CGEM azimuth motion rough
14 replies to this topic
#1 jacobmarchio
jacobmarchio
  • Loc: near the Loveliest Village on the Plains in the Heart of Dixie
Posted 07 June 2013 - 02:56 PM
Hi all,
The azimuth motion for polar alignment on my CGEM is very rough, or "jumpy". Is there an easy solution for this? WD-40? Anything recommended/not recommended?
#2 DaveJ
DaveJ
  • Loc: NE Ohio
Posted 07 June 2013 - 03:02 PM
Hi all,
Funny you should ask. Take a look at an ongoing thread here.
#3 jacobmarchio
jacobmarchio
Posted 07 June 2013 - 03:57 PM
Oops! Didn't see that thread! Thanks.
I'll try WD-40, and see if it works. Bicycle chain grease was suggested, so I'll try that next...
#4 DaveJ
DaveJ
  • Loc: NE Ohio
Posted 07 June 2013 - 05:27 PM
I'd first try "Super Lube" available at Harbor Freight or Amazon if you're sure grease is the idea you'd like to try. Honestly, the white plastic "milk jug" is a better idea but the sticky-backed UHMW plastic is much better still, especially if you'll be taking it apart for travel setup.
#5 Ron (Lubbock)
Ron (Lubbock)
  • Loc: West TX
Posted 08 June 2013 - 10:47 PM
When the mount is first put onto the tripod, one tightens a screw clamp underneath the tripod to secure the mount. This hand-tightened clamp should be loosened just a little before making azimuth adjustments. On my mount, the azimuth then glides smoothly. Otherwise, the azimuth sticks or moves in spurts. Of course, one has to tighten it again before continuing.
#6 DaveJ
DaveJ
  • Loc: NE Ohio
Posted 09 June 2013 - 08:07 AM
No need to loosen the head when the UHMW material (mentioned above) is used. Honestly, as I previously mentioned, the head can be cranked down hard and the AZ motions are "smooth as butter" once the UHMW material has been installed. It made a night-and-day difference in my CGEM DX and my friend's CGEM.
#7 Ron (Lubbock)
Ron (Lubbock)
  • Loc: West TX
Posted 09 June 2013 - 08:48 AM
That's an interesting fix. UHMWPE also performs well in hip replacements, probably for the same reasons- good wear resistance.
#8 Raginar
Raginar
  • Loc: Rapid CIty, SD
Posted 09 June 2013 - 10:29 AM
Add some super lube. the other thing I found that helped was getting ADM knobs. They're easier to grab... You can also drill the holes out and re-tap them with SAE threads.. :D And, the 'milk jug' material helps tremendously.
:jump:
#9 PeteM
PeteM
  • Loc: West Michigan
Posted 09 June 2013 - 07:57 PM
I used slick strips on my CGEM tripod head and it is super smooth now for polar alignment. I detailed the install and linked to the supplier on my little blog HERE.
#10 mich_al
mich_al
  • Loc: Rural central lower Michigan Yellow Skies
Posted 09 June 2013 - 10:47 PM
Take a look at both sliding surfaces and make sure they are smooth. Mine had some paint that needed to be removed and some rough areas that needed sanding. Careful harping too much on tha AZ adjusters cause the thread in the mount can be stipped.
#11 gmartin02
gmartin02
  • Loc: Santa Clarita, CA
Posted 10 June 2013 - 03:38 PM
I just cut my own ring out of a piece of 1/16" thick Teflon sheet I had lying around from another project - now the motion is super smooth.
#12 jacobmarchio
jacobmarchio
Posted 11 June 2013 - 02:53 PM
Thanks everyone for your suggestions- I'll be trying them.
#13 Stargazer78
Stargazer78
  • Loc: Susanville California
Posted 28 August 2013 - 07:15 PM
Looks like mine is doing the same thing
#14 Stew57
Stew57
  • Loc: Silsbee Texas
Posted 28 August 2013 - 07:22 PM
Poor man's Teflon (milk jug)on mine. Works great and is free.
#15 A. Viegas
A. Viegas
  • Loc: New York City/ CT
Posted 28 August 2013 - 09:40 PM
I used the milk jug cut-out as well, with some WD40 squirted on it for good measure. works great now, going on 4 months... no complaints...
Al
