode. One thing that works is to manually set the camera to 'bulb' and then use the Nikon remote control for shutter operation. The software controls the rest of the camera functions and hitting that button, while it will likely grow slightly tiring on longer exposures, seems like a reasonable 'temporary' fix. What is it specifically about the D7000 that you cannot control the 'bulb' function with your software? Thanks again, I can't wait to try it out on my scope in the coming days
Brian A.
Smiling Chicken Observatory
#27 dasams
dasams
  • Loc: NorCal
Posted 08 June 2013 - 04:38 PM
Duka:
The firmware on the newer Nikons is configured to allow bulb control via the usb cable whereas older Nikons require use of the 10 pin connector. Hence, you'll need a second cable and a program such as DSLR Shutter. There's a post above which lists which cameras allow usb control of the shutter. Dave
#28 Joepie
Joepie
  • Loc: The Netherlands
Posted 26 July 2013 - 11:36 AM
Alright, so my sis wants to buy my 1100D and I'm thinking about buying a D3200/D5200 again... :grin: 1100D's noise is bad and resolution's a bit low too.
#29 Footbag
Footbag
  • Loc: Scranton, PA
Posted 26 July 2013 - 11:45 AM
These days, performance differences between brands will be hard to see. Canon may be slightly behind with sensor tech, but I think the convenience of software solutions would make up for that. Of course BackyardNIK is coming and that will change things.
I wouldn't call the 1100D's noise performance bad, nor would I even bother taking resolution into account. All current DSLR's will have more then enough resolution. Purpose built astronomy CCD's will have larger pixels and lower resolution and this is a good thing.
#30 guyroch
guyroch
    Vendor (BackyardEOS)
  • Loc: Under the clouds!
Posted 26 July 2013 - 02:34 PM
The Nikon D5100 is probably your best bet for noise; it has an awesome Sony sensor.
The Nikon D3200 should be at the bottom of the list. The D3### series can not be tethered via software using the Nikon SDK so software is even more limited with this model.
The Nikon D5200 has a new Tochiba sensor and the jury is still out on these one.
The Canon 1100D is actually a good astro-performer. The noise level is on the low side compared to other Canon models.
http://ghonis2.ho8.c.../T3iReview.html
Good luck,
Guylain
#31 Joepie
Joepie
Posted 06 August 2013 - 11:46 AM
Just bought a Nikon D5100 :jump: Couldn't ignore spending only 157 euros. We'll see.
#32 WillCarney
WillCarney
  • Loc: Bloomington, ILL
Posted 09 October 2013 - 12:31 PM
I didn't know there was an embargo.
Not quite.
Majority of older Nikon DSLRs up to D40x (D40x, I think) were using CCD image sensor. They employed a non-defeatable older version of the Hot Pixel Suppression (HPS) algorithm, nick named star eater. Thus the ugly "mode 3" method to bypass the HPS step is required.
In that era, N made it very difficult to get its SDK while Nikon's own tethering software costs a lot.
The situation has changed quite a bit...
Recent Nikon DSLRs are all using CMOS sensors (less heat generated to make Liveview possible) and are using a refined version HPS algorithm with less Pacman-like behavior.
Nikon DSLRs' SDK (AFAIK) is now free.
N still has add few minor "tint" and intentional crippling (e.g., no lossless NEF) on lower end gears. Talented Nikonhacker(s) are removing some of them.
It is looking nicer and nicer. D5100 (using SONY Exmor IMX071) IMHO is very nice. Several days ago, refurb model was selling at $429 with a kit 18-55 VR lens included, $5 shipping (see here! Now sold out, of course.) Clear Skies! ccs_hello
My D40x allows you to take a noise reducer photo but it DOES NOT force you to. You have to go to the menu and choose to take one. You can see a few of my posts taken with my full spectrum D40x. There are no stars dropped at all unless it's done with Nebulosity3 or DSS. I tested a T1i, T2i and 5DMarkii Canons and several Pentax DSLR. My Nikon does great and even beats some of the others in noise levels. Right now I use the IR remote and have not gotten around to laptop control. William
#33 dkbender
dkbender
  • Loc: Illinois
Posted 09 October 2013 - 02:13 PM
Good to know that the Sony IMX071 sensor in my Nikon D7000 is a good one. My D700 full frame sensor is even better, in normal photography.
Would love to see a Nikon version of Back Yard come to market.
From what I can tell currently, TetherPro and Images Plus should work at some level. Will continue to mush on.
#34 TimN
TimN
  • Loc: Ontario, Canada
Posted 10 October 2013 - 08:16 AM
I believe BackyardNik is coming out late this year or early next year. However, Sequence Generator Pro now supports Nikon. I used to use TetherPro with my D5100 but I really like the many extra features of SGP. Its certainly nice to have some choices for us Nikon users.
#35 snommisbor
snommisbor
  • Loc: Cedar Park, TX
Posted 10 October 2013 - 08:47 AM
I have too much nice glass to justify switching so it would be nice. Im a Nikon user and a Mac user so I really dont have a whole lot of options. So for now it is PHD and The Sky X which is great for getting me to target and then running my intervolmeter on my D700 to capture to the CF card.
#36 dkbender
dkbender
  • Loc: Illinois
Posted 10 October 2013 - 11:40 AM
ahhh....!!! another D700 user! I just love my D700 for regular photography. How does it do for AP?? I'm just getting started and also have a D7000, which everyone seems to really like the Sony sensor in it.
#37 snommisbor
snommisbor
Posted 10 October 2013 - 11:49 AM
It a full frame sensor so you get excellent high ISO properties even though I still try to shoot around 800 to 1250. It does show vignetting due to the large sensor but I have been very pleased with it. I have taken some great wide field images as well as the witches broom just this past Monday. It turned out pretty good, I am sure I can improve it just through processing but it was the first time I ever did where you do a luminosity file then blend with a RGB. but shooting wide field with my 200-400 f/4 or 50 f1.8 is great.
#38 dkbender
dkbender
  • Loc: Illinois
Posted 10 October 2013 - 12:18 PM
Beautiful photo! Can you give me the particulars on which lens and maybe a little bit more on the processing?
I plan on trying prime focus with my 100mm Apo.... and then with some of my Nikkor lens piggybacked on the scope.... in particular, the AFS 300mm f/4, the AFS 85mm f/1.4G and the AFS 14-24mm f/2.8. I also have the TC-14E II that I use with the 300mm for capturing wildlife, I thought since that works so well with that lens, that the combination might be worth a try.
#39 guyroch
guyroch
Posted 10 October 2013 - 12:30 PM
The Nikon D7000 is NOT a full frame sensor. It has the same Sony sensor as the D5100.
EDIT: Oops... I think you meant the D700... in that case it is a full frame sensor.
Sorry for the confusion :(
Guylain
#40 dkbender
dkbender
  • Loc: Illinois
Posted 10 October 2013 - 12:41 PM
Guylain
Hello Guylain!
I have both the D700 & D7000. I was glad to read your liking of the D7000 Sony IMX071 sensor! That encouraged me. I was asking Rob about his experience with the D700, since it is Nikons sensor design. That FF sensor works REALLY well in regular photography, but I didn't have any input yet on how it will do in AP.
By the way, just to let you know, I'm anxiously awaiting BackYardNik. Are we getting close?? Many thanks!!
#41 guyroch
guyroch
Posted 10 October 2013 - 01:17 PM
Guylain
Hello Guylain!
Yeah... the Sony sensor in the D7000 and D5100 is just awesome. Even at 20c the noise is very low.
I'm making good strides on BackyardNIKON; thanks for asking. Still aiming late 2013 / early 2014 for beta release. We should move this conversation to the vendor forum if you want more info, I can't push software here.
Guylain
#42 snommisbor
snommisbor
Posted 10 October 2013 - 01:29 PM
That was shot with my D700 with a Nikkor 200-400 f/4 at F/4. I shot it at ISO 1600 and they were 3 minute shots and it was only 5 shots. I was at my dark sky place ( see my Clear Dark Sky Chart ) so that really helps. That was without a filter or anything. I cant remember if it was guided or not. I stacked in DSS and just processed in PS CS5. It was pretty easy, being in a dark site you could see the Lagoon and Trifid just from one 3 minute shot very easily. I shot this one with my 105mm Micro 2.8 at f/4 and it was alright but I didnt really like the dullness of the star field compared to Scorpius, that area just rocks.
#43 ccs_hello
ccs_hello
Posted 10 October 2013 - 04:07 PM
I would suggest try digicamControl for now:
http://digicamcontro...te-feature-list
Newly added astro features:
http://digicamcontro...igicamcontro...
#44 Astronewb
Astronewb
  • Loc: Connecticut
Posted 10 October 2013 - 05:11 PM
Ditto...
Paul
#45 GageCook
GageCook
  • Loc: Gallatin, TN
Posted 10 October 2013 - 05:43 PM
D7000 user here! I'm pretty new to AP and the D7000 is the first and only camera I've used. Not to say I wouldn't try any other, it's just what is available to me right now. I use ControlMyNikon for tethering and live view. I also use DSS and Fitswork along with GIMP. I would LOVE to try BackyardNIK when available! Add me to your mailing list when it comes out! Here is my first AP done last night...
#46 GageCook
GageCook
  • Loc: Gallatin, TN
Posted 10 October 2013 - 05:45 PM
here
#47 GageCook
GageCook
  • Loc: Gallatin, TN
Posted 10 October 2013 - 05:50 PM
30x2 minutes. Red zone. no mods to d7000. no filters. my first REAL attempt at AP and processing.
#48 Neil McAllister
Neil McAllister
Posted 11 October 2013 - 08:54 AM
I am very new to this asrophotography game,owning for some time an Astrotrac but not using it.I also have a copy of Pixinsight for processing future images but that seems like a steep learning curve ahead to say the least.My camera which I've owned two years for regular daytime stuff is a Nikon D3s along with Nikkor lenses,this is supposed to have a good sensor chip and sensitivity for regular shots,will it prove useful for this new avenue? Neil
