Problems with my CGEM and guiding
2 replies to this topic
#1 Jose Candelaria
Jose Candelaria
  • Loc: Puerto Rico
Posted 10 June 2013 - 11:33 AM
Hello. I have a problem that I would like to help me solve. My equipment is a Celestron CGEM mount and Orion StarShot mini autoguider. At first everything right, but two months as my guide began to be a bit lacking until I do not even calibrated. It seems that the guiding does not send or mount command does not receive and does not move the mount to calibrate. :bawling:
#2 rmollise
Posted 10 June 2013 - 12:52 PM
Are you using the ST-4 port or the serial port on the hand control? Have you checked PHD to make sure no settings have been changed accidentally? Can you move the mount manually with PHD? Have you checked your guide cable?
#3 Jose Candelaria
Jose Candelaria
  • Loc: Puerto Rico
Posted 10 June 2013 - 03:25 PM
I use the ST-4 port., PHD settings are right, I need to check the wire.
